My Mad B&W G3 Setup!
.... I'll give you 1 guess on whether I knew that trick ;-)
By changing the PLL?
Oh gosh! It's just a jumper block!
Code:
(S = Jumper present or "Set", " " = no jumper)
            Multiple     | 4 | 3 | 2 | 1 |
            3x   300 MHz |   | S | S | S |
            3.5x 350 MHz |   |   |   | S |
            4x   400 MHz |   | S |   | S |
            4.5x 450 MHz | S |   |   |   |
            5x   500 MHz |   | S |   |   |
So, upgrading from 350MHz to 400MHz involves adding a jumper at jumper 3. I'm not massively into upgrading the performance of vintage Macs, mostly because I want the experience of the period. But I'm happy to do period-correct, options. Hence, my PB1400cs/117 upgraded to PB1400c/166. So I'd certainly be up for upgrading a 350MHz B&W G3 to 400MHz!
But I wouldn't upgrade a PB1400 to a G3, or a 250MHz PPC603e. I wouldn't upgrade the B&W G3 to 1GHz or swap for a G4 if that was possible.
I wonder if I can just pull out the metal prongs from a jumper I have and insert them into the block?
They're 2mm jumpers. I might have some around if I have a rummage. I know I bought a bag of them at one point.
Hi @Phipli ! I found a 4GB Seagate SCSI HD with quite a few 2mm jumpers and an ST M28F101 -150 which is a 12V Flash with the same pinout and speed!
I think it might be OK to cannibalise it as there's a distinct rattle when I twist it back and forth. It's probably dead.
-cheers from Julz
-cheers from Julz
There are more jumpers here by the look of it :
I recommend using a 512k ROM as I've never had much luck with the modified ROM. If you want it to work first time.
I think you're right! I saw they might be when I posted the photo.
Oh, OK. But how would a 512kB ROM work? This is the ST MF101.
I can see a spare pin (pin 30) for A17, but not one for A18, unless VPP is reappropriated and it's 5V only. Hmmm, close guess by me. This is the AMD 29F040:
It's the same except Pin 1 is A18 and Pin 30 is A17 and it's 5V only. Does the PCI board try to use Pin 1 as an address pin then?
Amazing levels of ignorance on my part, despite having programmed these things (I have a few SST 256kB Flash chips, but they're DIPs).
-cheers from Julz
