Hi All,
Now that I've upgraded about 15 of these, I thought I would offer some tips here. I upgrade them to install Mac OS 9 on them using the image from https://macos9lives.com — so these are with that lens in place.
Tip 1: Get the right model
Only model A1103 has a G4 in it. Make sure you get an A1103! Obviously you can't install Mac OS 9 on anything else. If the seller doesn't list the model number just make sure it has exactly 2 USB ports and 1 firewire port on the back.
Tip 2: Open them very slowly
I won't go into the details because iFixit already has a guide for actually taking them apart and changing various parts. But by far the trickiest part is initially separating the case. I use a butter knife that I have found to work well—even better than the custom tools you can buy. But before I got good at it I broke a couple cases with brittle plastic. You need to be very careful and slowly separate the two sides with a sharp edge, one little bit at a time. Take your time and if it seems like it's bending too much, stop and try another spot to separate from.
Tip 3: Get an SSD via an IDE to mSATA Adapter
There are several that can work but I've had a very good experience with these ones on Amazon (as an Amazon associate I earn from qualified purchases). Then you can get a 128 GB mSATA SSD on eBay.
Tip 4: Don't forget to change the clock battery while you're in there
The CR2032 is the same used in AirTags. Get a quality one like a Duracell that you won't have to change again and won't leak. It's like an extra 50 cents.
Tip 5: OWC still sells new RAM for these machines
Tip 6: Thoroughly clean everything but especially don't forget the fan and heatsink
When you change the HD for the SSD you will have to unhook the fan anyway. You will find there's an open side of it for air intake. It can be very dirty in there. Also as you are thoroughly cleaning the whole insides be sure to run a q-tip over the heatsink. There can be so much dust in there. You may need something more pointy to get it all out.
Tip 7: Use the right screw drivers
I use three different size screw drivers every time I dismantle one of these. In particular it helps a lot to use the right screw driver when taking the fan off. Those screws just will not turn well without a perfect fit.
Tip 8: Get a 1.25 or 1.42 Ghz one for the best compatibility
Although they share the same model number (A1103), late in 2005 Apple improved the specs on the two Mac mini G4 models from 1.25 Ghz and 1.42 Ghz to 1.33 Ghz and 1.5 Ghz respectively. However, these new machines also had slightly updated video cards. Unfortunately, although these "silent upgrade" variants are faster, they tend to have issues with the hacked version of Mac OS 9 displaying high resolutions. Some people have found workarounds but most just use them at lower resolutions. It may actually be preferable to have a 1.42 Ghz machine to a 1.5 Ghz machine in the current state of Mac OS 9 on them. But the 1.5 Ghz machines are rather rare anyway and we don't always have them in stock. But they are the fastest you can go!
Tip 9: Get USB Speakers
The hacked version of Mac OS 9 only works well with USB audio. The Logitech S150 are cheap and work well in Mac OS 9.
Tip 10: Get a Contemporary Apple Mouse
There are issues sometimes with newer mice. The best compatibility is of course with an early '00s Apple USB wired mouse.
Tip 11: 110 Watt Power supplies work
The original power supplies were 85 watts. But the ones from slightly newer Intel Mac mini models that used 110 watts will work too. It's not ideal, but it's okay if it's all you have.
Tip 12: Replace Missing Screws
I've found many of these have missing M2 screws connecting the logic board to the case. M2s are hard to get but your local hardware store (in the USA where M2s are harder to get) may have a "miniatures" section that will have some imperial size units that will work. Bring a remaining screw with you if you have it.
Tip 13: Be Ready to Spend $120+ doing this yourself in the worst case scenario if you need all the parts
Here's a rough breakdown:
- Used generally "untested" Mac mini G4 on eBay ~$60 with shipping
- Power adapter if it didn't come with one $15
- IDE to mSATA adapter $13
- 128 GB mSATA SSD $15 if you're lucky
- 1 GB RAM module from OWC ~$15 with shipping
- Contemporary Apple Mouse $5 if lucky!
- Logitech S150 Speakers $15
- Clock Battery $1
- Missing Screws $1
It can be a lot of work, but it's a pretty great machine for Mac OS 9 enthusiasts. Mac OS 9 doesn't really get much faster on real hardware. It takes me about 3 hours to do each one properly including the cleaning and installing Mac OS 9.
If you don't have the stomach for it, you can buy an upgraded one directly from me on eBay with the bundled accessories or from my new website.
I'm happy to answer any of your upgrade questions that I can to help you get yours done.
- Clock Battery $1
- Missing Screws $1
