thanks man, with everything already in the cart... in the end I couldn't help but doing it
BTW is this really everything needed, or should I check the BOM anyway and find which missing parts I would still need?
In case other people would be interested, notice that some of the listed components in the cart are marked "END OF LIFE", so...
better safe than sorry.
Now back to me: I have a spare board which has been hanging around for a couple of years, I have a spare battery bombed SE/30 in need of a new board, I will get the parts... I guess it's really time to do this - even if I really feel I will need some help. Wish me luck![]()
They're the F240 (RAM buffer?) and SN75175 (serial line driver) chips. They're indeed scheduled to cease production.some of the listed components in the cart are marked "END OF LIFE"
Ouch.. from where do you know that?They're the F240 (RAM buffer?) and SN75175 (serial line driver) chips. They're indeed scheduled to cease production.
Here…https://tinkerdifferent.com/threads/texas-instruments-discontinuing-a-lot-of-ics.3190/#post-37526Ouch.. from where do you know that?
Can you please provide a link? Because I have considered that thread on TD as fake news…Although both say end of life on Mouser
Did you do that?When using the PLCC sockets make sure to bridge the two solder switches on the bottom of the board at the marked (V) position.
Yes they are bridged. I don't think the screen would have shown anything without access to the ROMs?Did you do that?
So on the reloaded board, I socketed everything that was ...ahem... socketable. The reasoning was that eventually I would do more boards and could use this initial board to test all IC components.
I found the sockets a bit of a bother and cut away the bottoms to solder them on to the board. The bottom of each socket has a non-conductive card of a similar thickness to keep the IC at the correct height when inserted.
I've carefully checked and sounded out the ROMs and FPU to the CPU on my meter and scope.
The CPU, video rom and PALS HAVE all been tested as working on another SE/30 that happened to have all these ICs already socketed.
Does this look like a Video RAM issue?
