I’m looking forward to your solution. Great that you took this on. Just wondering if you two were collaborating.
Thanks! That would have been awesome to collaborate with him. He seems to have a lot of knowledge about the portable compared to me, but unfortunately I don't have a good way to contact him.I’m looking forward to your solution. Great that you took this on. Just wondering if you two were collaborating.
Great! It'll make the adapter PCB and the controller PCB much smaller too! I just wanted to know if it was a good idea.Yes. The flat flex cable is a good idea with a small zif style connector.
Thank you very much for the advice! It's hard to find sound advice, so I just followed the schematic for the Waveshare. Thank you soooooooo much!Off the cuff, some quick thoughts....
Decoupling capacitors must be as close to the RP2350 as possible and wired one per power pin on the chip. That advice goes for all other power pins on other parts too. Oscillator must be as close as possible to the chip and take caution with the grounding of the caps. Use an array of vias instead of one large plated hole under the RP2350. Trace clearance looks somewhat tight, suggest increasing it and using smaller passives to give you more flexibility. I didn't really look at the rest of the design - switching regulator in the corner looks a little odd, especially inductor - or validate the schematic.
My advice: consider using a pico module for v1 as that will eliminate much of the sensitive critical design work. But if you want to do the laid-down RP2350, I would recommend looking at some tested open source designs and borrowing as much as possible of the layout. Also read the design guide provided by Raspberry PI and take it as gospel, they provide a lot of excellent advice in there.
Same here!always frightened of tunnel vision
Not quite sure what you mean by that?Is this for both the M5120 and M5126? Do you still plan on a ribbon cable connector because it looks like you've switched to a flat flex.
I don't have any spare wires in the cable, but i can make a pin header with gpio coming out for brightness modifying. I will do that thank you!2. If you have spare wires in the cable, bring those out to a header (along with +5 and ground) so that we can hack a brightness control via software
M5120 and M5126 are two models of Macintosh portable where the latter is backlit and the former is not.Not quite sure what you mean by that?
Both! I am making an adapter hat that will go to the ribbon with a plug on the end for flat flex that you can buy readily at amazon.Ribbon cable and flat flex
If the pinout is the same then yes.M5120 and M5126 are two models of Macintosh portable where the latter is backlit and the former is not.
