Mathey MSATA-02MAC SATA Card
finkmac
NORTHERN TELECOM
68000
Turn It On Again, One More Time? Deja Vu for sure.
Got this card a few months back.
Mathey MSATA-02MAC. SiI3512-based PCI SATA Controller with MacOS compatibility.
specs here:
index.php
You'll note that the preview image on the mathey website is… rather different. I have no idea.
The yellow version was definitely sold by mathey though. This is the best picture of the box I could find.
As per the specs, It's supposed to support MacOS 8.6+
I tested it out in a few Mac clones and managed to get to the "Welcome to MacOS" screen, but I had issues getting further.
To be honest, my selection of SATA disks is rather meagre, and I'm likely just running into hardware failures. Either that or an issue of skill.
firmware is by...
Hey look, it's Projovian again! Unlike the MSATA-13UMAC, I haven't found a compatible card on their website.
firmware ROM is a 39VF020 PLCC32
in theory you could flash a regular SiI3512 card with this firmware and it would just work.
wanna try? you know you want to.
Interesting; the pic on the box matches your board; the board in the picture does not. Guess they were into continual improvement :)
Nice find, @finkmac! Thank you for posting it. I will not try flashing another card, though, until you also dump the contents of this EEPROM, which I think is a AT24C02B:
Sorry, I have been burned before :)
:mad: and here I was hoping to avoid using hot air on this thing.
bah! i'll try and get that dumped sometime this week
Thank you. These Projovian things are a pain. Luckily all the generic 3512 boards seem to have the SOIC footprint, so it's a better situation than the VIA 6421 cards. Soldering still required, though.
Well, now I'm invested. The ROM on there was a 39VF010, which will be a problem for adoption by the retrocomputing masses unless someone can reduce the ROM size like @dosdude1 is working on for the VT6421-based cards.
I hope I am on the nice list and @finkmac claus brings me a Christmas present 😇
Initial results not good. I programmed the 39VF020, popped it in the socket, programmed the AT24C02D (not an 02B, surely it can't be that picky?), soldered to the board, installed in Quicksilver, I get a bong and a black screen. Never initializes video output.
Out of patience for now, will come back to it when I have more.
I remembered I'd had problems with this style of PLCC socket being finicky before, so I tried reseating the 39VF020 a few times with no improvement. So I tried booting without the chip installed; still a bong and a black screen. I then tried removing the serial EEPROM, just to see what the card would look like in OF with no ROM installed at all...and still a bong and a black screen. So the Quicksilver just hates this card. Maybe the card is bad?
Is it the same thing with other SATA cards with the 3.3v/5v VRM problem or other quirks? Quicksilvers and their pickiness. Do you have another machine to try it out? Also, any indication as to what the jumper on the card might be for? I guess I'm spitballing here.
