I'd read that the A/UX 3 installer can't be run under qemu due to the lack of floppy support, or under shoebill due to kernel-direct boot. This isn't true for qemu at least but I've never seen instructions anywhere, so in case anyone cares...
The A/UX installer ships as a floppy, but it's just a bootable classic system and doesn't care what media it's running from. To get from zero to a properly installed A/UX 3 under qemu is actually really easy.
As for Shoebill, it should work but I can't for the life of me work out what I'm doing wrong.
The A/UX installer is just a plain old normal A/UX hybrid app running under startmac, so of course we can run it. But how? What's the difference between the loader on the installer disk and the loader in a normal installed mac boot partition? A couple of things, but in the end the installer sets
If you look at the installer CD partition table there's all the normal APM junk, and 3 A/UX specific partitions. There's Root & Usr slice 0, which is the one you boot into if you use the CD as a bootable disk. There's a swap slice (strange since it's not like you're going to swap off a cdrom but I guess the kernel gets all sad if no swap slice exists). And there's a mysterious Free Unix slice 6 that's even bigger than slice 0. Mount it, and it's another A/UX root filesystem with an ARCHIVES directory holding the install packages, and a
Shoebill unconditionally loads the kernel from and sets
- Grab
Apple-Legacy-Nov_1999.isoandAPPLE_AUX_3.1.0_FILE_SERVER_WGS95.ISO - Create a 1GB disk image (luxury!)
- Boot qemu with your disk image at scsi 0 and
Apple-Legacy-Nov_1999.isoat scsi 1 - Launch
Legacy Recovery>Disk Utilities>Formatting Software>Drive Setup 1.7.3 - Initialise your empty 1GB disk at scsi 0, just accept all the defaults and you'll get a 1GB empty disk called
untitled - Go to
Legacy Recovery>A/UX>AWS 95 Boot Disks 1.1and openInstallation Boot Disk 1.1.imgto mount it - Drag the contents of
Installation Boot Diskover intountitled. You now have a bootable A/UX installer at scsi 0 - Shut down the VM, and replace
Apple-Legacy-Nov_1999.isowithAPPLE_AUX_3.1.0_FILE_SERVER_WGS95.ISOat scsi 1 - Boot, and you're in the installer. Easy Install works fine, or custom install and go wild. Note that this will overwrite the (now no longer needed) installer launcher.
- Be aware that reboots from A/UX don't work in qemu, so when it tries to reboot after the installer completes wait for the chime and just kill qemu.
- Launch again, let the first boot do a kernel reconfigure and once again reboot.
- You're in your newly-installed A/UX 3.1. Time to install the 3.1.1 tuneup! (handily included in the legacy recovery CD)
throttling.iops-total=100 to the cdrom -drive option to make the emulated cdrom suck really hard.As for Shoebill, it should work but I can't for the life of me work out what I'm doing wrong.
root_partition to 6, while the normal boot sets root_partition to 0. What's root_partition? It's a field in struct kernel_info, which is where the loader passes the kernel the info it needs to bring the system up. Scsi controller and id, location of text/data/bss in physical RAM, where to swap. And root_partition, the slice number to use for root. If you look at the installer CD partition table there's all the normal APM junk, and 3 A/UX specific partitions. There's Root & Usr slice 0, which is the one you boot into if you use the CD as a bootable disk. There's a swap slice (strange since it's not like you're going to swap off a cdrom but I guess the kernel gets all sad if no swap slice exists). And there's a mysterious Free Unix slice 6 that's even bigger than slice 0. Mount it, and it's another A/UX root filesystem with an ARCHIVES directory holding the install packages, and a
/mac/sys/InstallFolder/AUXInstaller that is indeed the installer.Shoebill unconditionally loads the kernel from and sets
root_partition to 0... So we just need to load our kernel from slice 6 instead, set root_partition to 6, and job done we can do a proper A/UX install under shoebill, right? Yeah in theory but when I patch shoebill to do that it still roots from the usual Root & Usr slice 0. Weird, I guess I'm missing something but I'm not sure what.
