Outbound Laptop repair/reverse engineering
Yeah 8 modules, I tried both 1MB and 4MB modules in the RAM disk slots, as well as none at all, the behavior is always the same.
I would open the control panel if the mouse worked. I think the EEPROMs are version 1.2.1, I can't remember if I updated them.
I also accidentally discovered that if you just give it 1MB of RAM at 0x600000 it will gladly make a 1MB RAM disk out of that, so I'll have to see exactly how that works, I would have thought it would be doing some sort of bank switching.
That is interesting - I expected the same. Especially as they supposedly support up to 16MB in the ramdisk. How are you giving it RAM, poking bytes with microbug? Supposedly there's a modified version of macsbug, but i doubt that will ever materialize...
Keeping forgetting your mouse is nonfunctional. Something that might be interesting to test wrt your mouse issues is if click works. In the boot position it'll at least click on the apple menu. You could also test this by sticking a jumper in the mouse port according to the pinout above.
Just in an emulator. I think I got the RAM disk working in it now, looks like there's just a few registers for controlling the address lines on the RAM.
You're using an emulator to roughly fake up the docked outbound + se/plus address map then? Clever, I like it!
I've not done much probing of the address map other than identifying some IDE registers.
Incidentally, the shut-off-when-base-closed function is done by another reed switch buried in the power module, so you can take your NMI magnet and place it on top of the serial sticker for a hard shutdown. Or drop the NMI magnet.... guess how I figured that out.
Confirmed the mouse pinout and theory about some InPort mice being mechanical. InPort Mouse with FCC ID C3K5K59937 marked Made in USA has mechanical encoders. To adapt it I went with stealing the end off a serial cable and splicing it; unfortunately the only DIY connector kits for mini-din 8 won't fit. I could have replaced the entire mouse cable but all the serial cables I've found were not particularly pliable, it'd not be a nice cable for mousing about.
Here's the pinout for the InPort cable. Note that pin numbers are for the connector inside the mouse, not on the DIN side.
And the same pinout for the connector on the Outbound Keyboard side as previously posted.
NOTE: There's a chance I might have accidentally transposed YA/YB XA/XB in these diagrams. If you find movement direction is inverted, simply swap A and B for the affected direction.
The result: not the most pretty, but functional.
The mouse respects sensitivity settings; I found Fast to be the most comfortable for me. Interesting that the apple control panel works at all for this given it's all running through the infrared connection, perhaps Outbound is injecting movements into the Apple driver rather than doing their own thing and manipulating the globals. Or it's tied into the isopoint driver and they just read the PRAM values the apple control panel sets.
AC Adapter is a 19v AC adapter with an obvious rectifier in the power module. It probably could be powered with an appropriate DC adapter. Not sure I'm brave enough to chance it, though.
I actually didn't even know it was AC, I've only ever powered off DC so I can confirm 100% it works. Always used the standard 19V PC Laptop Adapters that basically every Acer brand, HP, Clevo, etc used.
Good to know. Probably would be a good idea to put a fuse on it - I don't recall seeing one inside the Outbound's power module.
Took a second to probe the presumed video port on the outbound. As expected, it's very much not VGA and if you plugged a VGA monitor in it's going to short the -16v line to ground. Don't do that!
It appears to be 8 bits of pixel data plus a couple of clock signals. My assumption is this is fairly raw data read out from the VRAM inside the outbound - probably 2.46mhz is the rate at which bytes are read from the VRAM and I would assume 15.36khz has some relation to the horizontal frequency. As I recall passive matrix screens are all sorts of strange to drive and rather than providing a more conventional video signal out (requiring additional complexity in the outbound) they instead decided to provide raw data out and sort it out in the optional external monitor if/when one was used.
Still no luck with the external floppy. Per a comment from @techknight I've screwed up the alignment of the heads on top likely issues with the heads themselves (might have cracked one). I'm trying to adapt some other drives but no joy at the moment.
In the interim, I've taken a spare mac classic logic board and have it running headless in a 3D printed enclosure. It's got System 6, AppleShare Server 2.0.1, and Timbuktu with the contents of the common "MacPack" image as the share. It's a handy little USB-C powered localtalk server consuming about 5 watts @ 5v. Take about 15 minutes to boot as Appleshare checking ~20k files on a 2GB HDD takes a while.
The video signal is basically the same as the one from the Macintosh Portable (aside from the different pinout) though it also supplies HSYNC and also runs at more like 76Hz rather than 61Hz it seems. For my video decoder setup at least I don't even have to change the code, just the pinout.
Actually now that I go back to look at my code, I did have to tweak it since it's a DSTN display output and scans both halves of the screen in each clock.
The Gotek/Flashfloppy emulators work fine at least for 1.4MB disks, I have one running on mine since my physical floppy drive doesn't seem to work.
I've been fiddling around with adapted floppy drives... with one drive, it will read, write, and format 1.4mb disks - but god forbid you boot off a floppy that isn't read-only, straight to jail (corrupted disk). Haven't tried to capture what exactly is getting messed up yet. I would be curious if you can replicate that behavior with your floppy emulator, I've attached the image I'm using. System 6.0.8 + Outbound 1.3 software on a 1.4MB disk.
This drive is a FPC so the pinout is identical, direct connection for all even-numbered pins except 8 which isn't wired on the floppy side. 800K disks do not work; they will spin and twitch the head every ten seconds or so. Most drives do this. Cursor doesn't move while this happens. My assumption is the floppy driver is polling for a signal that isn't arriving, but I haven't tried to actually debug it. At some point I should try a few MacsBug versions and see what they actually do, might be the custom patch (which had to be requested from Outbound) was something simple perhaps related to the display.
I've found one drive that will entertain the concept of reading an 800k disk - with issues, of course - but that's more than most. It's a seemingly-crap Mitsumi D359M3D drive. I've not dug into that in any detail yet.
Also, I found your RE repo - https://github.com/rezafouladian/OutboundRE - curious what tooling you're using there?
I'll have to see if I can find where the floppy emulator went, that image does work fine on an original drive at least.
For the disassembly? Just Ghidra.
Interesting. It was well formatted/etc, better than I've seen of other tools I usually use.
It works and boots without corrupting the disk on a stock drive then? Internal or external? I'll need to capture some images to see what goes wrong with my adapted external.
Well if you mean the assembly text files themselves, that's all done by hand.
I've only tested external so far. I'll have to see if I can put an internal floppy setup back together again.
I have this weird issue with one of my internal power boards. It was likely caused by the main battery getting connected backwards, but I can't seem to figure out quite what's wrong. What's weird is adding any sort of capacitance to various points even briefly causes it to start working, at least until power is removed.
The power board is quite packed:
Sounds to me like however they're latching softpower state might have got messed up. I'm kind of expecting it's something to do with the cluster of transistors but I didn't spend a lot of time looking into it. As you said, it's a very dense board....
Regarding the disk, I suspect if it works on the external floppy, it'll probably be fine on the internal. I'm assuming it's some timing issue resulting in the drive writing when it shouldn't.
On the topic of external floppy I've been fussing around with the Mitsumi D359M3D drive. It actually managed to read and boot(!) from an 800K disk - once. Neither 1.4 or 800k work reliably/consistently though. There's some talk on modifying these drives for use in Amiga but it's not quite clear on *what* is actually being changed by messing with the jumpers.
I'm planning to tone out the floppy connector at some point to figure out what's wired and where it goes as that might shed some light on what it may be expecting in software/hardware. A big question I have is if it tries to determine disk type purely in software or if it uses the sense signal from the drive, disassembling the external floppy driver in the eeprom might shed a bit of light too.
It appears it just tests each format one by one until it finds a match.
Yes, that jives with what I found - no density select line is used. As expected the pinout of the 26 pin connector is "standard" 1:1 with the common 26 pin FPC pinouts. Most notably pin 8 (Ready) is unused in favor of pin 6 (Disk change). The tomfoolery around the read data and write data/gate lines is presumably for switching between the SCC and WD37C65 for data I/O.
This doesn't give me a lot of hope for progress with adapted drives as there aren't any surprises here and my DIY adapters are already wired correctly. It may end up being a trial and error which drives work and to what degree, I assume it depends on how the drive's controller behaves. Somewhat interestingly the drive LED remains on on the adapted drives unless a disk is present.
I've had another go at my citizen drive; it seems to want to seek past track 0 and starts missing steps because that's mechanically impossible. Format fails as a result. Not quite sure why it'd be trying to do that.
Nevermind, I figured out the Citizen floppy issue. Don't remove the stepper motor, at least, not without very precisely marking the rotation of it. Otherwise this messes up the stepper steps<>tracks and causes alignment issues. By trial and error I got a lucky rotation of the stepper and found it suddenly working. I'll spare the huge amount of trial and error and corrupted floppies it took to get to a point where it seems reliable. Or as good as I'm going to get, anyways. Booting from disks (not read only) is a bit corrupt-y still but it will read disks written in other machines and write disks that other machines can read, in 1.4MB Mac, 800KB Mac, 720KB PC, and 1.4MB PC.
In the end I put a scope on appropriate test points and rotated the stepper while reading a disk until the amplitude was highest. It's best to use OEM-mastered disks for final testing as they can be reasonably assumed to be written on a well adjusted drive. Failing that, need to use a bunch of different drives and sort of average as you can't guarantee the health of any one drive.
TP0, TP1 on the bottom of the drive are the raw signals from the heads with a DC offset of around 2.36v on my drive. Maximum amplitude observed was about 400mv when it seems best adjusted
TP11 is the tach signal for the disk; 5hz is expected here corresponding to a disk speed of 300RPM.
After buying around 5 random mice off eBay with very little description or pictures, I finally found a mechanical one:
It has the FCC ID E6Q5J8BUSMOUSE and not much else on it.
I still have the one floppy drive I can't seem to get working. I think it used to do more, but now only the motor spins, the head doesn't even move.
View attachment 96998View attachment 96999
Definitely an, erm, engineered to cost product. But should work. Pulse rate/DPI might differ though. No luck with the InPort mice?
I did have to get an assortment of chinese belts in the end as the TPU stretched and stopped gripping. As I recall if it can't bring the spindle to speed it won't try seeking, but it should try to at least home the head if I recall correctly.
I bought a Microsoft InPort Mouse C3K5K5COMB and found that it wasn’t a simple pull-up design — it actually uses IC control.
So I wired the mechanical encoder and microswitches directly to the DIN 8-pin connector.
I also added 4.7 nF ceramic capacitors between each of the four terminals of the mechanical encoder and GND to suppress contact bounce.
After 40 years, an external mouse is finally back on my Outbound.
Thank you.
Here’s another piece of information to share.
One possible cause of an Outbound failing to power on is a faulty reed switch in the power module.
The system is designed so that pressing the four keys activates the reed switch, which turns the power on.
The reed switch is still available today.
The power module is the aluminum case on the plug side of the AC adapter.
