Quadra 610
Quadra 610
Postby Mithrandir » 15 May 2012, 02:31
So i have decided on a quadra 610 for my summer project. I have already bought one online, but it will take about a week to get here. I bought it thinking that yay it has a full 68040 processor. Now after reading a little more about it, I find out that sure enough, there was a version of the quadra that had only the 68LC040, the quadra 610 8/160. I don't have anything of the computer except a screenshot from the front and a screenshot of the about this mac page showing its total ram. So I am guessing I will just have to wait until it gets here to see which processor it has. How worried should I be that this one might be a 8/160 (I did buy it from North America...) and is the difference in speeds really that bad? Thanks in advance for putting up with my Macintosh bewilderment at this time.
Desktop: Macintosh SE, iMac G3, Powermac G4, Quadra 610, Mac Mini (Early 2006)
Laptop: Powerbook 1400c, Powerbook G3 (Pismo), Macbook Pro (Late 2011)
User avatar
Mithrandir
Re: Quadra 610
Postby Cory5412 » 15 May 2012, 03:05
If your frames of reference are "G3s and higher" and "The Mac SE" -- I wouldn't worry about performance very much at all. If it ends up really being awful, then you can upgrade it later, get a better machine, or whatever. The ram is probably the first thing I'd upgrade though, given a few extra dollars, mainly because most people think that it's important to be able to run a bunch of applications at once, even on a midrange desktop from the early '90s when that just wasn't common.
Cory5412
General
Re: Quadra 610
Postby Gorgonops » 15 May 2012, 20:02
Unless you're running software which specifically wants a math coprocessor and/or you plan on running alternative operating systems (A/UX, NetBSD, etc) 68LC040 vs "full" 68040 hardly matters at all. If you bought the thing just to fiddle with old Mac games on I wouldn't obsess over it. For integer tasks (which is most game and productivity software) the two CPUs will execute code at exactly the same speed.
(The aforementioned "alternative operating systems" require a "full" '040 because there is a hardware flaw with most LC CPUs that prevents FPU emulation software which depends on inline trapping of the unsupported instructions from working entirely. This doesn't affect most MacOS programs because the math functions which would use FPU are routed through a higher-level library in the first place. There probably is a small category of ill-behaved MacOS programs that contain inline FPU instructions but I can't name any offhand.)
User avatar
Gorgonops
Re: Quadra 610
Postby uniserver » 15 May 2012, 20:11
good info on the 040 fpu less,
#I Can Re-Cap Your Board/PSU# (iAmCapsMack@gmail.com) or (maccaps.com) Link---->
Need: 840av, IIfx, *Portable Mainboard, Portable Parts pm-me please*
Fav's: SE/30-FIXD, LC575 Full 040@33mhz /w 1G-HD, IIsi-oc'd-29-mhz, PM 6100-oc'd 90mhz, Color Classic /wLC520 mobo
User avatar
uniserver
Re: Quadra 610
Postby Mithrandir » 15 May 2012, 21:48
Ok my worries are gone now.
User avatar
Mithrandir
Return to Mac II, Quadra & Centris
Who is online
Users browsing this forum: No registered users and 2 guests
