Realtek RTL8139D PCI Network Card Compatible with a PowerMac 6500?
Searching for a compatible networking card for the Power Mac 6500/300 I recently bought at VCF Southwest. Great bridge Mac but no networking. Apple Slot II cards start at $100 and are made with the RTL8139 chip. What I've read online indicates that any PCI networking card made with this chip is compatible and their starting price can be as low as $10. So if I were to buy this card, is it compatible with the included PowerMac drivers? I don't want to buy anything that's physically compatible but Apple's software won't recognize.
If you know of specific 3-party networking cards that are compatible, please let me know.
Thank you for your time and attention,
Gerry
This should work in any Mac with a PCI slot:
(I have one I've used in a 6500)
Mac drivers here (I don't believe any of the Apple distributed Ethernet drivers (extensions) support this Ethernet chipset):
993v14.sit.hqx which is include in the #1 download.
If you want to use the 2 6500 PCI slots for other cards (display/video cards, USB, Firewire, etc) a cheaper alternative to a Apple Comm Slot II Ethernet card is this recreation:
There are CSII cards with the Digital 21040 chip as well. I've got one, but no longer have anything to install it in.
It appears that these work in the 6500 - https://discuss.haiku-os.org/t/power-mac-6500-audio-in-beos/12481 (the problem there is no sound in BeOS, but the CSII card's ethernet worked fine)
...but here it looks like pizzigri was having issues getting them to work with MacOS 8.6 -https://68kmla.org/bb/index.php?threads/apple-ethernet-csii-card-no-boot-in-a-6500-board.43802/ (there was no response or update, so a bit inconclusive on the outcome)
The RTL8139 PCI card does require drivers, it doesn’t work with built in. The CS II with digital 21040 works without drivers but is 10 megabit only. Not that you’ll get anywhere near 100 Mb/s with OpenTransport anyway.
Read the bizarre caveats to the CS II recreations before purchasing one. Think what other similar decisions may have gone into the design of those cards.
My goal here is to be able to FTP between the Macs, Apple IIgs and Win 11 PCs on my local network. If I need to work on the internet, then I have my M1 MBP and Dell Win 11 machines. Yeah and to play too.
A new question. Is there a browser that runs under 9,1 that handles secure connections (https://) as well as display webpages like modern browsers Chrome and Firefox?
Thanks everyone for the help,
Gerry
I’m only aware of Classilla 9.3.4, which can do modern https (TLS) stuff if you set up Crypto Ancienne to handle the encryption. I have it set up on my 8500 where I can run it in the background and use Classilla to browse. Note that only version 9.3.4 supports this.
I’m not aware of any other solution, but if there is one, I’d love to hear about it, too.
I'm updating the thread with the lastest issue I've run into. The PM6500 is up and on the network and can talk to my LC475 without issue. It's not the same with the SE/30. I'm using a BlueSCSI with WiFi to get it on line and that works great. But the SE/30 has it's own network called 'Alternate Ethernet' to use the DaynaPort drivers to connect on line. Since the PM6500 and LC475 have ethernet cards and are hardwired to my local network, they are on an 'Ethernet' network but it appears to be isolated from from the SE/30. I have Appletalk on and I log into the LC and PM and they talk to each other. So how do I join the SE/30 to the 'ethernet' network so everyone can talk to each other? And what about my Win10 and 11 laptops along with my Synology NAS? I would like to have everyone sharing files. So, why are there two Apple ethernet virtual networks and how can I get everyone talking?
Thank you,
Gerry
You could try the PCI cards with the RTL8169S chipset on it.
These are gigabit ethernet cards. I have one in my B&W G3.
I don't know if the driver works below Mac OS 8.6 though.
Thank you,
Gerry
The ‘Alternate Ethernet’ wording doesnt have anything to do with being on a separate network. IIRC, it’s something to do with the type of driver. So your issue is elsewhere.
Right.
Don’t you have to have Open Transport in order to do AppleTalk over Ethernet? I thought the old System versions only could do AppleTalk via serial.
@GerrySch what version of OS is on the SE/30?
This is so wrong that it can't even see 'correct' on a clear day with a telescope.
Pre-OT, it'll be in the Network control panel. If there's no Network control panel, then the AppleTalk software isn't installed.
Well, that’s very helpful. Care to contribute something worthwhile to help the guy?
Weird, I'd assume that "stopping OP going down a rabbit hole on totally spurious information" was contributing something worthwhile; I appreciate that in some circles it has become fashionable to make confident statements based on things pulled out of one's backside, but if you don't like being called on it, perhaps try not to do it for things that are quite so trivially verifiable?
OP, if you don't mind my asking, did you make sure the AppleTalk control panel on your SE/30 has EtherTalk selected, and not the printer/modem ports? I'm almost sure you've already thought of this, since it'd be how you got the other Macs to see each other in Chooser, but that setting frequently seems to revert to default on my machines.
Come to think of it, does anyone more clever than me know if the AppleTalk port setting is a PRAM var? People often treat their SE/30s with extra care and leave them battery-less, so it'd at least explain why that preference won't persist.
Wouldn't claim to be cleverer than you, but yes, it's PRAM, and it's opened early enough in boot that things like PRAM auto-restore won't auto-restore it (unless they special-case it which none of the tools I've seen do).
That would be the ‘Alternate Ethernet’ option that they said they selected.
Good point about that setting possibly not being held after shutdown, in case they don’t have a PRAM battery or an ATtiny85 based RTC.
To the OP, it would be worth considering picking up an SE/30 PDS Ethernet card that will provide much more reliable networking than DaynaPort emulation.
Perhaps you need to brush up on your comprehension of the English language; posing something as a question, complete with the phrase “I thought” hardly qualifies as a confident statement. To most, that would indicate quite clearly the poster was NOT confident in the information. Also, there’s no call for arbitrarily and repeatedly being a prick.
Now, back to Gerry’s problem...
