Macintosh Classic II checkerboard display
Macintosh, 512k, SE, etc.
Postby cppursell » 07 Mar 2008, 05:59
Hi. I just got my hands on a Macintosh Classic II, shipped to me for free from a guy who said it worked fine.
I plugged in the keyboard, mouse, and power, and flipped the switch, and voila! A nice black and white checkerboard on display. I restarted it many times, and it mainly sticked with the checkerboard, but occasionally went to thick vertical lines, and only a couple times showed a white screen. It also occasionally emitted a quiet, but high pitch noise.
I opened up the computer (thank God I had a torx screwdriver that fit) and cleaned the contacts on the RAM as suggested from another forum: didn't work. What now? I'm hearing advice such as "replace the capacitors" to crazy stuff like "wash the motherboard in the sink". I REALLY want to have this classic Mac to play with; but is it doomed to become a Macquarium instead?
Thanks ahead for your valuable help.
cppursell
Re: Macintosh Classic II checkerboard display
Postby iMac600 » 07 Mar 2008, 09:25
Replacing the Capacitors will fix it for good, washing it in the sink will remove the electrolytic fluid that has leaked from said capacitors. It does conduct, so it bridges the traces and causes the aforementioned problems.
Most electronics repair shops should be able to replace the capacitors if you can't yourself.
G-Division (New World Engineering, Performance and Medic Operations)
MacBook Core 2 2.0GHz, iMac Core 2 1.83GHz, Macintosh 512Ke, iPod 1G 5GB, iPhone 3G 8GB
User avatar
iMac600
Postby cppursell » 07 Mar 2008, 15:07
Okay, I'm guessing I can go to an electronics store or Radioshack to get some capicitors, but I have no clue what to get, or which ones to replace, can I get some help in that area?
cppursell
Postby Hulotte » 07 Mar 2008, 22:41
Well "wash the motherboard in the sink" is not a so crazy stuff.
I made it a few days ago with a classic II that was only showing vertical black and white stripes.
And.... now, it works !!!
Hulotte
Postby tomlee59 » 07 Mar 2008, 23:47
Whether or not you replace the capacitors, you still need to wash the board. And although it does sound nutty, a dishwasher is a perfectly fine device for doing exactly that.
The capacitor-replacement expert here is probably JDW. But until he chimes in, I'd say that a good choice is a tantalum capacitor. Modern ones have no liquid electrolyte, so you wouldn't suffer a repeat in the future. The exact capacitance is wholly unimportant (almost all of them are just "shock absorbers" connected across the power supply terminals). Just don't go lower than, say, 25% below the original capacitance value. Also, make sure that the voltage rating meets or exceeds that of the capacitors you are replacing.
If you've not done this sort of operation before, it's a good idea to practice first (say, on a junk PC card or board). Once you've gotten confident in your ability to remove a capacitor without destroying the pc board traces, you'll be ready for the real thing.
User avatar
tomlee59
Postby cppursell » 08 Mar 2008, 03:05
Okay, I can get the capacitors at Radioshack. As for washing the board, I just want to be a little careful: Should I use detergent? The dishwasher uses hot water, is that okay? When drying, should it be room temperature air dry for a week or so, or speed dry it in the washer?
Last but not least: which board? There's a green one that has the RAM in it laying horizontally, and a tan one standing up on the side that I see at first glance. And, where exactly are the appropriate capacitors to be replaced?
Thanks again
cppursell
Postby equill » 08 Mar 2008, 05:41
A dishwasher is indiscriminate in where it squirts liquid. A rescuer of a Compact AIO does better to use a spraybottle, which can be varied from an intense jet to a misting spray, and thereby also directed to badly affected spots. The whole board should be washed, certainly, with clean warm (40-45°C) water containing a few drops of a non-ionic (most kitchen detergents are so) detergent in a pint or so, and then liberally washed with clean warm water.
Blot the surplus moisture off the board with a paper towel, and then set the board aside (vertically, to assist drainage) for several days, or leave it in a draught, to dry completely before further work is done on it. One essential inspection then is against corroded or broken board traces. Only if the board is physically intact is the effort of recapping going to reward you.
de
Apple IIe; 68K: 20DT/T + 5PB; PPC: 9DT/MT + 3PB + PTPro; G3: 7DT/MT; G4: 3T
User avatar
equill
Postby tomlee59 » 08 Mar 2008, 05:47
cppursell wrote:Last but not least: which board? There's a green one that has the RAM in it laying horizontally, and a tan one standing up on the side that I see at first glance. And, where exactly are the appropriate capacitors to be replaced?
Thanks again
The logic board is the one you want to fix -- it's the one with the RAM, and you should be able to see smudges of residue from the leaking capacitors. It is usually fairly obvious. The capacitors in question are the ones by the smudges, as well as the others of the same type.
Whether you use equill's more refined washing procedure or the "scorched earth" dishwasher method, you'll want to remove the RAM simms first.
User avatar
tomlee59
Postby Hulotte » 08 Mar 2008, 18:10
Yes and also the ROMs should be removed before washing. That's what I did.
Hulotte
Postby equill » 08 Mar 2008, 19:21
Not all Mac ROM chips will co-operate in being removed (as is often the case in a Classic II), but if they are on a card (as in an SE/30), your suggestion is worthwhile, if only to make drying the MLB thoroughly so much easier.
de
User avatar
equill
Postby cppursell » 08 Mar 2008, 20:21
Okay, I've taken out the green motherboard with the RAM in it, but I'm not sure where the capacitors are; can you point them out to me? Here's a link to the two boards in question, the green board with the RAM, and the tan board standing on the side:
http://gallery.mac.com/cppursell#100081
cppursell
Postby equill » 08 Mar 2008, 21:23
You are looking for 3 x 47µF/16V, 2 x 1µF/50V and 12 x 10µF/16V caps, most of them in the rear half of the MLB. They appear as (mostly) bright circles in your left-hand pic., and as little vertical cylinders on the board, with a number prefixed with 'C' screened onto the board near each one. C74, C79 and C106 are in the front half of the MLB.
This post gives you some idea of the replacement process and a potential source of replacement caps (tantalum electrolytics).
If, however, you are as unfamiliar or uncomfortable with the whole notion of replacement as you seem to be, you may wish to explore having someone else do it for you.
de
User avatar
equill
Postby cppursell » 09 Mar 2008, 06:58
Okay! I washed it in the dishwasher, then blot dried it, and now it will sit upright peacefully for a week!
I went to the electronics store to get replacement capacitors, and found it to be a little too expensive for this project ($25). I just hope that the existing ones will work for the time being. Besides, I think it would be a long, daunting, frustrating task to replace 13 capacitors. Oh, the store can do it for me, for only $150 an hour...
Thanks for your help and advice. I'll let you know if the washing technique worked. For now I'll just be stuck with my other computer... my Macbook Pro :P.
cppursell
Postby cppursell » 09 Mar 2008, 22:14
The computer works now!
I couldn't wait a week, I just let it finish drying overnight, probably not a wise thing to do.. but it worked.
I have an 80mb hard drive, and 4mb of ram. Cool!
I posted a thread asking this, but I can ask here too: Where can I find some applications and games for this machine (like a website)?
cppursell
Postby equill » 09 Mar 2008, 22:46
Good to hear that it is working for you. Just keep in the back of your mind, though, that will fail again at some time unless the caps are replaced. Foe me, a recent Classic took only 10 days or so from checkerboard to checkerboard via the spraybottle. However, that was long enough to get from System 7.1 to 7.5 and back to 7.1.3. 68000 processors are easily intimidated, but your 68030-driven Classic II can give you much good service.
For software there is a hot place nearby (rather than down below), and those who know of it will direct you.
de
User avatar
equill
Postby Mac128 » 10 Mar 2008, 01:24
cppursell wrote:cleaned the contacts on the RAM as suggested from another forum: didn't work.
Are you sure they said RAM?
The checkerboard problem is common on the SEs and Classics. The solution is usually to re-seat and or clean the ROM connections, not the RAM. The M0001s had similar vertical stripes related to ROMs as well.
Washing the logicboard likely resulted in a similar effort and/or water trapped in the sockets is actually enhancing the connection. Once the board thoroughly dries, you may once again get the pattern. Either way, you are luck your impetuousness didn't short out the whole board.
Granted this was the prescribed procedure 15 years ago before those caps started leaking all over the place. Nevertheless, try cleaning those ROMs if you didn't. Why Apple decided it was a good idea to go from 2 to 4 ROMs is beyond me. The Classic only has one! Was it a counterfeiting countermeasure moving to so many ROMs?
User avatar
Mac128
Postby cppursell » 10 Mar 2008, 01:28
I'm pretty sure the ROM wasn't the problem, and the capacitors are still bad, I can sometimes hear them whining. I'm sure the computer will eventually fail again, and then at that point I'll decide whether replacing the capacitors will be worth the effort.
cppursell
Postby tomlee59 » 10 Mar 2008, 03:40
cppursell wrote:I'm pretty sure the ROM wasn't the problem, and the capacitors are still bad, I can sometimes hear them whining. I'm sure the computer will eventually fail again, and then at that point I'll decide whether replacing the capacitors will be worth the effort.
Yes, it's neither the RAM nor the ROM. After having fixed countless of these things, I can say with confidence that it is very rarely due to a memory contact problem of any kind. Since it's easy to check, doing so is the first thing to try, but washing the board and replacing the capacitors is the way to solve the problem in nearly every case. No speculation is required -- a simple visual inspection will reveal whether the capacitors are leaking.
The SE, SE/30. Classic and Classic II all suffer widely from this malady; the original compacts do not. I don't have enough experience with the Color Classic/II to say whether this problem affects those models, too.
User avatar
tomlee59
Postby Mac128 » 10 Mar 2008, 06:14
Yes, it's neither the RAM nor the ROM. After having fixed countless of these things, I can say with confidence that it is very rarely due to a memory contact problem of any kind. ...
Tom, I don't doubt this is the case, given your experience. However, I'm not sure how a problem can be dismissed without checking, especially since all the repair guides I've read indicate this as a likely problem. In particular, I received an old Classic II from eBay a few years ago, advertised as being in a closet, with no power cord, keyboard, etc. to test. When I got it, it did not boot up and displayed a checkerboard-like pattern. I consulted Pina's SE & Classic Macintosh repair book and he described re-seating and cleaning the ROMs. That was all it took and the thing booted right up and runs fine today. None of the repair books of the day mention a word about leaky caps, which obviously wasn't a problem then as now.
For cppursell, this is moot.
Now, in a related issue: I completely understand that the Classic & Classic II would suffer this problem identically given their similar logicboard designs and as I have pointed out before, the first compacts to use entirely surface mount technology. What I don't understand is how the SE & SE/30 can exhibit the exact same symptoms, while the M0001 logicboards don't given that they are the exact same technology construction-wise, particularly the SE, which uses what appear to be identical capacitors in a similar ratio as the Plus. If the caps don't leak on the Plus, why the SE? It's more understandable with the SE/30 which at least uses SMDs similar to the Classics.
As for the Color Classic, I have never seen an SMD related issue. Though Stuart Bell over at Applefritter would be the guy to ask.
User avatar
Mac128
Postby tomlee59 » 10 Mar 2008, 11:50
Mac128 wrote:Tom, I don't doubt this is the case, given your experience. However, I'm not sure how a problem can be dismissed without checking.
Sorry that what I wrote was unclear. I meant to emphasize that since it is so simple to check ROM/RAM that one should certainly do so. We are in total agreement here. That said, capacitor leakage is a far more likely cause of this symptom, although certainly not the only one. It is just that memory sockets are not that bad, and there is certainly no reason why the classics should suffer inordinately from such a problem.
User avatar
tomlee59
Postby equill » 10 Mar 2008, 13:22
tomlee59 wrote:... The SE, SE/30. Classic and Classic II all suffer widely from this malady; the original compacts do not. I don't have enough experience with the Color Classic/II to say whether this problem affects those models, too.
http://68kmla.org/forums/viewtopic.php?t=3277
de
User avatar
equill
Postby Mac128 » 10 Mar 2008, 16:36
tomlee59 wrote:
Mac128 wrote:I'm not sure how a problem can be dismissed without checking.
Sorry that what I wrote was unclear. ... It is just that memory sockets are not that bad, and there is certainly no reason why the classics should suffer inordinately from such a problem.
No you were clear ... I meant for someone who does not have your experience diagnosing hardware problems. On threads like this, for future use, I like to emphasize trying the easiest things first – not that anybody actually searches these forums for info. In particular our friend demonstrated the dangers of throwing a board into the dishwasher, by not waiting as long as he should have for it to dry. While I've no doubt of the procedure's value, failure to follow simple directions in such methods can be devastating. Anyway, my experience with re-seating RAM & ROM is that many of these old Macs have been stored in places that encourage corrosion, or the same heat expansion that doomed the Apple ///.
One interesting side note regarding how bad the sockets are ... Pina goes into some detail about the Classic ROM socket. Evidently Apple took the low-cost philosophy down to the smallest part: he claims these sockets only have contacts on one side of the pin. Later Apple switched to the more robust variety which made contact with both sides of the pins. This is one reason the Classic in particular suffers from the checkerboard pattern. If that's true, given the capacitors propensity from this era to leak, compared to their older cousins on the Plus, who knows what kind of alloy the metal contacts on their cheap sockets might be made of or how likely it is to corrode. Not that this is the case here, just thought it interesting to note here.
equill, thanks for that refresher link. Interesting that cap goo hath flooded your logicboard like the Red Sea following Moses' passage, yet demonstrated no deleterious effects in powered use.
An interesting study would be spelunking through the depths of Apple confidential repair records to determine the frequency and cause of the majority of repairs of a particular Mac from the period and what lessons Apple took from it to effect future changes in parts or design.
User avatar
Mac128
Postby tomlee59 » 10 Mar 2008, 17:14
Again, to be clear, we do not disagree on the sequencing. That's exactly why I said nothing when you first advised to check the ROMs. It's only AFTER he experienced what I'd silently expected to be a null result that I chimed in. That was not an accident on my part. I waited until he reported on the outcome of Step 1.
So, by all means, having a person check the ROM/RAM as a first step is the smart and easy thing to do. In most cases involving the later compacts, however, that will not fix the problem. Just as easy is to see whether there are telltale smudges around the capacitors. That's why I chimed in with Step 2. And anyone advising someone who is troubleshooting this problem should mention the capacitors because they are a known cause of the largest fraction (by far) of these symptoms. Yes, I've seen a couple instances of bad sockets, but I've seen vastly more instances of leaking caps. So, in my experience (yes, it's a limited sample, but at this point, I'm willing to declare that my sample size is much larger than most people's), the statistics support a focus on the capacitors. Sure, many other faults could cause the symptoms in principle, but it's the capacitors that typically do cause the symptoms in practice.
User avatar
tomlee59
Postby Mac128 » 10 Mar 2008, 22:25
tomlee59 wrote:Again, to be clear, we do not disagree on the sequencing. That's exactly why I said nothing when you first advised to check the ROMs. It's only AFTER he experienced what I'd silently expected to be a null result that I chimed in. That was not an accident on my part. I waited until he reported on the outcome of Step 1.
To be clear, neither am I! And thus the dangers of posting on multiple forums. cppursell mentions nothing about capacitors on this forum and only said he checked the RAM SIMMs NOT the ROMs. Obviously there was more to his evaluation going on on another forum, to which you must have been a party. As always Tom, you exercise much restraint and a clear procedural aptitude along with your years of experience. I am certainly not questioning YOUR participation on this thread. Just trying to be clear about what I missed on another ...
Speaking of experts, it is surprising JDW has not weighed in on this one.
User avatar
Mac128
Postby equill » 10 Mar 2008, 22:47
Perhaps JDW was busy stirring another broth, somewhere? Even one for the delight of his household rather than his fellow soldiers?
Your point about potential confusion as a result of double- and out-posting is well made.
de
User avatar
equill
Next
Return to Compact Mac
Who is online
Users browsing this forum: No registered users and 0 guests
