PowerBook DUO 230 No backlight
Hi guys,
I have an issue with the backlight on a PowerBook Duo 230. The machine works perfectly, it boots up and works with the dock station, but the internal display has no backlight. The image is there, but there’s no illumination. I tested the display with another motherboard and the screen works fine.
So the problem is definitely on the motherboard. What do you think it could be? I tried something that you really shouldn’t do because it risks causing damage, connecting the display flat cable while the machine was powered on, and when I did that, the screen lit up. It seems like something related to the backlight control logic or brightness control. Of course, I can’t find any schematics…
Check for bent pin if applicable in the connection. Try doing a fresh install of an os via the dock. Definitely recap the logic board if not done.
The motherboard’s been recapped, of course.
I’ve got another donor board for spare parts, so I swapped out U17, U9, and a bunch of other 9953s around the board. The weird thing is that if I plug in the flat cable while it’s powered on, the backlight comes on, which makes me think it’s some kind of logic issue, but I’ve got no clue what’s actually causing it. Without schematics, it’s pretty hard to figure out how to fix it.
@ThisDoesNotCompute has the PenLite/210/230 schematics!
As shown off in his video here
I hope he does the community a solid and releases these! Just think of all the machines this could help!
Yes, I’m familiar with this video, great project. The page shown refers to the rear connector, and I don’t think it can help with this specific issue. It would be useful to have the complete schematics, even though the PenLite motherboard is very similar, but not identical.
Has anyone dumped the PenLite hard disk image? I remember hearing a couple years ago that none of the few PenLite owners were interested in backing that up publicly. If they're hoarding that, it doesn't surprise me that they're hoarding the schematics too. I doubt Colin got the schematics without being told he was not allowed to release them, or he would have by now.
