Sector - HFS Disk Image Creator & Editor for modern macOS
davecom
Hi All,
I released a new little Mac app called Sector for creating and editing HFS disk images on modern macOS (11.5+). This is to make it easier to work with disk images on your modern Mac for emulators like mini vMac and Basilisk II, or virtual disk devices like Blue SCSI, Zulu SCSI, and Floppy Emu.
You can learn more about it here:
And here are five promo codes for a free copy on the Mac App Store for this great community:
JH94R9EXFKYT
3A4K6P6LT7RE
YELYWW3JENTY
AYTRRF9YRKW3
4RFYMYA79Y9P
Please make sure to backup any disk images with valuable data before editing them with Sector. Sector comes with no guarantee that a bug won't hurt your data! Any edits you make to disk image with Sector are irreversible.
Neat! A GUI for hfsutils is quite handy and HFVExplorer only works on Windows. Does this support both unpartitioned (emulator) and partitioned disks?
Building in pdisk as well to allow for advanced partitioning would really be a killer app for a drag-and-drop tool for ease of use.
It's great this is open source, might I suggest a repo link on the website? Sometimes you've got to make a buck and I think source-without-binaries is a reasonable line, but it might encourage more contributions if it's less buried :).
Thanks for the feedback.
It will detect if a disk image has more than one HFS partition and let you select between them. If a disk image has multiple partitions but only one is HFS it will automatically just open the HFS partition.
Note that it is not compatible/safe to use with disks that have HFS+ partitions.
Looking forward to trying this out and finding out more about it!
Thank you so much for making this available, and also for the additional HFS+ warning.
Set Blessed Folder​
More than one System Folder on your bootable disk image? Sector can change which one is “blessed” or the one to boot of of. Note that Sector cannot create bootable disk images, only edit them.
I'm curious about this: Disk Jockey can create bootable disk images, but can't edit the boot partition.
Any plans to do what Disk Jockey does and create driver/boot partitions as well?
For now, no unfortunately. I believe making it bootable would require creating a special partition for the Apple SCSI disk driver and including it in the partition and I don't know the legality around that (distributing Apple's disk drivers). So, not something on the road map for now.
Here's what you can do with Sector though. In the Finder, take an existing bootable disk image, make a copy of it. Open it with Sector (Sector will not hurt its boot-ability), then add System Folder(s) and set the one that you want blessed. But it does mean you need at least one bootable image as a starting "graft."
Interesting; I've done a bit of searching, and it looks like everyone has kept their drivers proprietary. So the best solution appears to be something along the lines of grabbing the driver included with System 7.5.3 redistributable images and creating a new disk image containing that driver partition and an empty HFS partition. A bit of an annoying hack, and there's no guarantee the driver will work with older/newer OS versions.
Maybe the ability to select an existing image to copy its driver partition and create a new HFS partition would work?
It almost certainly will work across OS. The caveats have generally been: sometimes a newer OS needs a newer driver, sometimes a newer device needs a newer driver, always be mindful of the 4.3 boundary. There's a doc out there somewhere with the recommended drivers for different machines, but it's never seemed to matter much for me if I follow the rules above.
I like the idea of "download a licensed redistributable like an updater and pull it from there". If you simply block copy the contents of the partitions it should work fine.
Thanks these are helpful ideas. I will need to read the license of the free redistributables and see if it is allowed to copy only parts of the redistributable. Many corporate licenses insist that redistribution be done in the same manner as the original distribution (i.e. you can't shave off pieces and redistribute those pieces like one driver partition).
There's now a 1.0.1 update live on the Mac App Store that fixes several critical bugs. So if you gave it a chance and had an issue, please try it again.
Exactly what i was looking for. Top work!
Thanks @samovog
A small 1.0.2 update is out with some user suggested improvements:
- A contextual menu for common actions on files/folders
- Drag to open disk images on the app icon
- A different icon to distinguish apps from documents
1.0.3 is out today on the Mac App Store.
It fixes a bug when exporting (and/or reimporting) folders of content in auto mode. The .bin extension was not automatically being added to files with resource forks when a whole folder was exported and the files in it were converted to MacBinary. They were converted to MacBinary but without the extension. The program then in auto mode did not upon re-import see them as MacBinary so was pulling them raw. Sorry, my bad. This is fixed now. Auto mode is tricky!
You can get explicit behavior by selecting MacBinary as the transfer mode if you just want to do everything in MacBinary.
This version also adds double-click to expand/collapse folders or export a single file.
Been giving this a spin! It is handy to be able to just peer into HFS volumes.
Just a couple of notes:
  • Would be nice if it was possible to open locked images. I'm in the habit of making disk images I don't want any utility to modify (and/or that I want emulators to mount as read-only) "Locked" in the Finder. Sector currently refuses to open these images with "Failed to open volume - Operation not permitted - error opening medium".
  • On the side bar, there's just timestamps for the Modified and Backup volume timestamps. Could we have Created as well?
  • Again in the volume side bar, I believe Backup is incorrect, it displats 31 Dec 1903 at 22:23 for pretty much all images I have. The "HFS Check and Repair" option in the menu for the same volume correctly spits out drVolBkUp = (Never).
And one that is less of a note, but more of a wishlist:
In Big Sur, MacOS removed not only support, but all knowledge of what a Disk Copy NDIF image looks like. It'd be pretty nifty if you could add support for detecting and opening NDIF images too. NDIF read-only uncompressed images are particularly troublesome, because if you look at the data fork of the file, it just looks like a plain raw image, but in fact has chunks that only contain zeroes omitted, with the map of these chunks stored in the resource fork. The ndif2raw project seems to be pretty much the only way to extract these in modern platforms, and it's BSD 3-clause licensed so you'd be able to use that in Sector if you wished.
Thanks for pointing out these issues. I will look into the created timestamp and what is going on with the backup timestamp. Those should be pretty easy to sort out.
I never actually use locked files myself. I will try it out.
The NDIF thing—honestly that sounds like something more involved than I want to get into right now but I'll keep it on the wish list for the future.
Yeah, totally fair! ndif2raw works fine, to be honest.
The biggest thing for me would be the inability to open locked files, to be honest. Once I have a "good" image, I lock it immediately to make sure nothing touches it by accident.
