Hello together,
I have an issue getting network on my SE30 with Mac OS 8.1. It has the Asanté MacCon SE30E network card in it with driver version 5.6.1 installed.
I connected it to my router using an AUI to RJ45 10BASE-T transceiver (Allied Telesyn AT-210TS). The link LED turns on but there’s no network. I’m not getting any DHCP. I also tried setting the IP manually in the TCP/IP control panel, but i still can’t ping the SE30.
After that i tried to connect it directly to my laptop. I manually assigned IPs from the same subnet on both ends (laptop and SE30) but i still can’t ping the SE30. The link negotiation seems to work, it shows a negotiated 10 MBit/s in the network adapter properties.
As I don’t know further has anybody an idea what’s going wrong here? Is the MacCon even compatible with MacOS 8.1?
