Hi all,
I've got a Performa 6200 where the keyboard power-on button works perfectly every time — Mac chimes and boots to the desktop. But once booted, there's zero response from keyboard or mouse. No key presses, no mouse movement. It was working perfectly for months since I replaced the power supply.
I've tried multiple known-working ADB keyboards and mice, same result. Pressed the reset button, pulled and removed/reconnected the battery (a new one soldered to the original header), no change. Board looks clean with no visible cap leakage or corrosion.
Multimeter readings on the ADB port while powered on and booted:
Few shots included, can't see any caps that look bad, none have been replaced as far as I know.
- GND to +5V pin: 4.9V
- GND to DATA pin: 4.9V
