Anyone with a working Quadra LC 630, Performa 6200-6300?
Hi,
Can someone with a working Quadra LC 630 or Performa 6200-6300, please tell me if it will still post without the front LED/infrared/volume control unit plugged in?
I just wonder if mine has developed a fault.
Thanks.
I have a spare logic board you can have. Just pay shipping. Even recapped. In canada
Thanks for the kind offer, I actually managed to get this going now. It turns out there was some corrosion on the contacts of the Cache Rom slot which I didn't initially see. This slot sits directly below the fan/enclosure, which had a bit of rust on it, so might explain where the moisture came from.
I sprayed some contact cleaner on the slot and inserted/removed some thick cardboard 30+ times which seems to have cleaned it up. Now the machine posts. :)
