Macintosh IIfx repair
Hi all,
Looking for help narrowing down an issue on a recapped Mac IIfx. Long story short, I think IOP A may be dead, but I'd like a sanity check from people with more knowledge before I go further.
Background:
  • Board was fully recapped (electrolytic → presumably new electrolytics, not tantalum)
  • After the recap, it booted successfully into Mac OS and was usable
  • Sound did not work after the recap (never confirmed working post-recap) but sound worked through the headphone jack
  • Next boot: hung partway through startup
  • Boot after that: degraded to a uniform static screen
  • All recap joints have since been reflowed — no change
Current symptoms (bare-bones config — SCSI and floppy removed, NuBus video card only):
  • Single chime on power-on (confirmed via headphone jack), no second chime, nothing further
  • Steady black/white raster pattern
  • ADB completely dead: caps-lock LED does not respond to keypress
  • PRAM reset (Cmd+Opt+P+R) has no effect
  • This exact video card has previously booted fully to Finder in this exact machine
Questions:
  1. Is "chime fires, ADB completely dead, PRAM reset dead, hangs before video" a known/recognized IOP A failure signature on the IIfx?
  2. For anyone with the schematics (or @TheRealBolle's recreation) open — which net/rail feeds IOP A's local supply, clock, or reset line, so I can probe it directly?
  3. Is IOP A failure something that's been seen as repairable/socketed, or is this generally a "find a working donor board" situation?
Happy to provide more diagnostic data (voltage readings, etc.) if someone can point me to what to check.
Thanks!
So, generally, 99.9% of the time, it is a bad or marginal trace or dry joint somewhere, or PSU issues.
Chips actually fail very infrequently. Often when people repair something by replacing a chip it is really that they have cleaned and resolder as part of putting it in. There are a few exceptions like if there has been a serious issue (lightning) and some components that are known to be unreliable.
The IIfx's memory sockets are very fussy. Pull bank B. Then reseat bank A. If that doesn't work, try it a few more times and swap memory SIMMs. I swear if RAM in bank A does not pass you do not get the chimes of death. It simply does what you experience (power on chime and then nothing).
This is why I like swapping chips between boards, with one being a known working one.. then you can test if the original problem suddenly plagues the previously working system.. it is more work of course.
I agree. For all the Macs I've repaired, I have only experienced two types of chip failure:
1. Chips immersed in capacitor goo. There are sections on the SE/30 and IIci that routinely damage the nearby jelly bean chips.
2. Anything on the Macintosh Portable -- due to a bad power design.
@HomeLate There are two types of IIfx boards: Those with only two surface-mount electrolytics (C9 and C24), and those with many surface mount electrolytics. Not counting the large axial electolytics, how many does your board have? That will help us determine where the damage is.
Also, seriously, check the RAM sockets for corrosion.
See my post here:
"it would chime but not activate the NuBus video card or continue to boot"
@David Cook It's the one with many elektrolytisch unfortunately. I already found some corroded traces near the simm sockets, near C24. My plan is to remove the corrosion and repair if necessary. If that isn't sufficient, I'll remove the simm sockets and check for corrosion. I already removed the simms in bank B and swapped the simms in bank A but the issue remained.
I'll be also checking the area near the ADB ports as the keyboard does not work. Caps-lock does nothing and the PRAM reset procedure also doesn't work.
I've got another:
3. Chips that are physically cracked or have damaged pins by rough handling during re-pasting.
I've seen a few of these over the years.
This is wild, I am currently also looking into an IOP issue on a IIfx that was just working a couple of weeks ago. Caveat -- mine seems to be the SCC IOP, because I get the chimes of death, and the serial diagnostics give me an error of 0012, a SCC IOP failure. I may have to start a new thread on this one. That said, I think an actual IOP failure would give you sad chimes, not a boot chime and nothing.
FWIW, after screwing around with a bunch of caps, I got to a boot chime and nothing, and ended up having to reflow all of my caps due to obviously knocking something loose that shouldn't have. Gave me a chance to fix an earlier recap. Unfortunately, I'm back to chimes of death.
Good luck with the repair of your IIfx. I already found some corroded traces near the simm sockets. These still have continuity but I need to remove the corrosion anyway.
I'm leaving on holiday soon. I'm going to continue working on it when I'm back.
