TashTalk USB
On the server side, PAP has to handle parsing Postscript comments as part of the Adobe Document Structuring Conventions.
Also see Inside AppleTalk Chapter 14.
Supporting Macintosh LaserWriter drivers older then 7.0 isn't straightforward to do. These expect the LaserPrep file to be stored resident on the printer or spooler. The LaserWriter 7.0 driver can be installed on older versions of MacOS if needed and came with System 6.0.8. The Apple IIgs LaserWriter driver does some funky stuff when starting a print job that tripped up Netatalk (it sends Postscript data before the magic string), which has since been fixed.
Yeah I figured it'd likely be the same way I'm using that for querying the LaserWriters to bridge to IPP. Always love a good excuse to break out my Inside AppleTalk book though :) The only extra thing I think I'd do is bridge straight to IPP rather than rely on CUPS to try and keep it platform neutral and just translate the PostScript queries to and from IPP's versions.
In terms of attribute collection, CUPS is only used in Netatalk for the actual IPP communication link. Since papd always supported PPD files for retrieving printer attributes, a shim was built using IPP queries to generate a stub PPD on the fly with just the information the LaserWriter 8 driver needs.
Ahh that is great to know thank you! On another note too - any chance you know if the LocalTalk adapters for the later Colour StyleWriters use ADSP? I'm working on getting support added for the official Apple StyleWriter EtherTalk adapter to print to my CS 2200 which I know does and same with Grayshare, but I cant seem to find any docs about the LocalTalk module.
Just received mine and have confirmed that it works with a direct connection from a modern host and via AirTalk using the GUI to serve files over AFP. Will be testing with the MacIPGW virtual machine and will update with results there- my physical fileserver lacks the AppleTalk kernel modules.
I was able to get everything running without issue on Ubuntu but sharing ran into similar problems as others trying to get Netatalk and Tashrouter to run together on the same bare metal. Since Tashrouter can function as a LocalTalk-Ethernet bridge (unless I misread the docs), I'm going to try serving files over AFP from a G4 via ethernet and keep Tashrouter on the Ubuntu box- hoping to keep documenting stuff for anybody with the same use case later on. Definitely more complex than a Pi and a Tashtalk HAT but given the price increases, the ability to use this as a cheap, drop-in solution on any existing computer is very useful.
It was one of the most frustrating experiences ever but I now have TailTalk able to directly print to my Colour StyleWriter 2200 with the official EtherTalk adapter, which should also work with the LocalTalk adapters and GreyShare (I think).
Thankfully lpstyl documented most of the interesting parts but oh my is that printer not forgiving in the slightest. It's pretty lazy right now in that it waits for the SW buffer to be drained before sending more data (Same as lpstyl) but after capturing a session from the native Mac OS driver printing images I should be able to replicate the "topping up" buffer behaviour the native one does. I still need to get it a little more stable and get the CMYK conversion in but I hope to have auto discovery and IPP advertisement for this one in the next TailTalk release :)
Looks like everything is working. My Powerbook can see zones and I can assign devices to the configured zones. File transfers route through TashRouter when using two LToUDP-connected peers. I still need to test connection between LtoUDP devices and hardware connecting via ethertalk but otherwise this is performing to spec.
I have a Powermac G4 which is connecting over WiFi via an adapter that plugs into the Ethernet port. As expected since AppleTalk cannot be encapsulated over Wifi, I'm getting errors that the DDP header length is invalid. Those extra characters in the header presumably are due to the ethernet frame being passed via WiFi.
Interestingly, attempting to enumerate connected hosts from a WiFi-connected device crashes all devices on the AppleTalk network.
I am unsure if this behavior is also present when using the TashTalk Hat or is specific to using TashRouter with a TashTalk USB.
