You have: AAUI to 10BASE-T ethernet adapter (aka a MAU). You need: regular AUI. A hack...
Plenty of older computers have only a 15-pin D-sub AUI connector for Ethernet. Apple tended to avoid this connector on Macs as it used (basically) the same 15-pin D-sub connector as the video connector, so they came up with the compact AAUI connector to use instead instead.
To connect either of these to anything that looks like a modern Ethernet cable, you need an adapter called a MAU. And while AUI to 10BASE-T MAUs used to accumulate in IT department drawers like fleas, these days they're surprisingly hard to find for a reasonable price. (Go on over to eBay and try it now...) Meanwhile, probably because they can only be used on old Macs, AAUI MAUs are easier to find for cheap. You can get 15 of them for $30 or just one for $10.
But sometimes even Mac users need AUI, as recent threads here like this one show. Is it possible to adapt an AAUI MAU to AUI?
A Farallon EtherMac AAUI/10BASE-T MAU has had its AAUI cable cut and spliced onto a prototyping circuit board, where a 12V to 5V buck converter also sits. On the other end of the board is a short ribbon cable leading to a 15-pin D-sub connector, which has some power leads connected to it. A few LEDs on the Farallon adapter are illuminated.
Yes, it is. Here's a video in dazzling Potatovision that shows my adapted adapter working with an IBM PC/AT. It's hard to see the AUI connector but you can bet there's no AAUI connector there.
The AAUI connector still works if you allow the original connections to "pass through" your hack unchanged. But for AUI, it's not that simple, since AAUI usually supplies +5V power while AUI supplies +12V. The answer is to use a voltage regulator to make +5V from +12V, or what I've used myself is a cool-running buck converter like the Recom R-78E5.0 series. I've used the 1A variant, not because the EtherMac consumes 1A (nowhere close) but because I have a bunch of these buck converters handy for various projects. A hand-drawn wiring diagram is attached.
The diagram also shows capacitors connecting various "Shield" pins to ground. The standard defining AUI states that these pins must be "capacitively coupled" to Vc (which I've recklessly labeled GND) but offers no further guidance for the sake of non-wizards like me. I was not able to measure any capacitance between shield pins and Vc on a real MAU that I own, so I simply didn't fit any: the shield lines terminate on the PCB with no connection anywhere. AUI cables are allowed to be up to 50 metres long, and I'm guessing the coupling is meant to accommodate that. My ribbon cable is 5 cm long, so I'm guessing it does not matter.
I'm happy with my hack, but I'd prefer not to have to chop up the MAU and strip so many itty bitty wires in the way I've had to do. Is anyone aware of a way to get AAUI socket receptacles? It would be a way to make a much more elegant little AUI<->AAUI adapter that works with plenty of AAUI appliances.
Aren't these similar to Wide SCSI connectors? https://de.aliexpress.com/item/1005005639252236.html. It would be cool to have a nice PCB for this since I also just have AAUI MAUs.
That looks very promising indeed, particularly the 14-pin variant!
It looks like the official name for this type of connector may be the 3M Mini Delta Ribbon (MDR) connector. I will order some and look into making a nice little PCB.
I think your idea for an AUI to AAUI adapter is a good one.
I had another idea. I remember in the 90’s you could find inexpensive 10baseT hub with a single 10base2 connector. I used one in my office to bridge a 10base2 network to a 10baseT network - plug and play. I just searched eBay and found multiple 10baseT hubs that have a single AUI connector, selling for $20-$30.
I used to have a drawer full of those in the early 2000s.
10BASE-2 has an appeal. What I've found harder to get hands on at a reasonable price is the mass of cable segments, T adapters, socket-to-socket joints/extenders/splices/whatever-they're-called, and terminators you need to build the network. (Yet another "used-to-have" situation for me.) Cat5+ cables with modular plugs on the ends are meanwhile basically free... for now anyway.
These were cheap & plentiful on eBay and AliExpress the last time I looked. The cables are also used in lab equipment.
For every machine of mine with an AUI port, I'm not going to get one of those hubs --- at $20/pop plus shipping to the UK in my case, not counting the fourteen quid AUI cable (or maybe four quid plus slow shipping from AliExpress for something that may work but wasn't made for the job).
I'm also not going to inaugurate a 10BASE-2 network. A new kind of network means an online retailer fetch quest and another box of stuff, and I don't want another box of stuff, especially not cables. Ethernet to WiFi bridges don't generally do BNC, either.
The problem I wanted to solve is the one I named in the title of this thread.
I do appreciate the tip about the AAUI connector. In a while I'll have my AUI-plug to AAUI-receptacle adapter board and I will let you know how it goes.
Ok, didn’t know how many computers had an AUI port. These must be some unique computers, as Macs typically had an AAUI port and 10baseT cards that work in PC’s are inexpensive ($10-$15) on eBay.
Rather surprisingly there are other computers besides Macs and PCs.
Older Ethernet-equipped workstations and other kinds of personal computers often had AUI ports. Many also had BNC ports, but as discussed, I don't want to start setting up a 10BASE-2 network right now.
Here's the back of some Sun 3 workstations: note AUI and BNC, no 10bT
The Sun Sparcstation 1 at the top of the pile: AUI only
Smaller lunchbox SPARC machines: AUI only
They made thousands of each of those, so not so unique, although I don't have any. What else?
Original 68030-based NeXT cube. Several people on this forum have them. AUI and BNC, no 10bT. (Later NeXTs had it.)
DEC MicroVAX 3100 workstation: AUI and BNC
I could go on but I'll stop there. Anyway, lots of (or even most) workstation manufacturers from the '80s and into the '90s did it this way. Now, I actually do have some unique computers in my collection, so I'll add them to the list:
Whitechapel MG-1 (a British UNIX graphical workstation from the early '80s): AUI only
PERQ 2T2 (a contemporary graphical workstation inspired by the Xerox Alto): AUI only.
But they're not unusual in their choice of Ethernet interface; they're pretty much in keeping with how workstations were made back then.
Are AUI Transceivers really that expensive there? The Centrecom boxes are nearly a dime a dozen in the US. Transition Networks even still manufactures them new.
I'd be interested to see what you see in the US --- share a screenshot? Attached are what I get when I search ebay.co.uk for "centrecom 210T" and "centrecom 210TS", sorting up by price (zoomed out to make more offers visible), and remember that international shipping often isn't priced in. Note also that the seemingly-reasonable 210TS offer is actually a keychain.
Just searching for those things on Google yields similarly dismal results.
(At time of writing £1 is $1.35.)
...now I wish that I had kept all the CentreCom adapters I had from my HP-UX workstations, instead of just the four adapters that I still have.
I got a pallet of HP735s back in the day - sorted them down to around 10 fully upgraded units and eventually gifted those all to a coworker learning UNIX, so I had a LOT of them laying about.
