I have been thinking about getting one for several years now and I finally decided it was time, I bought myself an original Mac II! Should have done it years ago, I LOVE this thing!
Here's a pic of the Mac II right after I had gotten it fully working but before I cleaned it.
You may notice those little labels next to each disk drive slot, this is one of the reasons I bought this machine! The "FDHD" label told me this machine more than likely had the FDHD upgrade, which it did thankfully! For some reason someone had pulled the FDHD drive so it was missing. I had a broken one on hand I was able to actually fix though so I got that installed and it's working great now. The original 800k drive on the right was still present and cleaned up well.
Here's some internal shots.
Still has the original 5.25" Quantum 40MB drive! More on that later...
Also, this has the earlier revision motherboard, which is another reason I wanted it. No nasty SMD caps here! Has all axials like the SE. I added those two CR2032 battery holders which are working great so far.
And it came with an Apple High Resolution Video Card, which needed recapping badly. I managed to scrounge up enough caps to get that done, but it still showed lines on the display afterwards. It otherwise worked though. Turns out there was one bad trace going from the F521DW to one of the VRAM chips. Once I patched that, it was working perfectly with no lines!
Before this machine arrived I also ordered one of the original "Toby" video cards too just in case I wasn't able to fix this one, which is actually installed in the machine now. I didn't think to get a pic of it!
So back to the hard drive. It was working fine but these drive have a known issue where the rubber bumpers inside melt and allow the heads to smash into the spindle when they park, which will eventually cause one or more heads to come detached from the arm! Of course the drive is done for at that point, so it needs to be fixed before that happens. So I had to pop the drive open even though I really didn't want too...
What a pretty drive on the inside though! The bumpers in these drives are an odd design unlike any other Quantum drive. It has this nylon piece with rubber behind it. When the rubber melts and shrinks it causes the nylon bumper to recede further and further until it starts to cause issues. I ended up fixing it with a cut-up drinking straw, which is kind of hard to explain and I once again did not think to get a pic of this repair! The drive still worked fine after reassembly and I let it run for several hours just to make sure it was all good. This was a week ago and it's still running great!
Now, 40MB is pretty small for everything I want to put on this machine and I have already almost completely filled it, so I will be looking at upgrading the drive. Since this is going to be one of my main classic Macs now I want it to have a bit more internal storage at least. I want to find another 5.25" SCSI drive of a larger capacity for it, because the whole idea of an internal 5.25" hard drive in a Mac is just so cool to me! And the sound is awesome. There is an 80MB version of this Quantum drive which would be a decent upgrade. Not sure exactly what I'm going to get yet.
I had been using an LCD monitor with this machine, which actually worked really good, but as of yesterday that changed!
I actually got my High Res RGB monitor working and adjusted properly! I have had this monitor in storage for over ten years and thought was in bad shape and needed serious work, but it actually didn't! These monitors have tons of adjustments on the back and more inside. After fiddling with several of those I'm getting a very good image out of it now! The next even bigger issue it had was an electrical arching sound and ozone smell. I did some diagnosis and it turned out the sound was coming from under the annode cap, which gave me hope that it might actually be a really easy fix, and it WAS! I discharged the CRT, removed the annode cap, cleaned it, applied new dielectric grease, and no more arching sounds or ozone smell! I'm kind of embarrassed I have had this monitor for so long and thought it was junk, when it needed some very simple maintenace done, but hey, at least it's fixed now! Glad I never got rid of it. It's the later M1297 version and was made in 1992, so it was probably used with a IIci or something back in the day.
And yes, it's a lot more yellow than the Mac II unfortunately, but I'm not too bothered by it honestly. The camera flash made it look worse than it does in real life too!
Oh, and I also already had an Apple Extended Keyboard I found at Goodwill many years ago! I have the Extended Keyboard II also, but the original is what's correct for the original Mac II. I have the smaller Apple Standard Keyboard as well, but I use that for my SE.
I did upgrade the memory also. It had 5MB when I got it and I upgraded it to 8MB, which is the highest you can easily go in these. I hope someone will eventually offer reproduction PAL SIMMs for these! I would love to get it up to 32MB someday.
So there is my Macintosh II! I love my compacts but I have really been wanting a good color 68k Mac lately. I've had some LCs and even a IIsi, but never really got into them. But this Mac II is a whole different story! THIS is what I have been after as far as "look and feel" and everything like that. It looks so damn cool! I love that's it's pretty much the same form factor/size as a typical IBM or compatible PC of the era. And it's very heavy and built like a tank. Such a well designed machine.
I will definitely be making some more posts here about this machine!
