Lindy mouse
I'm not familiar with the program, but try setting it to listen, then clicking the right button. See if data received says anything.
Edit - thinking about it, you need to read the registers in the mouse with the right button pressed and not pressed. ADB is mostly driven by the host polling the peripherals. I'm not familiar enough to remember what exactly needs doing.
nothing happens, no output at all
I find it easiest to open up “ADB Record” from the Window menu. When I move around my Pippin controller (which acts as a 2-button mouse by default) I see something along the lines of:
Code:
Poll Data Count:       $02
Data Buffer Contents:  $80 80
It looks like the data being sent is something like:
C:
struct MouseListen {
    int8_t left : 1;
    int8_t y : 7;
    int8_t right : 1;
    int8_t x : 7;
This machine is on System 7, so no contextual menus. I’m not sure if they would work out of the box.
One thing to be aware is that some devices need to be told to provide more information. The controller’s other buttons don’t appear in the data and won’t unless told. I think the extended keyboard is like that too.
this is all i get, no other window or info
Data Buffer Contents of $03 FE is consistent with left-dragging down and to the left, I think. If the mouse is perfectly still, I’d expect $00 80 for left-click, $80 00 for right-click, and $00 00 for both.
just picked up an alps adjustable adb mouse NIB with software. installed the software and plugged in the mouse. i get every click option available but still no right click with any software, even using themouse2b nothing is registered. was the 68k series challenged or could my install of 8.1 be faulty?
So i figured i would post an update to this thread, i found out how to get the control click to work on 68K macos 8. It's called the mouse2b control panel and a "very" special ADB mouse.
That sucker set me back $150 but it's worth it. mouse in question is a NeXT ADB mouse. it arrived this morning and i finally got home to try it out. yes, control click works properly with the control panel installed. when i have a little more time, i will upload screenshots and pics
Interesting, this same setup only works with the NeXT mouse, not with any other two-button mice you tried?
I have a similar 2 button mouse from "macally" and it cam with the driver "Point Device v3.0"
It looks identical to the Lindy mouse except that it has a different logo. The mouse in the "Macintosh Repository"-link looks a bit different.
You can define the 2nd button freely to any key combination.
-Jonas
Interesting thread, I've been searching for a 2 buttons mouse for some time and some really are one button mouse with 2 buttons.
For example this one I got not long ago, the Sanwa Supply small confort mouse MA-402MACMD
The product webpage show this
If I look at another model from the same brand and its specs, you'll see the difference in the compatibility info at the bottom.
The control panel looks like this:
It's downloadable at
Also interesting:
from archive.org:
2bt mouse manual: Macally Two Button Mouse Manual
Point Device 1.0: Macally Two Button Mouse Driver - v1.0 (68K)
Point Device 3.0 should be a FAT and work on 68k (i am pretty sure that my father used v3.0 on his 475)
Point Device 3.1: Macally Two Button Mouse Driver - v3.1 (PPC only)
Point Device 3.5: Macally Two Button Mouse Driver - v3.5 (PPC only)
Point Device 3.6 (final): Two Button Mouse Driver v3.6 (PPC only)
Mouse Sprokets (old): Two Button Mouse InputSprocket - v1.0d1
Mouse Sprokets up to 8.6.1: InputSprocket for Macally Two Button Mouse
Mouse Sprokets for OS9: InputSprocket for Two Button Mouse v1.7b5
i'll look into all those here in a bit. i wouldn't mind seeing if the lindy mouse i have works again. i like the shape of it better than the next mouse but i knew steve allowed proper ctrl click with those
ok, was able to get the downloads that you mentioned, so now i will try to get this mouse to work. will keep you updated
ok, so my lindy mouse is acting stupid, i can move side to side and down no issues, i can't move up without trying to mash the mouse into the mousepad and constantly trying to scroll upwards, so trying all this on my alps 3 button mouse and the next mouse
**doing all these tests on a Performa 637CD with 132 MB ram and a 68040 33 Mhz on MacOS 8.1**
**disabled mouse2b control panel in order to check each of these out**
- installed mouse commander and got a crash: bus error on startup...
- installed macally mouse installer 1.0.3 and installer corrupt. not installed properly and won't see the mice even though it says that the mouse will work like a normal 1 button mouse *also glitched out my computer, had to boot into safe mode to remove those files*
- installed macally point device 3.0 *says can't find macally mouse so reattaching lindy mouse for testing*
*software see's the lindy mouse but now mouse doesn't move at all*
ok, so after bending the sensor for vertical movement, the lindy mouse reacts properly. side to side and up and down, and right click works
