New (FOR ME) Beige G3 Questions! (regarding USB and FireWire PCI Cards and CPUs)
Alright! So I got my Beige G3 Desktop up and running. Got it connected to the internet, loaded Classilla, found my old QuickTime Pro S/N, and have begun installing all the apps I wanted to make this a near perfect publishing/bridge machine. I also installed USB and FireWire PCI Cards salvaged from another Beige G3 (although that one was a tower). However, the USB card isn't recognizing a Flash Drive when inserted. I haven't tried the FireWire yet. My guess is that this is a driver issue.
The cards are being recognized in Apple System Profiler (ASP to save on typing), but that's it.
The USB is a pci 1045,c861 (rev. 1045) and the Firewire is a pci 106b,1a (rev. 104C) according to the ASP.
Any idea where I can get the software to make these work? Or is there some other issue I'm not aware of?
Also, what are the part numbers for G3 Processor cards? Where do I find them on the Card itself? How do I know what the max clock is? And what risks are there in overclocking?
I have two Motherboards and thus two CPU cards. I tried swapping, but saw no improvement in clock speeds in the ASP. I've since learned that I need to alter the configuration jumpers to do that, but don't want to risk it until I know what cards I have and what they were designed/intended to run at.
The USB PCI card drivers don't go in by default in all situations. Re run the OS installer and either select everything with USB in the name, or make sure you pick "USB Adapter Support".
It's a really, really, common issue.
What the CPU is rated to is written on the sticker and on the CPU itself (but the latter is usually hidden by the spacer). But this doesn't mean the most it will do. Most chips will exceed their rating by at least 20%, but at your own risk and all that. Really, if you don't misconfigure anything, the only risks are an unstable machine (give yourself Headroom for hot weather or heavy loads). Technically overclocking shortens the life of the CPU, but at this point, assuming you're not planning to run it all day every day, this is unlikely to be the first thing to fail.
It will also use a little more power and make a bit more heat. And void your warranty :LOL:
Thank you! But… now I've run into another issue. The system won't fully boot if the FireWire extensions are installed. It just locks up mid boot (after the background pattern but before the extension icons). Attempting to boot from the 9.1 CD has the same result. I had to use an 8.5 CD and then manually delete the extensions to get it to fully boot to 9.1 from the HD.
The good news is that the USB is working now! Thanks again for that. Although, I've come to discover that if I want the computer to recognize Mac files as Mac files, I have to format the Flash Drive in OS9 on the G3 (MacOS Extended Journaled) first, as the standard DOS format seems to cause issues. But I'm guessing that's just a quirk of the OS.
Suffice it to say, I've had this machine a while, so I installed the OS prior to the cards. Given that these did come from another Beige G3, I have to assume there's a patched FireWire driver that will work, right?
Perfect! Then if I'm reading this sticker right, I have a 300Mhz Processor to install!
That... Sounds like a more serious issue. FireWire usually Just Works, and is very reliable. I'd try another card to be honest, or at least reseat the one you have.
Classic Mac files have two components, a data fork and a resource fork. The former is arbitrary binary data, the latter is more like a structured database. PCs don't support the resource fork and if you put most (not all) Mac files on a PC formatted disk without taking appropriate precautions (such as putting it in a .bin or .hqx or even a .sit with caveats), it strips out the resources. Which is unfortunate given most Mac files and applications store almost all of their content there.
There is something not right going on with your FireWire - I've never had a FireWire card cause any issues like this. The usual FireWire issue is that it gives absolutely no clue that it is working until you plug in a disk and it appears on the desktop, so people think it isn't working because it doesn't appear as an available bus in System Profiler.
That's correct - that is a 300MHz - it will almost certainly happily run at 333MHz.
Yep! The card's bad. Tried reseating it, but ended up with the same issue. Sadly, I don't have another, but FireWire was just a would-be-nice for me. What I'll really be on the hunt for is a VGA card (probably the same kind that's in a Blue and White). For now, I'll just leave it to plug the hole in the back. I'll see what my local recycler has on Friday.
Yes it did, but I'm happy at 300. I don't think the extra 33MHz will make much of a difference, and I don't want to press my luck with some of the more processor intensive tasks I might try. My plan is to play with all the graphics/publishing software I've accumulated over the years. Photoshop, Illustrator, Freehand (never tried that one before)… I even found a copy of Corel Draw 8, which I'm hoping will prove more stable than 10 ever did.
In terms of bridging, USB is all I really need. Well that and a working floppy drive! Fortunately, my drive is good, So transferring files, making disks, I finally got something that can do it! The only thing I haven't figured out is file sharing. I'm guessing that OS 9 might not be up to the current standards to play nice with my current MacBook. Still, it's a minor issue.
Eventually, I might even look into some simple animation. I know there are better (newer) computers for the task, but where's the fun in that?
If you have the logic board the 300MHz chip is out of, they sometimes have a better video chip than the one on the lower speed machines. It will have "Pro" or "Turbo" in some mix written on the chip. The better chip is the first one apple supplied that supports OpenGL, although not much will run with the minimum VRAM. Many of those machines came with an extra 2MB of VRAM in the expansion slot though. If you're lucky you can find up to 4MB cards for them giving a total of 6MB.
Keep in mind Ethernet is a lot faster than USB.
They can both talk FTP or SMB with the right software. Need to be careful with resource forks again.
Macromedia Director is probably what you want, version 6 perhaps? Obviously there are lots of supported versions, but 6 is nicely "old" but usable.
