I recently got a scrap Mac IIcx, mostly to get its case for a different project, but still tried to clean and recap the board to see if it could boot. I did not attempt to power this logic board at all until the recap and washing/drying were all done, in case stray goo fried anything. The battery was on the verge of leaking, with a brown spot forming on the edge and terminal, which I quickly neutralized and cleaned off before disposing of it. All of the caps are on and have the expected continuity, with C4 and C11 notably tripping my multimeter's continuity tester, but the pads for these were making it beep already, so I know they are not solder bridged. I lifted and resoldered them to be extra certain of this before powering on. Some of the legs on the ICs in the power circuit are dull-looking, as are the ROM legs, and the rear ports are superficially pretty corroded/rusted. However, I did not see any green on any ICs.
After a final clean of the board, a rinse in isopropyl, and a long dry, followed by checking all the connections again, I powered it on using a known good PicoPSU with a ten pin adapter. As soon as I threw the switch on the PicoPSU, I got immediate slow chimes of death. I was doing the first test without RAM, so I expected the normal chimes and knew something was up. I put in four known good 1MB SIMMs and got the same issue. I do not have a NuBus video card on hand nor a PRAM battery, but from what I've seen searching here, neither of these should be necessary to get a normal chime(?) Checking the diagnostic mode over a null modem showed return code 0000FFFF0001. I see that the '01' status is a "ROM checksum error," according to this archive of the only informational page I've seen for the diag mode. However, I'm unsure how much of this applies or is reliable. I cannot find any obvious continuity problems with the four ROM ICs. I also put in a spare SE/30 ROM SIMM and the result did not change, so I'm curious if this could be a less obvious issue such as a bus transceiver.
Does anyone more familiar with the IIcx have an idea what could be wrong, or any similar experiences? I'll attach some hi-res photos, but note that the few dubious looking traces on here all beeped out fine when I checked, unless there are even more that I've missed. This machine looks like it sat unused for decades, so I have no idea about its history, why it was partially gutted, or whether the logic board was working at all when the last owner stored it. Compared to the dusty, dead spider-covered state it was in when I got it, it at least looks close to working, though that obviously doesn't count for much when a mystery component is probably fried.
Edit: I did check the ROM socket with the frequency tester on my multimeter, and saw various, stable frequencies from each pin. None appeared to be dead/disconnected.
