Quadra 950 Various Crashes
jmacz
68020
Starting a work thread for debugging multiple issues with my Quadra 950.
State Upon Receipt
I picked this unit up online and it came in a non-working state. The power supply was dead (various issues on both the primary and secondary sides).
ATX Power Supply
Put together an ATX conversion of the PSU using a Corsair HX1200 which drives the right amount of current for the +5V rail for the Q950. This allowed me to boot and things seemed mostly ok. But I would get a very loud speaker pop on cold boot and I would get some odd crashes (illegal instruction, bus error, bad address, question mark icon even with a known good disk, etc).
Loud Speaker Pop
I heard Q950 owner do experience a speaker pop on boot but I didn't think it was supposed to be this loud. I borrowed a friend's stock working Q950 power supply and the pop was there but much quieter. I put both PSUs on a scope and the only difference I could see is that on the stock PSU, the +5V/+12V/-12V rails ramp up at the same time. The ATX PSU however has +12V coming first about 12-14 ms before the +5V/-12V rails. This seemed problematic. ATX power supplies don't have a requirement to bring up the rails at the same time as they utilize a ready signal to the logic board when the rails have stabilized.
Loud Speaker Pop Resolved
I put together a small circuit that gates +12V against the ramp up of the +5V rail. This got all three rails really close during ramp up. With that change, the loud speaker pop was much more muted, like the stock PSU.
OS Crashes
I was hoping the PSU fix would resolve the crashes but it did not. On boot (and sometimes on restarts), I get a lockup shortly after the "Welcome to Macintosh" screen appears. This means that the System file has loaded and the machine is booting. It's not always the same error. Sometimes I get an illegal instruction error, sometimes a bus error, sometimes a bad address error. Sometimes, it stops finding the disk and shows the question mark icon. In these occasions, it looks like the disk image got corrupted and I have to replace it.
Again I borrowed my friend's PSU thinking it was the PSU but I was able to reproduce with the stock PSU as well.
Setup
Q950. System 7.6.1. 128MB of memory. ZuluSCSI for the disk. Machine does have the stock SCSI terminator at the end of the internal SCSI ribbon cable. And I am not using termination on the internal ZuluSCSI.
Debugging Attempted
  • Replaced the memory, didn't help.
  • Cleaned the memory socket, didn't help.
  • Reflowed the memory socket, didn't help.
  • Reflowed the PSU connector, didn't help.
  • Reflowed both SCSI chips, didn't help.
  • Reflowed the internal primary SCSI connector, didn't help.
  • Used my own burned custom ROM, didn't help.
  • Tried both an internal and external ZuluSCSI, didn't help. Issue reproduces on either SCSI chain.
  • Messed with combinations of SCSI termination, didn't help.
  • Tried System 7.5.5 and System 7.6.1, didn't help.
Visual Inspection
Board looks super clean. No corrosion. Chips are clean. No missing components.
Reproduction
The reproduction is not easy. I get the issue about 1 in every 5-10 cold boots. I get it about 1 in every 50 warm restarts. I have never yet hit the issue when no disk is installed - I have so far always made it to the question mark disk screen when there is no disk. That seems to suggest data and address lines from memory/ROM/cpu are ok.
I'm narrowing on the SCSI subsystem. The fact that it happens on both the internal and external means it's most likely not specific to the SCSI chips (there's two). If I am able to get through boot, the system behaves ok after that, no crashes. Even running a few runs of MacTest Pro and MacBench doesn't introduce a crash. It feels like something on boot up, perhaps power related, is inducing the issue which is why I thought it was the PSU but given I can repro on a known working PSU, maybe I have to look at the caps on the logic board.
What I'm currently looking into...
I printed out @Bolle 's Q950 schematic which he put together to design his Q950 reloaded logic board project. There are no electrolytic capacitors on this logic board but I wanted to take a look at the tantalums.
Found something interesting... the stock logic board primarily uses the following tantalum capacitors:
  • 47uF 6.3V - many of them
  • 10uF 16V - many of them
  • 4.7uF 16V - a couple
  • 22uf 16V - a few
  • 2.2uF 25V - a few
  • 1uF 35V - a few
What's interesting is that if I look at the schematics, some of these caps are on the 12V/-12V rails, and of course many are on the 5V rail. From prior discussions, the tantalum capacitors need to be spec'd at twice the voltage rating or risk failing. So basically all of the 47uF capacitors are underrated and a few of the others as well. None of mine have blown... but there's at least one thread on this forum where one of these underrated has blown:
The C26 capacitor that burned out in the thread above is a 10uF 16V capacitor that is on a +12V rail.. the capacitor should have been rated at 25V. We've seen the same issue on IIfx machines that Apple put underrated tantalums on. I should probably replace these tantalums. But given these are underrated on the Q950, I may have to go back and take a look at my Q700 and Q800...
Another thing I need to look at is to check the G2 48MHz clock. I believe this one's used for the SCSI chips and need to check if it's flaky although I wouldn't expect that to manifest as a problem on boots only.
I went through and replaced all the underrated stock tantalums on the logic board. I determined this based on @Bolle's Q950 schematic and looking for what rails they were on. After pulling each one, I tested them on my LCR meter. All of them had a capacitance within spec except one. The C6 capacitor (a 6.3V 47uF) was reading at around 1pF instead of 47uF. This was off the board. Read it multiple times and it consistently read near 1pF. Ouch? It's been replaced with a 25V 47uF part tantalum. Schematic shows it might be a decoupling cap for the egret/cuda.
I've booted the Q950 around a dozen times and no repro yet. But that doesn't say much, I've had sequences where it was behaving properly. Keeping an eye on it with fingers crossed.
Still cannot reproduce the issue. Should have been able to normally by now. Keeping my fingers crossed.
Unfortunately, I deviated from the scientific method this morning (after countless attempts to reproduce). I should have waited for a few more weeks but couldn't resist making some additional changes... added another 128MB of memory and also swapped out the main crystal ... replaced the 66MHz with an 80MHz so it's overclocked to 40MHz now. Still stable.
I actually went through a set of eight 80MHz crystals that I bought off eBay a couple years back and they all didn't work in the Q950. Oscillator showed the signal was not very clean (compared to the stock 66MHz crystal). But none of them worked, machine would not chime at all. I ended up an 80MHz crystal off a parts video card and that actually worked fine.
Ok bummer... it came back.. harder to reproduce now but still there. I have stopped overclocking but doesn't matter. Saw a new symptom as well as the previous ones... this time it gets to the Welcome to Macintosh (the usual dialog box) and there it gets stuck... the color traditional mac icon next to the "Welcome" goes from color to black and white all of a sudden, and then the "Welcome to Macintosh" text keeps blinking, partially rendering, and it's stuck there. Seen this a few times today. Much harder to repro now though...
Also after boot, if I initiate a large bulk copy/delete, or run multiple MacBench runs in a row, I'll see an IO error of some kind.. usually after that the disk image corrupts.
Looks like this is going to get annoying trying to debug :)
My previous note that it happens on both internal and external might have been incorrect. I think I may have seen it on the external after the boot image was already corrupted on the internal. I have been just trying various tests and have been unable to reproduce with a clean image on the external SCSI port. But can reproduce on the internal SCSI.
Other test results:
  • Floppy boot - never has a problem. Boots cleanly every time I have tried but could be due to timing.
  • Swapped SCSI ribbon cables, didn't help.
  • Changed out the main clock oscillator and that didn't help.
  • Thought it might be related to a noisy /REQ line (hoping it was similar to a problem I had on my SE/30) and thus added a pull up 470ohm resistor across TERMPOWER and /REQ, didn't help. Tried adding the termination capacitors as well, also didn't help.
  • Used RAM in bank A only, didn't help.
  • Used RAM in bank B only, didn't help.
  • Used RAM In bank C only, didn't help.
  • Used RAM in bank D only, didn't help.
  • And to be clear from my first post, tried another stock PSU and that didn't help.
I am unable to reproduce the issue via floppy boot and so far have been unsuccessful after many attempts to reproduce via external SCSI port.
I still have some stock tantalums on the SCSI circuit that haven't been replaced so going to try those just to rule them out.
If that doesn't help, then I'm going to replace the internal SCSI chain's SCSI chip. I figured out my spare parts board from a Centris 610 has the same NCR 53C96 chip. I'm going to try swapping it out to see if that does anything.
This sounds a lot like what my Q700 was doing for awhile. Like...almost 100% exactly. Actually the more I really think about it, I think it was exactly the same. And with a ZuluSCSI. Specifically:
And:
Though at times it was probably more like 9 in every 10 cold boots, until it started to behave again.
I never figured out why but I had started to suspect it was the SCSI device causing the problem. Specifically, the ZuluSCSI.
So, I do have good news: it's fixed now.
But...eh...bad news: I never figured out what was wrong with it...it just stopped having this problem. I fiddled, a lot. I can't pinpoint one thing I did.
But what I'd try is removing the ZuluSCSI entirely and replacing it with a different device and see if it works properly.
That's what I thought it was gonna be - it's being a tough! Hang in there.
Haha, thanks.
And:
Interesting.. do you have anything in your ZuluSCSI.ini file?
I have ZuluSCSIs deployed across my fleet. Haven't had an issue in any of the machines including my Quadra 700.
On this Q950, an external ZuluSCSI mini seems to work fine and I have been unable to reproduce on the external port. But on the internal I am having issues and I have tried 3 different ZuluSCSIs (all compact form factor RP2040 versions) and I'm having these issues with all three of them.
I don't currently have another SCSI device to try right now.. my spinning disks are all dead.
I know the internal SCSI bus is different than the external in how it deals with termination. Looking at Bolle's schematics, it certainly looks like termination is on the logic board for the internal bus. The SCSI ribbon that came with this unit had what looks to be a termination block installed at the end of it. And I have termination disabled on my ZuluSCSI. I've tried various combinations of termination but that didn't seem to help.
Haha, thanks.
Have you tried a different internal SCSI cable?
Long shot that I can't see changing anything, but if you suspect there is some borderline compatabililty issue with the ZS and the 950 scsi subsystem, have you tried using the ZS in raw mode instead of images/.ini config?
Hmm, no. I have not. I need to look into that.
One thing that all my ZS systems have in common, the ZS is the either the last or the only device on the chain and I'm using the built in termination...
Yeah, it's the only device in this case. I have tried the built in termination this Q950 seems to be special in its termination requirements. I've tried various flavors.
Oh wow. I’ve managed to save about 7
Lucky... the only drive I have (I guess I could try) is a working miniscribe 20mb. It's in my SE so I guess I could...
