consider investing in an EPROM eraser too!
I went with the GQ-4X4 from MCUMall. Also with the appropriate adapter and UV eraser. I'll report back on how that bundle works.consider investing in an EPROM eraser too!
I am wondering if these are tied to additional address lines, and if so, perhaps I could expand the ROM to 4MB with room for a built-in ROM Disk.
Looks like I've identified my MARCHintosh project for this year!They are. They go to A20 and A21. I haven't tried it myself, but it should work. I'm not sure if you would need to do any MMU reconfig like what was required for the Quadras, but it should be possible to get 4 MB of ROM in the LC III.
If it works, I may do this for my overclocked LC IIILooks like I've identified my MARCHintosh project for this year!
Nicely done! I have to buy those chips and a programmer once you get 1.1 going. And is that an 8MB memory mod I see on your LC III? I plan to do that and the "evil RAS" mod so I can truly max out my LC IIILCIII ROM patched and 3MB ROM disk embedded. Happy MARCHintosh! I know, a bit late.... I would have made it in time, but I got a batch of really bad M27C160s from China. So I scrapped them and had to buy and then wait for a new batch.
- Two M27C160 EPROMs: 1024K x 16 = 2MB each (4MB total). ROM = 1MB, DISK = 3MB. 42-pin EPROMs to take advantage of all address lines.
- Patched the Sonora tables to support a 4MB ROM in 32-bit mode (thanks @dougg3 for pointing me towards Sonora). I was able to boot to R in both 24-bit and 32-bit mode, but I don't trust the 24-bit option quite yet.
- Using an older version of my driver, what I call v0.90. This pre-dates the usage of the splash screen as I didn't want to test toolbox routines until I knew that this was working.
- Other ROM patches include: Disable RAM test, disable ROM checksum, usual changes to auto-open and optionally boot from ROMDISK driver. Used free resource at offset 60080 for this driver.
- Included ZIP file has the Big Endian HI and LO files ready for programming. Again be advised that I haven't done a lot of testing quite yet, especially as it pertains to 24-bit mode. In time I will run in the much more current v1.1 driver I am about done with. This includes full support for FC8, including caching the FC8b for faster access.
View attachment 97290View attachment 97291View attachment 97292View attachment 97293
That is a really strong theory. I've started doing image searches to see if I can find an example of a board with a populated J11.I'd bet money that unpopulated connector J11 has something to do with in-system programming of the ROM.
YesImpressive! 500 series next?
Not an 8MB mod, but actually a trace fix. I bought this LCIII from @jmacz. He has a really detailed thread showing how he resurrected this machine from a really bad battery bomb. So it is sort of fun to see this machine move into new ROM space instead of the dumpsterAnd is that an 8MB memory mod I see on your LC III?
