Warning! Exploding Maxell PRAM Batteries
Ah, the consumer computers!
Re: Warning! Exploding Maxell PRAM Batteries
Postby maceffects » 19 May 2012, 02:44
Yes its pretty crazy not sure the issue but it seems pretty wide spread. and uniserver I'm glad there was something to save in there, I am surprised the HD is dead, maybe it has something to do with the board because it was tip top when put away years ago, even had some neat programs on there IIRC. I am surprised the PSU is good since it look liked it got hit pretty good.
maceffects
Postby uniserver » 22 May 2012, 04:37
here is 2 completely dead ZERO volts 3.6v batteries, good news is neither are leaking!
the tadiran is made in israel, the maxell is made in japan...
#I Can Re-Cap Your Board/PSU# (iAmCapsMack@gmail.com) or (maccaps.com) Link---->
Need: 840av, IIfx, *Portable Mainboard, Portable Parts pm-me please*
Fav's: SE/30-FIXD, LC575 Full 040@33mhz /w 1G-HD, IIsi-oc'd-29-mhz, PM 6100-oc'd 90mhz, Color Classic /wLC520 mobo
User avatar
uniserver
Postby onlyonemac » 20 Jun 2012, 16:58
Bunsen wrote:
maceffects wrote:This should be stickied if not already.
Done. I might also move this to a more visible forum, seeing as this is not specifically an LC/Performa issue. The Lounge?
I don't think so. It needs to be visible to non 68kmla members. I read this a while before a member, and found it very important (although fortunately my mac hadn't suffered).
Don't hack your Mac...you might as well throw it in the dumpster.
Always on the lookout for cheap/free Macs and Mac goodies-PM me if you've got an offer.
As my username suggests, I only have one mac (Performa 475), but wouldn't mind 50 or so.
User avatar
onlyonemac
Postby kite210 » 21 Jul 2012, 07:19
After reading this thread, I decided to pull out the macs I have stored in my basement to see if I had left any of the PRAM batteries in them.
I started with my G3 B&W, nothing there, then the 8500, which had a Tadiran battery in it, I decided to leave it in, as I didn't feel like taking it all the way apart just to take it out.
Once I got to my 7100, I opened it and found this:
It's still sealed, so that's a relief :) . I've had these machines stored for about a year now, so I'm glad I checked before my 7100 bit the dust from the maxell bomb.
I just need to check my eMac and iMac DV upstairs now.
My Collection:
Macintosh LC III, Macintosh Color Classic, Power Macintosh 6100/60, Power Macintosh 7100/66, Power Macintosh 8500/180 PowerBook G3 Wallstreet rev. 2, Power Macintosh G3 Blue & White, iMac DV 400Mhz Indigo, eMac (USB 2.0), PowerBook G4
User avatar
kite210
Postby onlyonemac » 27 Sep 2012, 18:24
WHY is this not being MOVED!!! :?: It was more or less what brought me here!
User avatar
onlyonemac
Postby volvo242gt » 02 Oct 2012, 07:36
Guess it can happen with Tadiran batteries. Tested out an SE/30 that I got today. Wouldn't boot, showed what looked like a mixture of checkerboard and the normal startup screen on the monitor. After repeated attempts to get the machine to boot, I got out the T-15. Opened it up, found some capacitor leakage that was visible from under the motherboard. Pulled the board and found this:
As per usual, the battery holder wasn't attached to the board anymore. So, I'm thinking it'd be a good idea to replace these guys, no matter what brand they are, on a 10 year schedule. Maybe sooner.
I also tore into a IIcx that came with the SE/30 and a bunch of other machines. No explosion yet from the Tadiran battery, but it was getting a little stinky and corroded looking.
-J
Mac: 512Ke, Plus 4/0, SE 4/40, SE/30 8/40, IIx 8/230, IIcx, IIci 20/250, Q660av, iMac G3/333 Tang, G4/1.2GHz DA 1.5G/40G/DVD-RW, G4 MDD 2G/80G/30G/DVD-RW, C2D 2.16 iMac 2G/250G
Apple II: ][, ][+, //e x2, //c
Other: iPhone 4, Dell D830
User avatar
volvo242gt
Postby LCGuy » 02 Oct 2012, 08:32
Remember, these are 20 - 25 year old batteries. Any battery that old can leak or even explode. They're simply not designed to last that long. Personally I always dispose of batteries when they die.
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Postby volvo242gt » 02 Oct 2012, 09:59
Yep, hence the reason I'm changing them out on a 10 year cycle now. Need to change out the one in the G4, since it's likely the original Tadiran from 2001.
-J
User avatar
volvo242gt
Postby mcdermd » 02 Oct 2012, 16:40
I just leave them out. 95% of Macs will boot without them and the once in a while that they are turned on after being unplugged, I can set the time or let the time get set via NTP.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby uniserver » 02 Oct 2012, 16:49
yeah its a shame to have a battery destroy a main board like that.
User avatar
uniserver
Postby directive0 » 02 Oct 2012, 18:32
On the topic of Network Time Synchronizer:
Does anyone else have problems with it crippling your computer? I have 2 7100's running OS 8.5.1 and they both just lock up until command-opt-escape lets me force quit (and when I do its ALWAYS Network Time Synchronizer thats doing it).
I've left it for hours and come back and it's still locked. Is there something I can do to get it working properly?
Powermac 7100/80 - 8GB CompactFlash card via AztecMonster, 100Mb RAM, Mac OS 8.5.1, OrangeMicro 486 Card with MS-DOS 6.0, Win 3.1.
User avatar
directive0
Postby techknight » 05 Oct 2012, 00:51
i ran it on my SE/30 back in the day and never had issues.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby insaneboy » 08 Oct 2012, 13:49
hummm maybe I should check the SE/30 at work... although it's on a really high shelf and I don't do heights.
insaneboy
Postby volvo242gt » 08 Oct 2012, 17:52
^ If necessary, have a coworker grab it. But, yep, I'd check it.
-J
User avatar
volvo242gt
Postby Nathan » 11 Apr 2013, 19:15
You could just tape up the compartment with masking type or something else, couldn't you? Might help reduce the chance of the board getting destroyed.
PPC: PowerMac G4 800 DP QS, Bondi iMac G3 333MHz (Upgraded from 233MHz) -- 256MB, Performa 6100/66 -- 72MB RAM - hd now dead :(
68k: Macintosh LC II -- 12MB RAM
Older: Apple IIe Enhanced -- 128KB RAM, Newton eMate 300 w/memory enhancement -- 4MB RAM
Nathan
Postby LCGuy » 11 Apr 2013, 21:33
I doubt it. But whats the point given that the battery is most likely already dead, and you've got the machine open, and can remove the battery, therefore removing the risk completely?
User avatar
LCGuy
Postby Brett B. » 12 Apr 2013, 02:32
I haven't specifically seen a Maxell battery blow up, but I've dealt with several other brands. Don't remember which. Really, it doesn't matter, they can all leak.
IMO there is zero reason to even have a PRAM battery in any old Mac that you are not using on a daily basis that doesn't require it to boot. It's just too risky and there's no reason to damage your equipment with a battery that explodes.
68k: LC, LCII, LCIII, LC475, LC630, Q650, Plus, 2x SE, SE/30, IIci
PPC: 2x Beige G3 Server, Rev. A&C iMacs, PM7300, DP 2.5 G5
PowerBooks: 150, 180, PDQ
User avatar
Brett B.
Postby genie_mac » 13 May 2013, 23:31
Another one bites the dust...or should I say has bitten the dust:
Picked up an LC with monitor for a tenner today and was told it wasn't working. When I got home and spotted all the rust on the backpanel I got suspicious...more rust than usual....this couldn't be, could it???
Looks like a Maxell alright. Mind you I also have an unexploded Maxell from 1992 but the plot thickens....
I didn't know caps could turn into mushrooms either....
Ah well at least the harddrive, floppy and PSU are still OK...now can I use that floppy in my SE?
8 bit was the future.
User avatar
genie_mac
Postby uniserver » 14 May 2013, 00:05
wow that is terrible and cool all at the same time :)
User avatar
uniserver
Postby markyb86 » 14 May 2013, 04:12
You can use it in the SE if it is the FDHD or Superdisk model, or if you have roms from either IIRC
DON'T COPY THAT FLOPPY....
My computer registry is at: http://www.markyb.org/computers/
68k: Plus,SE FDHD | G3: B&W, iMac '01, Pismo | G4: Sawtooth AGP | intel: MacBook '08
iPod nano 6G, iPad 2G, core i5 PC, eeePC 900
User avatar
markyb86
Postby uniserver » 14 May 2013, 06:32
or you could scrape it off really good, toss it in the sink and scrubb it. try a re-cap, maybe it will fire right up ? :)
User avatar
uniserver
Postby LCGuy » 14 May 2013, 09:28
genie_mac wrote:I didn't know caps could turn into mushrooms either....
What is that....that.....stuff? That couldn't *all* have come from the caps, could it?
User avatar
LCGuy
Postby onlyonemac » 14 May 2013, 16:19
It's probably the result of a reaction between the capacitors and the battery acid.
User avatar
onlyonemac
Postby genie_mac » 20 May 2013, 19:24
Yeah looks pretty cool alright, not if you're a poor LC though.
Have decided to try and get it going again; have scrubbed it down pretty well and it doesn't look too bad. Have to replace the caps alright and not sure if the pads are gone...also have to resolder some pins of the 68020 which have come loose...very strange. The only major problem is one of the socketed chips (what are they?) where there is major corrosion. If I take it out, I'll probably loose half the legs :(
Well I'm away for a few weeks so this will have to wait...might start a new thread once I have something to report.
Laters.
PS: Thanks markyb86, will try that; my SE works with a FDHD alright so that's great.
User avatar
genie_mac
Previous
Return to 68k LC & Performa
Who is online
Users browsing this forum: No registered users and 2 guests
