Outbound Laptop repair/reverse engineering
Back off the contrast a bit in the outbound control panel - you'll find it helps notably with the artifacts/ghosts.
I would if my mouse worked 🥲
At this point I can't tell if it's just the mouse itself not working or if there's a problem with the computer. I think when I was trying to run things with just the keyboard alone it would freeze up when opening apps. It also doesn't prompt to initialize the RAM disk which I thought it was supposed to do.
Do you mean the isopoint bar or an external mouse? My isopoint just worked, there's a disassembly guide in the manual that you might check if not. In particular, if you poke the limit switches I'm pretty sure the cursor should move immediately.
If there's simms present it should prompt you to initialize AFAIK. Also, what key combo did you use for NMI? I've found Ctrl+Option+Delete is reset but not found NMI yet. Just so it doesn't alarm anyone else, it's normal behavior for the outbound to hard shut off immediately if the base is pivoted to the closed position. Alarming creaking noises while opening are also normal due to the... interesting hinge design. Sounds terrible, adjusting the hinge brake can help as directed by the user manual.
I've got mine put back together but it's still seeming a bit crashy so I've work to do still....
For the floppy, I'm going to attempt to adapt another drive to verify the control electronics before I put any more time into trying to rehabilitate the external drive. Right now it'll try (and fail) to initialize disks unless single sided is picked, which it will finish but don't work on subsequent boots.
I found the main hinge had some cracking from the spring over time - I've added a metal reinforcement to mitigate that. Some small cracks there and elsewhere I used acetone (where practical) to repair.
It's the isopoint. None of the switches seem to do anything at all. I haven't been able to find a compatible external mouse yet. Mine is also missing the cover and the white part that holds the roller, not that it would prevent it from working.
Hold a magnet in the area below the expansion connector on the left to activate NMI.
Aha. I wondered what that reed switch was for.
You might try putting a camera in front of the infrared window and working the buttons on first the keyboard then moving the isopoint. You should see infrared activity on both, if you don't see it for the isopoint then it's something in the keyboard for sure.
I've heard the mouse is a microsoft bus mouse, no idea if standard or not.
I do see IR activity from the isopoint, though whether it's sending the right data I'm not sure. It doesn't work connecting it with the cable either.
I tried getting a Microsoft bus mouse, but besides the connector not physically fitting the bus mouse is a 9 pin connector and the connector on the Outbound mouse port is 8 pin.
Here's the pinout as I have it so far. I verified by feeding power into an Apple II mouse i had handy and wiring things up. Mouse button 2 is a locate function, highlights the cursor with a black circle. Pin 1 seems to be a NC, but i haven't taken the keyboard apart. All lines are pulled up except 1.
What's odd is this mouse is mechanical only, not the usual optical arrangement. This does make sense because the usual infrared mice would kill the wireless keyboard battery in a few hundred hours tops, so they needed a passive solution.... but it's weird.
As far as I know standard Microsoft mice will require power so no go there. Unless you make an adapter that incorporates a power source, anyways, or hack one into the mouse itself. If I can confirm the Microsoft Inport mouse (housing) is what Outbound custom-ordered then I may take that approach.
Okay, here's the mouse plan: looks like older Microsoft mice were still using mechanical encoders, including some of the InPort mice. So I guess it wasn't a special order beyond the cable termination.
I found this by checking a Serial mouse I have with FCC ID beginning in C3K5K (Made in US) and found it had mechanical encoders inside, so I've ordered an InPort mouse with a similar FCC ID in the hopes it too has the same inside. I'll either replace the cable or re-terminate it if so. There's a later Made in Japan C3K7PN9937 type also... no idea if it uses mechanical or optical encoders.
I found it was obvious from looking inside the mouse ball housing that there were mechanical encoders in play - see below.
I think it's pretty unlikely that it's not sending the correct codes if the keyboard works. You could try updating your eeproms with the images I posted previously (back them up first!). Could be they're corrupt.
I just figured out my "something odd".
On my machine, I had a behavior where it would fail to boot or freeze for unclear reasons, but flexing the board or repositioning the hinge would sometimes fix it. When "frozen" all would stop but it would happily resume afterwards if mechanically "stimulated" one way or another. At one point mouse clicks would work but movement wouldn't, but usually it'd be stuck in early boot and, well, can't interact at that point. It'd be fine when out of the casing and resist board flexing but when fully assembled the issue would come back - very annoying given the amount of work it is to (de)assemble it.
Started poking every damn inch of the logic board while running after dark and trying to figure out exactly what would cause it to "pause". Eventually, I found the below. The copper is some kind of improvised ground.... but the circled via (?) seems to not been filled with mask and got coated with solder. As a result, when pressed, it'd short to ground and seemingly cause the pause effect. Measured ~ 5v when not bridged.
I pulled the copper up slightly and then no amount of flex would interrupt the machine. Aha. And: this is a mounting point for the rear case, so it'd receive some stress as well as being a direct path for vibrations/mechanical manipulations to apply a bit of flex to the board.... seems like a smoking gun to me! I cut a small bit of the copper around the via and so far we're good.
It's a long shot, but you might check it.
I also pulled the GAL from the External floppy and dumped it. It was a GAL16V8A 25QJ in PLCC form factor.
I assume there's some kind of microcontroller on the floppy besides the SCC and WD17xx/27xx?
Only whatever a standard PC floppy would have. The drive is a Citizen U0DA-13a - there's a few bodges on it, but I'm not sure if those are standard. Much of the magic must be happening in software, I posted the eeproms with the driver earlier in this thread. I've made a quick attempt to adapt a 3.5" slimline drive but so far it's noticeably unhappy with that.
The drive has been recapped except for a 2.2uf bipolar cap that appeared in good condition. It'll spin the disks (with replacement belt), detects presence and size tab correctly, and can seek the whole range, but seems to have read issues. It sometimes can format a disk but can't actually write correctly either as far as I can tell.
Well, something has to be programming the registers on the SCC and the uPD765 clone. What port does it attach to? The IWM?
There is no IWM or other proprietary apple ASICs used in the outbound. This is used as a functional replacement for the (S)IWM with that driver I mentioned being responsible for the magic.
It is attached to an external PDS type bus - also used as the docking interface to the "host" machine and an external SCSI HBA.
Wow. The EPROM contains what looks like a pretty standard 68k Mac driver. With MacsBug subroutine names, conveniently ("floppyopen", "floppycontrol", "floppystatus", etc).
Disassembling it should be kind of wild - based on other unhinged FDCs we've seen I'm gonna say they use the 765 for 1.44 MB disks and the SCC for 800K.
this is why this machine is fun, nearly everything about it is unhinged. even the design of the hinges (har, har)
The way I've been describing this in my mind is outbound is not a Mac and doesn't owe much of anything to Apple's designs. It's just sufficiently similar that the ROM will get far enough along that they can hack it along the rest of the way with a pile of custom drivers. And yeah, even the hinge is, uh, interesting, with external tension adjustments and a tool supplied to adjust it.
Overall while the machine is a whole is fantastically odd, it seems competently executed as far as I'm able to judge.
The IDE HDD is handled by the .PTek driver in the main EEPROM code, I've been poking through it and it really isn't anything terribly exotic either. It does seem to read CHS values so it may be possible to stick a HFS image that maps to appropriate CHS values and have it just work. First I may try to get the ZuluIDE byteswapping data for me however to make it easier to inject stuff.
I took a moment to play with the zuluide and confirmed a few things.
First, the driver does read CHS values from the disk: I tested 93.75 MB working (CHS 800 6 40) which all values are different from the original drive. I am sure there is a limit somewhere but I'm in no hurry to find it :)
Second, as long as you have a way to boot the system to finder it will prompt you to initialize the drive. This can even be as simple as booting off one of the images I posted, copying the Outbound 1.3 folder to your silicondrive, and rebooting off that.
So really the "problem" all along was just expecting an ATA-1 General Configuration word, and that could be easily patched as I don't think it's used for anything but a sanity check.
I checked what vias I could see and the solder mask seemed to be doing its job at least, though I haven't looked under the copper itself so who knows what's under there.
I'm pretty sure this is what I'm supposed to see when starting up the system:
The odd thing is it appears this screen is supposed to show when the computer thinks that RAM is installed there, regardless of whether it is valid, so I guess I have to work backwards through the code to see what it's using to detect the RAM being installed, then see if I can figure out where it's going wrong in the hardware.
You do have 8 modules installed and not just 4 right? Since the farthest 4 modules from the ROM slot are system RAM and closer 4 are RAM disk. If you do have RAM there it should be prompting you.... if you have the outbound control panel, what version does it say your EEPROMs are?
Some gentle flexing of the board might be in order, that is what eventually led to me that issue on my board.
Yeah 8 modules, I tried both 1MB and 4MB modules in the RAM disk slots, as well as none at all, the behavior is always the same.
I would open the control panel if the mouse worked. I think the EEPROMs are version 1.2.1, I can't remember if I updated them.
I also accidentally discovered that if you just give it 1MB of RAM at 0x600000 it will gladly make a 1MB RAM disk out of that, so I'll have to see exactly how that works, I would have thought it would be doing some sort of bank switching.
