TOPS FlashBox information
I meant about running an AppleShare server with only System 6 machines to do any AFP. I am not sure what to make of that TOPS 2.0 on garden, if that's not a AFP but something custom? If I read it right, perhaps it should work as a file share between the machines, I might need to give it a go.
Anyway I finally figured out how to set up the AppleShare File Server on my SE. Then I first tested with a simple pair of PhoneNet adapters and I was able to access the share on my LC, great. I had not much files on the machines (as I had just set them up with System 6) but I had Lode Runner and Tetris Max there (as one should) so I used those as a benchmark.
First with just PhoneNet adapters over RJ11 cable: copying Lode Runner and Tetris Max over was about 1min 31sec - 1min 34sec (run twice).
Then I plugged in the FlashBoxes to the same ports, and then the PhoneNet adapters to the FlashBoxes and set the FlashTalk active in the Network panel on both machines. Rebooted and the FlashTalk icon shows up in the bottom-left corner of screen. Testing again, and I was able to connect to the File Server just like before. So the FlashBoxes were working (or at least passing normal LocalTalk thru succesfully).
I run the same test over the FlashBox + PhoneNet adapters: copying Lode Runner and Tetris Max over took only 1min - 1min 2sec (run twice).
Also I copied over the whole LC's boot drive (2,8MB) and it took just 2min 18sec.
So yes, the FlashBoxes work, and it has at least a measurable speed boost to the LocalTalk traffic :geek: Setting up the boxes with their own power supplies and the very short pigtail cables (the computer port on the FlashBox is not a Mac serial port) was not too tidy (over the simplicity of having just a PhoneNet dongles) and I can kinda see why this would've been a pretty niche market for this type of adapters.
TOPS/2.0 isn't custom so much as it was a commercial product to transfer files across different systems, such as PC-DOS, VAX/VMS hardware or whatever else they made stuff for. You'll probably run into a snag because at least for Version 3, you need a different key file for each machine.
Your transfer times seem about right. LocalTalk tops out a 230.400 bps, in practice most machines max out at 20KiB/sec or 10KiB/sec depending on how slow they are. Really slow computers like the 512K are about 7.5KiB/sec.
The COMPUTER labeled port on the FlashBox is just a Mini-DIN-6 PS/2 style connector which allows it to use either DE-9 or Mini-DIN-8 connectors depending on which machine you had, as the 512K and 512Ke used the DE-9 serial port. Mac Plus and up used the Mini-DIN-8 interface connector.
I don't have an oscilloscope to test, but I wonder if the FlashBox uses the HSKo at all. If it just uses RXD+/- and TXD +/- then yeah a normal PhoneNET cable wouldn't lead to any speed changes.
Hi MindWalker,
I'm at the point to build my homebrew version of faster LocalTalk by using an external clock.
I'm currently blocked at how to select the external clock, I made as small program but seems some driver is changing it also in the background.
How did your machine feel like speed reduction during transfers ? I have a collection from SE/40, LC, up to beige 266.
Hi Mk.558,
If TOPS is using an 6.144 clock, double that of the internal 3.68, I would also expect a speed increase of 60 to 80%, not 30%.
Seems like the CPU is not fast enough to provide data ?
You need to make sure that your app or driver becomes the owner of the serial port so that others don't mess with your settings. I don't know if just opening the driver is sufficient.
Go here and search for SerialDriverArbitration
https://developer.apple.com/library/archive/navigation/#section=Platforms&topic=macOS
Where does the 6.144 number from?
If an external clock is used then you can use the x1 mode instead x16 mode (3686.4 / 16 = 230.4 kbps)
6.144 Mbps is probably too fast though.
https://68kmla.org/bb/threads/apple-localtalk-interface-box.51731/post-584229
Hi,
I did a draft reverse engineering of the schematics based on the photo's and found some interesting things :
1. Of the differential transceiver SN75176 only the receive part is used, the transmitter is continues disabled (pin 3 to GND).
This means the data is coming directly out of the MAC without any change to it.
2. The 6.144 MHz clock in going into the PAL on pin1 , I think it's then divided by 4 (for FM0 decoding ?) giving 768k bit / sec !
3. Of the PAL only two outputs pins are used = P13, going to the MAC ? And pin 12 for the LED.
4. PAL inputs 4 is used to detect data passing by.
Some questions that I can't check by the photo's :
- Is the switch between 230k and 768k done automatically or can you set it on you MAC by SW ?
The PAL would be able to detect the data speed coming from the network and adjust the external clock accordingly.
- So the 6 pin mini DIN is connected to the MAC (got me confused at first), I expect it's a 1 on 1 cable ?
Any possibility you could check this please ?
If it is an 1 on 1 cable, then pin 1 is connected to pin 2, meaning HSKO connected to HSKI, so no external clock used ...
Or if not then a higher clock is supplied to the MAC from output 13 of the PAL, what would make sense.
When you write MAC in all caps while discussing low-level components, I keep thinking you mean a Media Access Controller chip or similar, but from context you appear to be talking about the Macintosh as a whole? That’s needlessly unclear.
