ATI Radeon 9250 PCI cards, converting from 64-bit to 128-bit and other details
obsolete
I wanted to play with some of the last/fastest classic Mac OS-compatible PCI video cards, so I managed to find a pair of Radeon 9250s. I feel like these used to be plentiful and cheap, but they seem to have gotten much rarer and more expensive. Of course, because I'm looking for projects, I only buy the cheapest I can find. I was lucky enough to get two different 128MB 64-bit cards for ~$50 each.
Card #1 is the black Sapphire board, which is referred to as the ATI reference design on The Mac Elite and elsewhere.
It came with 5ns Winbond RAM, good for 200MHz. This one needed two strap resistors moved on the back, which The Mac Elite 9250 Trick page has a helpful diagram of. Annoyingly, there are no silkscreened component labels on this PCBA. I moved the resistors, upgraded the ROM chip to 128KB, and flashed the modified v127 firmware from The Mac Elite, which resulted in a card that worked but only reported 64MB VRAM. Apparently this firmware is configured for half the memory density of this card.
Card #2 is a red Mad Dog board. It's got a different layout and BOM vs. the reference board, and needs no resistor changes.
It came with 4ns Samsung RAM, good for 250MHz. I did the same ROM chip swap and firmware flash as the first card and got the same results, a working card with 64MB of its 128MB VRAM reporting for duty.
I had a scrap AGP 9200 with compatible RAM on hand, so I decided to try using its chips to upgrade the Mad Dog card from 64-bit to 128-bit; 4 chips to 8 chips, but half the density, so still 128MB. The replacement RAM is 5ns instead of 4ns, but I'm not trying to set any benchmark records here, so it'll be fine. I'm sure that doubling the bus width more than makes up for the clock speed difference. This upgrade was tempting to try because all of the supporting passive components for the extra 4 RAM chips were already on the Mad Dog board; all I needed to do was swap the RAM. I preheated the board for a few hours to drive out any residual moisture, removed the original 4 chips with hot air, then drag-soldered the 8 chips I had salvaged from the scrap board in place. With no other changes, the result was...still a card that reported 64MB of VRAM. I believed my soldering was good, so I suspected the firmware. I took a look at the other available options, and found that despite being labeled as Radeon 9200, the original v201 firmware at The Mac Elite has a device ID of 0x5960, which is the same as the 9250 cards. I flashed that one, and magically I had my full 128MB of VRAM. Apparently the modified v127 firmware on The Mac Elite is hardcoded for 64MB and 64-bit. I'll have to try taking a look at v127 vs. v201 someday to see whether I can figure out which bits control this.
The upgraded Mad Dog looks like this now:
As you can see, I also replaced its old Ketuo branded caps with Nichicon SMT electrolytics.
Energized by my success with the Mad Dog 9250, I looked through my scrap box again and found a broken Geforce 6600 (chipped die) with 256MB of compatible RAM. I decided to use it to upgrade the Sapphire card from 64-bit to 128-bit. This is more of a challenge because the Sapphire is also missing all of the passives surrounding the unpopulated RAM chips. I found two resources that allowed me to easily overcome this. First, there are some 9200 schematics posted at VOGONS. Second, this Gigabyte 9250 AGP on The Retro Web has the same component layout around the RAM, and nice high-resolution photos with reference designators that match the R9200_V101 schematic. Armed with this info, I was able to compile the following parts list:
QuantityValueSizeRefDesDigi-Key
210 nF0805C878, C879https://www.digikey.com/en/products/detail/samsung-electro-mechanics/CL21B103KBANNNC/3886673
1256 ohm0603R875, R876, R877, R878, R879, R880, R881, R882, R897, R898, R899, R900https://www.digikey.com/en/products/detail/yageo/RC0603FR-1356RL/14008360
85.1k ohm0603R64, R65, R66, R67, R72, R73, R74, R75https://www.digikey.com/en/products/detail/yageo/RC0603FR-135K1L/14008317
1256 ohm x 41206RP167, RP168, RP169, RP170, RP171, RP172, RP173, RP174, RP175, RP176, RP177, RP178, RP179, RP180, RP181, RP182https://www.digikey.com/en/products/detail/yageo/YC164-FR-0756RL/5952757
50 ohm x 41206RP187, RP188, RP189, RP190, RP192n/a
80 ohm0603R859, R860, R861, R862, R863, R864, R865, R866n/a
33100 nF0603C81, C82, C225, C226, C227, C228, C240, C241, C242, C244, C419, C421, C567, C568, C582, C583, C584, C585, C586, C587, C588, C589, C590, C591, C602, C604, C605, C606, C607, C608, C609, C610, C611https://www.digikey.com/en/products/detail/samsung-electro-mechanics/CL10B104KB8NNWC/3887593
No Digi-Key links for the 0-ohm resistors or resistor packs because I had enough on hand and was able to salvage from the scrap AGP 9200 respectively.
The unfinished Sapphire card looks like this at the moment:
As you can see, I also replaced its old G-Luxon and Teapo branded caps with some lovely dark brown Nichicons. I thought about removing its 4 original Winbond RAM chips so I would have 8 matching Elixir chips, but that just feels like unnecessary work. I don't need to make it look like it came from the factory as 128-bit 256MB. Besides, now this card will be unique, half Winbond and half Elixir. It's for my own use anyway, so who cares?
I checked the Winbond W9425G6EH and Elixir N2DS25616CT (which is Nanya, TIL) datasheets just to make sure there weren't any obvious incompatibilities. I found that Winbond specifies 2.5V +/- 0.2V for DDR400 (200MHz) but Nanya/Elixir wants 2.6V +/- 0.1V to run at that speed. It would probably be fine regardless, but I wanted to check just in case the regulator setting should be changed.
Here's the +MVDDQ/VDDR1 regulator from the 9200 schematic:
The 431L here is a version of the ubiquitous TLV431 shunt regulator. My Sapphire card has 1.1k and 1k resistors at R279/Rq1 and R283/Rq2 respectively. I was having trouble wrapping my mind around the output voltage programming formula in the datasheet, so I just threw together an LTSpice model:
Yep, 2.6V, should be good to go. The schematic values, 4.75k and 4.32k, also result in 2.6V output. I'll try to remember to measure on the card once I have it fully assembled.
There's an error in my table above that I wish I could correct; 16 (4 x 4) of the 56-ohm resistor packs are required, not 12. Not sure how I screwed up such basic math, must have been up late that night. Anyway, thinking I needed 12, I ordered 15 from Digi-Key, meaning I was one short. I angrily searched my scrap boards and found one near the RAM slots on a Socket 478 motherboard (makes sense, it uses DDR1 SDRAM too). I stole it and the card is finished. Bonus points if you can spot it.
The card works well. It immediately showed up as 128MB, 128-bit with the v127 ROM, which was a bit confusing based on my experience with the Mad Dog card above. I don't fully understand how the ROM and hardware work together to determine the memory size and bus width on these cards. I flashed the v201 ROM on it and there was no change, still 128MB, 128-bit. The difference between 128MB and 256MB doesn't really matter for all practical purposes with this card, but I'd like to understand how it works. Maybe Mem_Strap0, Mem_Strap1, and Mem_Strap2 have something to do with it? These are shown in the schematic but their meaning is not documented.
Loving your VidCard hijinks! Keep 'em coming. :)
Have any suggestions for flashable to Mac OS9 PCI cards that'll do 1920x1200 DVI output?
edit: side note; does anyone have Mac compatible suggestions for same?
On the back, fourth one from left to right under the upper left RAM chip 😁
Points for you! Unfortunately...
Somewhat unexpectedly, this saga continues. @Trash80toHP_Mini asked me to convert a PCI 9250 for him, and I agreed to take a shot at it. Specifically one of these, a VisionTek with a DMS-59 connector:
The DMS-59 output is odd and was clearly chosen for its ability to fit into a low-profile PCI bracket. Luckily, the card I have is equipped with a full-height bracket. A dual DVI adapter is included, but the card has only one digital output, available on port 2; analog output is available on either port via a DVI-to-VGA adapter.
While the layout of this card was rearranged to fit on a smaller PCB, the components all use the same reference designators as the available schematic, so it was pretty easy to check and move strap resistors. Based on The Mac Elite information, the schematic, and a little poking around, I put together the following table of straps that seem to be important for the Mac Radeon 9250 PCI. The Sapphire and VisionTek (and Mac) cards use the reference design (at least in terms of how the strap resistors are labeled) and the Mad Dog uses an alternate design (which I presume is just one of many).
Net NameGPU Pin NameGPU BallReference Design = 0Reference Design = 1Alternate Design = 0Alternate Design = 1Mac PCIMad Dog PCISapphire PCIVisionTek PCI
BUSCFG0GPIO4AG4R220R219R40R390001
BUSCFG1GPIO5AH4R222R221R42R410000
BUSCFG2GPIO6AK3R224R223R44R431111
MULTIFUNC0LCDDATA16AH9R228R227R48R470000
MULTIFUNC1LCDDATA17AJ9R230R229R50R490011
As the table shows, I had to move R219 to R220. I found R229 populated, so I removed it, but I could not find R230 anywhere, including under the heatsink. I measure 1.7Mohms to GND on that net, so I guess it's very weakly pulled down? Maybe I should search for R230 again. Anyway, the card works well. Before the resistor changes, the video output was garbled, now it's clear. Here's the area of the card where the resistors need to be changed, just up and to the left of the upper heatsink pin. They have already been moved in the picture, and the flash ROM chip has been replaced with a 1Mbit part:IMG_20260118_204208_421.jpg
Oh yeah, the heatsink on this card has the awful yellow phase change TIM, like R300 and NV25/NV28 cards typically do. It requires heat and scraping to remove. I replaced it with regular thermal paste.
I was optimistic that the 4.0ns RAM onboard would clock to its rated speed of 250MHz:
Well, it didn't. Any attempt to increase the memory clock above 225MHz showed artifacts. True to the reference schematic, this card uses the same TLV431-based switcher that I posted the schematic of above to supply both VDD and VDDQ for the memory. R279 is 4.75k and R283 is also 4.75k, which results in an output of 2.5V. The memory wants 2.6V, so it's being undervolted, thus it won't reach its rated speed. I'm sure the performance difference isn't huge, but I may try playing with these resistors later to see if I can get the rated speed out of these chips.
Another oddity of this card is that the two FETs at Q901 and Q902 get HOT! I measured over 100C under load, and that's with the G4's case open in a cool room. I suspected that these FETs might be under-specified switching FETs like I'd seen on early NV25 cards, but I was wrong; it's weirder than that. These are NTD14N03s, fairly beefy 14A parts. Scoping their gate pins, I see no switching, just a constant DC voltage...this isn't a switching regulator, it's two linear regulators in a trenchcoat! Their source pins are tied together, so these two FETs are supplying current to the GPU core in parallel, regulating 3.3V down to 1.6V and burning the rest off as heat. So, as far as wanting to reduce their operating temperature, I think I'm kinda screwed. If I replace the FETs with ones that have lower RDSon, the gate drive voltage will be adjusted until their RDSon is high enough to regulate the output, at which point they'll be dissipating exactly the same amount of power as the existing FETs. Oh well, this design worked for 20 years, and the silicon is rated for 150C. Might just have to live with it the way it is.
I have been misunderstanding all of the TLV431-based regulators on these cards. They are not switchers at all. While it is possible to build a switching regulator with a shunt reference like the TLV431, the configuration here is a linear regulator. They find a gate voltage where the FET's RDSon results, via Ohm's law, in a voltage at the source that equals the TLV431's reference voltage via a resistor divider. If the load goes up or down, the gate voltage rises and falls a little to compensate, but the FET is never fully on or off. Here is an LTSpice simulation of the 2.6V regulator for the memory. If I had done a transient analysis earlier instead of just looking at the operating point, I would have understood this:
I had some NTD40N03s on hand, so I tried swapping them in for the NTD14N03s. As expected, no improvement. Still burning hot. Here's the reference schematic for this regulator:
The VisionTek card doesn't implement it exactly as shown above, but it shares one thing in common that I hadn't really focused on, which is the 1N5400 diodes in parallel. These are the big through-hole parts in the upper right corner of the PCBA. Their job appears to be just to drop some voltage from the 3.3V rail before it reaches the drain pin of the FET(s). This is a weird, janky setup; the diodes are elevated off the PCBA by 0 ohm resistors used as spacers, as it says in the note above, to prevent them burning the PCBA. The design seems to be to spread the heat out between the diodes and the FET(s). Okay, so why aren't my diodes getting hot at all? I measured them in circuit with my handheld meter and it shows 536mV forward voltage across the diode combo. These parts are supposed to have 1.2V forward voltage, but I have no idea how being in parallel affects that. In fact, best practice seems to be not to use diodes in parallel like this, because they are not guaranteed to share current well. ; Apparently standard diodes have negative temperature coefficients, so the hotter one gets, the lower its forward voltage gets, which means the hotter one in a pair ends up taking more of the current...you can where that feedback loop would go. Luckily these two parts are physically touching, so their temperature probably never differs all that much; maybe that's enough to avoid a horrible runaway problem. But also, perhaps there's something wrong with the ones on this board? I think that's where I'll investigate next.
Interesting posts, thanks for sharing your projects! Buck converters are usually easy to spot by the presence of inductors.
Thanks guys, yeah, having some fairly low-stakes fun with these old PCI cards.
I finished up jt's VisionTek card today. It got a recap, and I replaced the diodes with STTH310s, which are 1.7V forward voltage. I measured 843mV across them while the card was running, so they're definitely doing more than the 1N5400s were. The diodes at least get warmish now (~50C) whereas the 1N5400s didn't seem to get above the temperature of the card. Unfortunately the NTD40N03 FETs for the GPU core voltage regulator will still hit 90C+ after running OpenMark in Tiger for a while. They stay much cooler while not doing 3D stuff, so this simply isn't a gaming card, which is reasonable. For anyone working on one of these 9200/9250s with the diodes and doing a recap anyway, throwing some STTH310 or equivalent higher forward voltage diodes on there still seems like a good move.
I also swapped R283 from 4.75k to 4.32k to bump the DRAM voltage from 2.5V to 2.6V, and I verified 2.613V while the card was running. Unfortunately it still won't hit 250MHz with ATIccelerator, so I left it at 200MHz and went back to 2.5V. I kinda wanted that extra 50MHz...but again, not a gaming card, so it's fine.
Confirmed acceleration in OS 9.2.2 using the modified driver package available from several places. Only 64MB reporting for duty, which is expected until/unless someone figures out a firmware mod.
SWEET! Thanks much, time to get to the PO. ;) Found one of the VisionTek Cards and splitter cableI snagged on the cheap in the backwhen while looking for something else. Never got it running, so I guess I've got the heat sink somewhere around here too along with the other card/cable.
The DIN7(?) connector's implemented, but covered by the plate. With 256MB on board I'm guessing this is a later card with no Mac support?
Never reported over here on the card you sent me. Gave up on running the 1440p Display from the DVI port. Hadn't been able to get more than 1080p from there and out thru the KVM switch so I gave up and hooked up a VGA Cable.
Gotta switch the display to VGA manually, PITA that. But VGA is pumping out 2048 x 1152 at the panel's native 16:9 aspect ratio.
It looks GREAT! :D
That's what I'd thought, but surprised it might be possible to be done. How much is it better than the 9250 cards and was there ever any Mac support at all?
Wicked cool heatsink though! Took it off to install on somethingorother, pretty sure it never was and is running about somewhere loose in the Old Dragon's Horde. :rolleyes:
There was a G5-compatible PCIe X1900 GT, and its ROM is on The Mac Elite. As far as I know, nobody has gotten the AGP version working. The X1300 is, in theory, 1/4 of an X1900. So as a prerequisite, if the AGP X1900 could be made to work, then maybe the X1300 PCI could be made to work. Each is a different flavor of R5xx GPU with a PCIe interface behind a bridge chip. This is all conjecture and way beyond anything I am willing to attempt.
Of course, this would all be OS X only, and a PCI card that doesn't work in OS 9 and older is much less appealing. As far as performance is concerned, I'd look for some Windows benchmarks to get a rough idea. At a certain point, the PCI interface has to become a liability.
Yep, but using any PCI Card to drive the second display from the MDD'03, hopefully over DVI, in 1200x1920 portrait mode. ATM the main display is a 1440p screen driven at 2048x1152 over VGA.
If I need to run the card you've prepped over VGA as well, my 4 Computer/Twin Display USB-3 KVM switch downshifts to only K_M function with manually menu switched V. SIGH! No biggie though, I could live with that. ;)
