I've just rebuilt the battery for my Powerbook G3 Pismo. I used a spot welder and spent a methodical day putting the new battery back together as i've never done anything like this before (outside on a fireproof table, with a bucket of sand and plenty of protective gear!).
It all went OK except when assembled and I pressed the button to show the status of the battery it shows nothing at all! It was working before in the battery, albeit just flashing a single LED.
The voltage across the battery leads is coming out at 10.3v. However, if I measure across pin 2 and 6 of the battery pack plug it shows 9.4v. Which seems a bit weird to me!
Since the battery is three sets of three 18650 in series that means each set of three cells is at 3.4v. That's not discharged so I would have thought I should be seeing at least one or two LEDS.
I'm guessing that I've broken the board at some point? Before I go any further does the sound about right? I'm a little out of my comfort zone here
Thanks!
Thanks!
