There isn't, and here's why....the microcontrollers used with ZuluSCSI are limited to ~1MByte/sec (USB Full Speed), not USB High Speed. If you want to add the ability to access files via USB, the firmware is open source. We accept pull requestsI was hoping that using a USB cable I would be able to see the contents of the HD files and write to them. However plugging in the appropriate Data capable cable doesn't do anything other than power the device. I've read the official documentation and the section on "Transferring Data" doesn't exist.
Can anyone tell me if there is a way to access the data stored in the images across USB. I have everything from my old mechanical drives archived and would like to simply restore that data to the ZuluSCSI.
I realize I can use an image reading program, but is there no other more direct way? Thanks for your time.
