How do you feel about building something? If you're up for it, I've built one of these for my Lisa :Question, what storage alternatives are there to install and run LisaOS from?
Not just Apple!Where on earth did Apple come up with this design?
c
Might be just early technology, the keyboard brands using those foam pads (BTC, keytronic) moved over to the rubber dome type keyboard.Huh, interesting.
Why did they use it? Are keyboards with foam pads (that aren't crumbled, of course) somehow better than an equivalent mechanical one? I don't think the rubber dome membrane kind were invented back then, were they? Is this foam stuff one of the predecessors to that, maybe?
c
I'll let you know when mine is restored!I suppose so. But the Lisa was such an expensive, high end computer, the cost of a mechanical keyboard would've been insignificant.
Even the Mac, which was meant to be a more affordable alternative, used a mechanical keyboard!
There must've been more to it than cost. Feel, perhaps?
I'd imagine that the Lisa keyboard is significantly quieter and softer than an equivalent mechanical one, yes?
c
True that, bet no engineer ever said "let's make sure that they'll still be working perfectly in 40 odd years time"It's simple and robust, and works well for how simple it is. Until the foam disintegrates, but it's easy to forget how far beyond their rated lives we are using these things.
