Quadraman wrote:...so I have no way of knowing what the original serial number was.
MacOS wrote:Quadraman wrote:...so I have no way of knowing what the original serial number was.
Maybe you find the original Serial Number on the front case at the contrast button. An upgraded Mac to MacPlus has two SNs - one on the bottom of the back site case and one at the contrast button on the front case (this is the older, original one)
Sadly the SNs where added as stickers who disappear sometimes from the case.
Mac128 wrote:MacOS wrote:Quadraman wrote:...so I have no way of knowing what the original serial number was.
This actually raises a good question ... how should the dual serial numbers be handled? I think the original serial number should always override and that one should be next to the contrast knob on original 128K/512K bezels. If the front bezel is a Plus design, then the bucket bottom is the primary serial number. The second serial number should be added in the description field, or does there need to be a second serial number field?
If the serial numbers are missing, then that needs to be accounted for in the description field.
I have never actually come across a Plus upgraded 128K/512K. It seems odd to me that the case bucket would have its own serial number, but perhaps it corresponds to the logic board/bucket configuration. Can anyone confirm this?
Mac128 wrote:equill, the HD20 can not only be decoded but also included in the M0001 registry, as well as encouraged to do so ... Unfortunately I don't believe anyone has found a way to decode the Apple product serial numbers ...
Mac128 wrote:... As for your egregious omissions, I will happily update your entry ...
equill wrote:there is no provision in the database to record as fundamental a property of our wee beasties as the operating System(s) in use. With the luxury of a large non-floppy floppy drive and 2MB of RAM, I can and do use System 6.0.8, but the versatility of the marque at that time allows for a wide range, which is perhaps worth recording, as also is the reason for the choice?
equill wrote:If there are enough data or nuggets in a field to constitute a strike, findability is more useful than sortability, so search terms rather than field descriptors come into their own. The tools for a database must always fit the kinds and uses of the data.
Any thoughts about 'official' history recording? I believe that there were Apple & Educational consortia all around the world.
Users browsing this forum: No registered users and 3 guests
