I have a Power Mac 7100/80 with a distorted chime and no video output. Probing the onboard memory there is reasonable activity up until right after the end of chime when the CPU appears to crash with what looks like just noise on the address and data busses.
Machine does not respond to any key combinations at boot time that I've found except ctrl+apple+power for reset, but holding down NMI during reset does produce the silly car crash sound which does not sound distorted like the chime (although it's a bit hard to tell).
What is done so far:
Now I'm suspecting bad onboard RAM. So my question is if it's possible to run the 7100 without the onboard memory entirely using only SIMMs? Of course the onboard video probably will not work but it would be an interesting test. Just want to verify my assumptions before I start de-soldering. Anything else I should try? Is there maybe a quick way to disable the onboard RAM without desoldering chips?
- Verified power rails good
- Running the board without SIMMs, cache module, drives or other nubus cards
- Replaced dried up thermal compound under CPU heat sink
- Tried moving the ROM card to the cache slot since they are in parallel
- Tried a different known good power supply
- Replaced all capacitors. They did not appear to leak and non tested totally bad after removal but replaced them anyway
- Tried another known good PDS video card
- Replaced battery with a CR2032 (voltage high enough?)
