Hi all,
I'm at the stage of my self-taught-repair-skills journey where I'm just knowledgable enough to be dangerous. Case in point: I have two 128k Macs - one "standard" and one which was upgraded to "Fat Mac" status, and both had issues:
- The Fat Mac would power on but it would take several minutes before the display would come up, and even then it was extremely sensitive to any movement - even light bumps or movement of the desk would cause the display to flicker wildly or just turn off. I carefully reflowed all the solder joints on the analog board, paying extra attention to the soldering of the flyback and the cable sockets. Now it's working like a champ!
- The Standard 128k was dead as a doornail, no beep at power on, nothing on screen, no floppy sounds, etc.
Feeling confident after getting the Fat Mac running well, the other night I went through and carefully replaced each capacitor on the "Standard" 128k's analog board with new ones purchased in a kit from Console5. I'm not the most experienced or knowledgeable solderer but I have decent tools (including a Hakko desoldering pump) and I followed a really nice step-by-step video on YouTube as I progressed. I was super careful about ensuring that the polarized caps went in with the right orientation, I did my best to ensure that my solder was neat and not shorting anything. etc.
Unfortunately, when I finished and tested, it was only a partial success: now the machine gives a nice loud beep at power-on and I can see the "heater" at the back of the CRT glowing (and the flyback transformer gets warm), but there's never any indication of an image at all onscreen. Bearing in mind that I'm a beginner with this work, I've done the following:
Thanks for any advice!
Huxley
- I've worked the brightness knob - it's definitely set to full brightness
- I've visually inspected my soldering work and redid a couple spots where it didn't look perfectly uniform
- I've carefully reflowed the solder joints on all basically everything, including all the plug connectors on the analog board
- Double-checked the polarity of the caps I installed
- Carefully re-seated the "suction cup" into the CRT glass
Huxley
