upgrading the ibook clamshell's L2 cache to 1MB
Don't know what setting I need (ºC?) nor what distance to hold it at.
350° probably - depends a little on what solder and thermal mass you're working with, and start further away and work inwards with time. If you can see the orange of the elements reflected in the solder resist, you're perhaps too close. Put a bit of flux on first, it will mostly flash off, but generally helps getting the solder to flow more easily. Poke the component gently to check if it is free, don't pull / push hard on it when it is not free or you might damage a pad.
Practice on an old VCR board or something first ask neighbours / family/ charity shop if they have any broken electronic devices so you can find something to practice on.
Regarding popcorn, stick it in the oven at about 70°C for 45 minutes before you start if you're worried. Don't burn yourself on it. Generally things are ok if they've been in a heated room / summer.
One thing I've found that really helps is ChipQuik - it's not super cheap but it has a really low melting temp compared to regular solder and for anything thats not a huge chip it makes it really easy to desolder things, often dont even need hot air. I am by no means a hot air rework specialist, so for any chips I've not had handy replacements for I break out that stuff.
Perhaps @herd can give us more information, but I believe these iBooks use a 3.3V cache, which is incompatible with the MPC7410; only the MPC7400 can be used. The MPC7410 can be used if the model doesn't have an L2 cache.
pretty sure the iBook G3's use lower L2 cache voltages, they are Uninorth machines, I have 7410 swapped one in the past without issue, as have a few other folk
@LightBulbFun would it be possible to put the 7400 into an iBook clamshell? or should i go for the 7410
i'd go with the 7410, its a cooler running chip much better suited for a portable, espically if you get one of the MPC7410RX500LE MPC7410's from eBay etc you can run those at 1.8V
what would be a good voltage for 600mhz? do i have to use a custom cooling solution?
if your gunning for 600Mhz you can probably leave the voltage alone I think most of the PPC750L's run at about 2.0V, at least thats what I did with the 600Mhz Pismo I did :)
I imagine you would want some sort of extra cooling, tho I never bothered with mine but i was only running at 450Mhz which seemed to be fine with stock cooling
if your sticking a G4 in there, then you can also upgrade the L2 cache to 2MB, tho that quite likely might need an extra address line wiring in with a jumper wire
i'd probably recommend going for 500Mhz and take the extra power saving with a reduction of core voltage to 1.8V :)
I would love to see what one of @herd's 750/7400/7410 to 7447/7448 interposers could do in one of these macs a 7448 running at nice low voltage and moddest ~1Ghz clock speed would probably work very well I imagine?
hmmm that would be interesting... a 7447B (which is what i've got) ibook clamshell... lol
the hardest part i think is getting the firmware to work with it. that would already be one hell of a performance boost from the G3/400...
also, how would i get my hands on one of the interposers?
Do 7447/8s run boiling hot like 7455s?
I feel like a 7410 would be the absolute perfect sweet spot for a clamshell just based on how cool they run.
No, 7448's especially are quite good power efficient chips, from their datasheets, 15-20W for a 1Ghz 7448 vs 5W-10W for a 500Mhz 7410, so a bit warmer, but nothing like a 7455 or the such like
That’s interesting to know. There were two models of PowerBook G4 that used the 7455 - the 1GHz 17” Aluminium model and the 867/1Ghz TiBook. I wonder how they fared with that monster of a chip.
I'm not likely to ever be in a position to find out first hand, but is it theoretically possible to directly swap the 7455 in one of those with one of the cooler-running chips mentioned above? Even at the same clock speed it'd net you a huge improvement in usability, just from the improved battery life and not cooking the user’s lap.
