Capacitor fell off of an LC III?
Ah, the consumer computers!
Postby Mike Richardson » 10 Aug 2007, 03:50
I have an LC III. One of the capacitors looks like it fell off, solder pads and all, but as far as I can tell, the missing capacitor has no ill effects on the system. Sound works fine, ADB works, everything seems to work OK. Is it OK to just leave it off?
Mike Richardson
Banned
Re: Capacitor fell off of an LC III?
Postby LCGuy » 10 Aug 2007, 06:05
Got a pic? :O I've never even HEARD of this before! If everything works ok, then i'd leave it *exactly* as is. but get a pic.
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Postby Bolle » 10 Aug 2007, 06:37
on my old (now dead) 8500 board was a cap that came off on one side. the board worked well the way it was.
Bluets and Granola Bars, Make a chewy snack.
User avatar
Bolle
Postby ~tl » 10 Aug 2007, 07:00
What location on the board did it come from? If it's near the LC-PDS slot then it might be something to do with that -- and hence if you're not using a card then you wouldn't notice.
~tl
Postby Mike Richardson » 10 Aug 2007, 11:01
Yes it is near the PDS slot. It is probably related to it somehow. Would trying a PDS card damage the card at this point?
Mike Richardson
Banned
Postby ~tl » 10 Aug 2007, 11:28
Mike Richardson wrote:Yes it is near the PDS slot. It is probably related to it somehow. Would trying a PDS card damage the card at this point?
It's hard to say without knowing what the capacitor does exactly. I wouldn't risk it personally, unless you don't mind the chance that it will get trashed.
~tl
Postby tomlee59 » 10 Aug 2007, 23:27
Almost all of the electrolytics are power supply bypasses. There is an abundance of them, so one or two lost here and there won't cause any problems, assuming that the remaining ones are in good health (this may not be a good assumption with our old machines, however).
If all is working now, be happy. Just carefully note what and where it used to be, so that you know what to do in the future, should the need arise.
User avatar
tomlee59
Postby Mike Richardson » 11 Aug 2007, 00:27
A few capacitors are also audio related; generally they are near the audio port. But the audio is fine.
Mike Richardson
Banned
Postby tomlee59 » 11 Aug 2007, 04:23
Mike Richardson wrote:A few capacitors are also audio related; generally they are near the audio port. But the audio is fine.
Yes, I took note of what you said in your original post. Since you already said that you had no sound or other problems, the likelihood of the fallen cap being an ordinary bypass cap was made very high.
User avatar
tomlee59
Postby JohnnyGrey » 21 Jan 2008, 21:43
Or you might have an ugly inaudible gremlin to deal with like a DC offset or ultrasonic oscillation.
LCIII - 36MB RAM, 68040@33Mhz, FPU, Ethernet
LC575, SE/30, SE, PB145, PB5300
JohnnyGrey
Postby gobabushka » 31 Jan 2008, 18:54
id say just pop an el cheapo card in and try it.
"I reject your reality and substute my own!!!"
User avatar
gobabushka
Postby Mike Richardson » 31 Jan 2008, 20:39
This topic is really old. I think I stopped using the board.
Mike Richardson
Banned
Postby Christopher » 31 Jan 2008, 22:43
Bolle wrote:on my old (now dead) 8500 board was a cap that came off on one side. the board worked well the way it was.
I've got a couple missing on my 8500 as well. :?:
Christopher
Return to 68k LC & Performa
Who is online
Users browsing this forum: No registered users and 2 guests
