Personally I prefer the AEKII.. but maybe that's just because that's what I was used to back in the day. Also I quite liked the butterfly switch keyboard on my 12" MacBook so perhaps I'm not the best judge of keyboards.
An AEK parked in front of an SE/30 is a beautiful sight indeed. Like a Mini Cooper body on a GMC Jimmy frame, there’s no kill like overkill.
I love pairing my AEK with my desktop-bound MBP via a drakware ADB dongle - deliciously anachronistic
-PAGE BREAK-
AEK PROS & CONS
PROS:
Just the right shade of silver-beige
Key switches go “clicky-slap” in a satisfying way when you’re really cookin’
Fixed at a most agreeable angle for my middle-aged wrists
ADB ports are clocked properly (imho) so that the square part faces away from the user (comports favorably with my particular flavor of OCD)
“undo cut copy paste” markings under the F1-F4 keys is a soothing reminder of simpler times, like a comfort blanket or a faded window sticker on a vintage car
Apple logo in bottom-left corner just looks right
The original AEK, so extra street cred
CONS:
Caps Lock key is too sensitive
You know what I mean - sometimes the key cap doesn’t stay down when you hit Caps Lock and so it’ll be in Caps Lock with the Caps Lock light on but the key will still be “up” and so you gotta tap it super quick to get it right or else your aforementioned OCD will eat you from the inside out
Barely a CON but I had to put something here
-PAGE BREAK-
AEK II PROS & CONS
PROS:
Adjustable height, if you’re into that sort of thing
Two of the three versions have really nice key switches
I like the shape of the AEK II’s Power key more than the AEK’s
CONS:
Bunko height-adjustment mechanism loves to collapse at random intervals
ADB ports face the wrong way (according to me)
Apple logo placed way up at the tippy top in an awkward spot that fees like an after thought
Fails to “tie” the proverbial “room” metaphorically “together”
Feels ~10% flimsier than the AEK
-ONE MORE-
ADK PROS & CONS
NEITHER PRO NOR CON:
Permanently attached ADB cord
Sorta goes hand in hand with having only one ADB port but really doesn’t matter
Feet up or feet down, doesn’t matter, angle is the textbook example of MID
Look up “mid” in the dictionary and you’ll see a halftone illustration of an ADK in both positions
Right below that, by definition #2, you’ll see a halftone illustration of an ADK key switch, followed by “see also: mushy, flavorless, dead”
Apple logo is embossed and not a sweet li’l enamel six color Apple LIKE GOD INTENDED but not a total deal breaker
