LC squeaking
Ah, the consumer computers!
LC squeaking
Postby JRL » 01 Jun 2008, 01:35
While an pizzabox LC is turned on, it emits a squeaking sound which eventually fades over time. What's wrong?
Plus (MicroMac Performer), SE x2, Classic, LC x3, LC II, LC III, P460, LC 475, LC 575, Color Classic, II, IIci (PowerCache), IIsi x2, 150, 160 x3, 170 x2, 180c, Duo 2300c, 520c x2, 5500, 6360, Duo Dock, 7100, iBook 366, MacBook
User avatar
JRL
Re: LC squeaking
Postby meall » 01 Jun 2008, 02:47
Maybe the fan needs lubrification?
Newtons: 110, 120, 2x eMate 300, 130, 2x 2100, and lots of memory card, ethernet, wifi.
Macs: Lisa 2, 128K, II, IIsi, Beige desktop G3, LC III, Performa 6360, SE/30 (not feeling well!), G4 Cube, G4 450 tower
Apple IIs: IIc and 2x IIgs
User avatar
meall
Re: LC squeaking
Postby JRL » 01 Jun 2008, 03:00
Hmmm... I'll swap out the fan from my own dead LC then.
User avatar
JRL
Re: LC squeaking
Postby meall » 01 Jun 2008, 03:17
As far as I can tell, the fan is the only moving part in an LC. So it is either that, or some kind of transistor that going to died, difficult to say from your problem's description.
User avatar
meall
Re: LC squeaking
Postby JRL » 01 Jun 2008, 17:15
I really have a feeling it's the fan.... The cords appear to be damaged in some way.
User avatar
JRL
Re: LC squeaking
Postby pee-air » 01 Jun 2008, 17:31
meall wrote:As far as I can tell, the fan is the only moving part in an LC. So it is either that, or some kind of transistor that going to died, difficult to say from your problem's description.
The LC also has a floppy drive or two and/or a hard drive. My Quadra 700 squeals briefly when I power it up as well. I attribute the squeal to power draw on startup. If I run the Quadra with a beefier power suply, there is no squeal.
I just said, "No!" Basically, I just said, "No!"
User avatar
pee-air
Re: LC squeaking
Postby JRL » 01 Jun 2008, 17:44
I am going to try to replace the fan and see what happens. It could be power draw, but I switched PSU's with no change.
User avatar
JRL
Re: LC squeaking
Postby pee-air » 01 Jun 2008, 18:24
Just disconnect the fan for a moment and power the sucker up. No point in replacing the fan if it's not the source of the squeal. In my Quadra 700 I have a CPU fan that gets its power from the hard drive connector. If I disconnect the fan and power the machine up there is no squeal. If I disconnect the hard drive and leave the fan connected, there is no squeal when I power up. If I connect them both, I get a squeal until the hard drive completely spins up. The hard drive draws more power on spin up than it does once it's up and running.
User avatar
pee-air
Re: LC squeaking
Postby LCGuy » 01 Jun 2008, 23:24
What monitor are you using, and have you tried booting it up without the monitor? My LCIII has always had a 14" Macintosh Colour Display (14" Apple Trinitron that does 640x480, very common on LCs) since we got it new in 1993. In 1999 we noticed it started making a squealing sound, which at first I thought was either the HDD or the fan, since the display sits on top of the computer. It was the monitor. (its a common issue with these displays)
That one blew up in 2001, but since then I now have another MCD, which has the same issue. So yeah, before doing anything with the computer, try and rule out the monitor first, especially if its an MCD.
Also, it could be the bearings in the HDD.
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Re: LC squeaking
Postby JRL » 01 Jun 2008, 23:35
The monitor is a '12 RGB; I tried two of these with no change.
User avatar
JRL
Re: LC squeaking
Postby sylwiusz » 16 Jun 2008, 09:10
My LC makes similar sounds and for sure it is not fan, because I have disconnected it :-/ Seems like a problem with logic board.
Regards
Sylwek
MB | PM7600/G3/400 | Quadra 800 | Classic II
sylwiusz
Re: LC squeaking
Postby porter » 16 Jun 2008, 10:04
Have you considered the switch mode power supply? They working by using high frequencies that stabilise after the loads settle.
Is it an electronic or mechanical squeak?
User avatar
porter
Re: LC squeaking
Postby tomlee59 » 16 Jun 2008, 18:23
I just noticed this thread -- what seems to be missing is a discussion of where the noise is coming from. Is it emanating from the speaker? Is it coming from someplace else? The source of the sound will be an important clue as to its cause, needless to say. It could be this, it could be that, it could be any of the things people have mentioned, but a systematic investigation of the source itself should precede any substantial repair effort.
User avatar
tomlee59
Re: LC squeaking
Postby Scott Baret » 17 Jun 2008, 02:11
This problem seems to be pretty common with pizza box LCs. I've seen it in Is, IIs, and IIIs.
It's not the hard drive. Nor is it your fan. I've even tried swapping power supplies to no avail. My guess is that it's got something to do with the logic board's connection to the power supply, since the sound I have heard seems to originate there. (Unless, of course, the extra power supplies I've got are all bad too).
I've got an LC I'm working on right now and will try swapping the power supply with one from a known working LC 475 that doesn't have this problem. If it works, then the conjecture is that the power supply is the problem. Otherwise, it's a logic board issue (perhaps pertaining to the power supply portion of the board, similar to what the standalone analog board on a compact Mac is).
"Education is life."
User avatar
Scott Baret
Re: LC squeaking
Postby LCGuy » 17 Jun 2008, 06:42
I'm curious - do capacitors make any noises like this as they start to go out? I'm thinking...maybe it could mean the caps are on their way out...:(
User avatar
LCGuy
Re: LC squeaking
Postby Franklinstein » 17 Jun 2008, 14:31
Big ones will. Ya know how a camera will emit a high-pitched whine when it's charging the flash? That's coming from the charge capacitor. So other high-capacity caps will also emit a squeal or squeak from time to time, particularly if they're old or overloaded.
User avatar
Franklinstein
Re: LC squeaking
Postby tomlee59 » 17 Jun 2008, 18:13
The noise from a flash charging is from the inductor/transformer, not the capacitor.
Capacitors can make sound, but much more rarely and softly. The core materials used in inductors and transformers are magnetostrictive (i.e., their dimensions vary with the applied magnetic field). Also, the windings can change shape as the magnetic field varies. Many transformers are dipped in goo to dampen the audible noise (and to reduce sensitivity to moisture, etc.).
Capacitors have plates that are separated by such small distances that, even if the plate separation were to modulate as a function of applied electric field, the sound emitted would be feeble.
Failing electrolytic capacitors can generate electrical noise -- a steady voltage can produce currents that vary randomly, crackle, pop, whistle, chirp, etc. If these capacitors are in the audio signal path, then the electrical noise can turn into audible noise.
User avatar
tomlee59
Re: LC squeaking
Postby Charlieman » 17 Jun 2008, 20:16
LCGuy wrote:I'm curious - do capacitors make any noises like this as they start to go out?(
The small caps on logic boards fail silently (apart from the disruption that they cause during the process). Big caps in power supplies provide very few subtle warnings and go BANG. We bought a bunch of PCs with bad PSU caps (BANG!) for student teaching areas.
By BANG! I mean that fragments shot out of the back of the PC and could have caused facial or eye injury. Fortunately, the first failure was observed by an electrical engineering lecturer, so we immediately took the report seriously. In private testing (ie without a class of students), a couple of PSUs failed in a similar way, so our supplier fitted a different batch of power supplies.
*Edit* Apple PSUs very rarely go BANG. Once, in my experience of using thousands of Macs, and that might have been might fault by not waiting long enough before booting a Mac that had been in long term storage. But I've seen a couple of WOOFs of flame from compact Macs. Tom Lee denies this from his experience, but it might be a difference between 110V and 220V compacts.
Charlieman
Re: LC squeaking
Postby LCGuy » 18 Jun 2008, 00:00
Oh yes, Charlieman, I've had a couple of AT and ATX PSUs do that, but also a Power Mac 8100 power supply back in 2002.
User avatar
LCGuy
Re: LC squeaking
Postby JRL » 21 Jun 2008, 01:30
I do have a spare board; maybe that will work.
User avatar
JRL
Re: LC squeaking
Postby commodorejohn » 21 Aug 2008, 22:23
I've actually had the same problem with my LC and Classic II. I opened up the LC to see if I could figure it out (didn't have a long enough allen wrench to open the Classic :-/ ) I traced the noise to the internal speaker; sure enough, when I plug something into the headphone port, the speaker is disabled and the noise goes away. As near as I can figure, this is RF interference between the speaker and the fan, which are right next to each other on the LC board; I don't know if this is also the case with the Classic (though I suspect it is,) and I don't know why it would do it now when it almost certainly didn't when the computer was manufactured. So, quick fix: use external speakers or headphones.
commodorejohn
Re: LC squeaking
Postby FakeWozniak » 29 Nov 2008, 02:04
I got the same whining.
I don't believe it is interference between the speaker and anything else.
You can unplug the fan and it's still there. You can unplug the speaker and it goes away. It is also audible when headphones are plugged in, although some believe it can solve the problem (may external speakers have a filter).
I have taken the speaker out of the snap-in holder on the case and moved the speaker away from the fan, et. al., while still connected, and held it up to my ear and it is CLEARLY coming from the speaker. It was away from the fan and the power supply, and still made the noise.
Question is, which cap or driver/amp chip needs replacement....
FakeWozniak
Re: LC squeaking
Postby superpantoufle » 29 Nov 2008, 11:02
commodorejohn wrote:I've actually had the same problem with my LC and Classic II. I opened up the LC to see if I could figure it out (didn't have a long enough allen wrench to open the Classic :-/ ) I traced the noise to the internal speaker; sure enough, when I plug something into the headphone port, the speaker is disabled and the noise goes away. As near as I can figure, this is RF interference between the speaker and the fan, which are right next to each other on the LC board; I don't know if this is also the case with the Classic (though I suspect it is,) and I don't know why it would do it now when it almost certainly didn't when the computer was manufactured. So, quick fix: use external speakers or headphones.
This is it. I got the exact same experience on a LC and a LCIII, couldn't have described it better.
From a Macintosh SE to a MacBook Pro 13'' (late 2009). 23 years of (insanely great) addiction, and counting.
Pomme-S.ch :: my collection hosted on a PowerBook 145B.
Takalyde.ch :: Indie-rock from Switzerland
User avatar
superpantoufle
Re: LC squeaking
Postby Scott Baret » 21 Apr 2012, 04:57
Bumping this since I had to take an LCIII+ out of service today due to the same problem. It looks as though nobody had found a clear solution for this when the post was written, but perhaps someone has found a culprit (specific capacitor or otherwise) in the years since.
I didn't have any speakers on hand; these computers were being set up as a mini-lab for a monthly activity camp for children with disabilities. As much as I wanted to use this LC for Kid Pix, the sound only got louder as I kept the computer on (definitely a no-no for both the sake of presenting computers and for children with sensory issues, especially those affecting hearing).
My first thought is to wash the logic board although I'd like to see if anyone has tried that with success before I go through with that only because I've been pressed for free time thanks to a few 14+ hour workdays. If nobody has, I'll see what I can do--my LCIII+ can be our guinea pig sometime when I have a day off. (I'm also thinking of washing a Classic board, as I have a Classic which just lost its sound after sitting idly since 2009 and I know it's usually cap-related on the Classic when the speakers stop working).
User avatar
Scott Baret
Re: LC squeaking
Postby FlyingToaster » 21 Apr 2012, 13:13
My LC 1 had the same issue (it eventually died altogether) but the problem was some leaking caps around the speaker. When plugged headphones in, the noise went away and was barely audible from the headphones.
User avatar
FlyingToaster
Next
Return to 68k LC & Performa
Who is online
Users browsing this forum: No registered users and 1 guest
