Macintosh IIsi Restoration
Postby Theretrogamingroom » 11 Aug 2011, 23:07
A while back I was given a Macintosh IIsi with a few issues. Not only was there Uneven Yellowing on the case, but upon powering the machine up, it would show a Solid Colored Screen and would not load the Operating System. This was probably due to Leaking Capacitors (Which I cleaned and Removed when I recieved the Computer).
I started by cleaning the case and then Retr0brighting it. I made the recipe that JDW made and applied it to the yellowed areas. Even though this was my first time using it, I think that it turned out quite well.
With the Case taken care of, I decided to clean the Motherboard (Again). This time I cleaned in a specific area; Under the Hard Drive Ribbon where Capacitor Damage appeared to be greatest.
I then connected my Peripherals and crossed my fingers.
When I turned it on, I was thrilled to see the machine loading the OS and Desktop. It works*!
*: Even though the Mac IIsi Loads the OS and is now usable, I am still having a few issues. Upon Startup, I still get Colors but the Machine is able to push through and Boot Up. The Machine also freezes from time to time. What ways can these problems be fixed? I would imagine that I need to clean the MoBo some more but I think that a chip under the HD Ribbon Cable is Damaged (The Connectors have turned a greenish color from the Leaky Capacitors) Should I reclean, replace or create a better connection with wires?
Thanks
PS: I will try to upload some pictures later.
Apple IIe (x2), Mac 128k, Plus, SE/30, IIci (x2), IIsi, IIfx, LC, Performa 6214CD, Quadra 610AV, PM 6100/66, 6500/250, G3 AIO, G5 (x3), iMac G3 (3 BB, 2 Snow and 1 Indigo), G4, G5, PB 165c, AlG4, TiG4, Snow iBook (5 G3, 4 G4), iPhone 4, iPod G2, G3.
User avatar
Theretrogamingroom
Re: Macintosh IIsi Restoration
Postby theos911 » 12 Aug 2011, 00:17
I've found the best way to clean these boards to be a dishwasher. Pull out the RAM/ROM(if in chip form) and basically any other item that can be removed and run it through the dishwasher with a tad of handsoap(or any non-oxy/variant thereof). Then, let it dry for a minimum two days(week=safer), and see how it works. Also, this gives the benefit of allowing you to see which capacitors are still leaking.(Though, it'll probably take a while for the culprits to make a large-enough-to-be-visible mess)
68k: Duo 230, 270c, 280c, DuoDock II, DuoDock Plus, Apple Minidock, Newertech Netdock & Ultradock 16sce, 540c, 190
PPC: 2300c, 5300ce, Performa 6500, Wallstreet II 300, B&W Powermac G3 500, iMac G3 700
PRAM? When in doubt, Pull it out!
theos911
Postby Trash80toHP_Mini » 12 Aug 2011, 03:23
Do you have any RAM SIMMs installed?
If not, never mind, but if you do, take them out and try booting with just the MoBo's 1 MB of soldered in RAM ICs to see if it just might be memory related.
It's just a hunch, but since the IIsi inherited such a horrilbe System RAM based Video Kluge from the IIci, you never know what might be going wrong!
Which OS are you booting, BTW? Use a RAM test utility, that's OS appropriate, to beat the snot outta' that measly stock 1 MB of Memory to see if you get any errors.
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Return to Mac II, Quadra & Centris
Who is online
Users browsing this forum: No registered users and 1 guest
