TashTalk USB
Let us know if you do another run. I’d be interested in 2 or 3.
And ditto on gsteemso’s comment. I’m actually a little surprised Joe (the proprietor of jcm-1) didn’t reach out to you before making a clone. He’s normally fairly sensitive to supporting the original author.
I just put an order in today, so should be here a week on Monday most likely. I also had PCBWay reach out to sponsor a run, so I might be able to do some reduced price ones for forum members. Still trying to figure it out with them of course.
I messaged Joe as well and heard back, and I think it was just a misunderstanding thankfully, so no hard feelings.
@Bolacore Trying out the new version of TailTalk, 0.4.2, and indeed, bullet characters are now appearing correctly! However, some other change(s) you've made appear to be causing numerous files/folders, though not all, to appear as individual, unnamed files on the vintage Mac side, hundreds of megs in size. If I try to open Get Info on one of the files, the window quickly closes again and a number of duplicates appear in the window.
(Also, it seems I may have been using a faulty cable initially, as a new one appears to be behaving perfectly!)
Meh, I'll rather spend my pennies on the guy who's actually doing the work before I patronize a “zero-value-added” seller. Seems only fair. Open-source hardware is meant for people to improve on the original, not just to act like concert-ticket scalpers and undercut actual development.
Agreed ten thousand percent!!!
c
Ooo that doesn't look good, sorry about that! Is this only happening in 0.4.3 or what is the first version that you see this in? Could you possibly do a file list of the directory you are serving up as an attachment (Perhaps with this as the command)
Bash:
find /path/to/your/share -exec stat -f "%HT %N" {} \;
If you serve up a brand new empty folder does it also do the same?
Figured out the bullet issue - It helps if I convert back to MacRoman on the reverse direction :) Fix will be in the next release.
Ah, the joys of dealing with pre-Unicode systems and protocols.
I eventually have to get one of these USB adapters. Now that Netatalk 4.5 is out, I'd like to add support to A2SERVER and finally get it out the door.
As the Netatalk maintainer you can have one on the house :) I have relied so much on Netatalk code for understanding how to make AFP work properly and it is the least I can do to say thanks. When the new set comes in I'll put one aside for you, just DM me your shipping info if you're interested.
