Did I Get a Bum Daystar Card?
Postby jwmcfarlin » 25 May 2010, 03:24
I try and figure things out by myself first, but since I am new at this I am running into a lot of new situations. I recently installed a Daystar Powercache card (P33 designation) in my IIci and downloaded and installed the control panel from Daystar, but I do not notice any performance difference. Is there a good way to check this out and see whether it is doing anything for my machine?
Best,
John
jwmcfarlin
Re: Did I Get a Bum Daystar Card?
Postby Unknown_K » 25 May 2010, 04:07
Look for the control panel and make sure it is turned on.
On the 040 cards you see a 040 icon when booting, I don't have an 030 to see what it does.
Favorites: big box Mac IIs, 950, 800's
Wanted: Anything Nubus, Video capture and editing hardware and software for 68k mac. Original software including A/UX.
Looking for 9150, Mac II, Color classic, 840av motherboard, and Nubus cards.
User avatar
Unknown_K
Postby jwmcfarlin » 25 May 2010, 06:48
There is a Daystar Icon that pops up during windows load, so I guess it's there. Boot time was 44 seconds instead of 56, but I was guessing that boot time is primarily an issue of hard drive speed. My benchmarking methods without a formal benchmarker right now are kinda crude: I just time certain functions, such as boot to termination of stopwatch, open a Word document, open PageMaker, general feel of performance in games like Syndicate. Didn't seem much different, is all, so I was confused as I would have figured that with a 50MHz clock speed 1992 to 1994-era software under 7.1 would be pretty snappy.
Then again, this card doesn't have the FPU so maybe there is a big difference there.
Best,
John
jwmcfarlin
Postby Unknown_K » 25 May 2010, 06:58
FPU does nothing for boot times.
All CPU upgrades do is speed up calcs, I have a IIci with a Daystar 68040 running at 48Mhz with a heat sink and fan. Speeds up apps , but cache would make it even faster.
User avatar
Unknown_K
Postby jwmcfarlin » 25 May 2010, 14:09
Yeah, that's what I 've come to an awareness of--that the things that I was wanting faster were functions of hard drive seek and access time, not CPU speed. Cool.
Best,
John
jwmcfarlin
Postby Unknown_K » 25 May 2010, 19:29
Get a faster HD and maybe a UWscsi HD controller. FWB Nubus Jackhammers are fast and bootable, 68 pin 10K RPM SCSI drives are super cheap these days.
User avatar
Unknown_K
Postby trag » 25 May 2010, 20:11
Unknown_K wrote:Get a faster HD and maybe a UWscsi HD controller. FWB Nubus Jackhammers are fast and bootable, 68 pin 10K RPM SCSI drives are super cheap these days.
[Nitpick]There is no UWSCSI HD controller for NuBus. The FWB JackHammer was *Fast* and Wide SCSI, which has a theoretical maximum speed of 20 MB/s and is much slower in practice. You'll be lucky to get actual sustained transfers of 12 MB/s and 6 MB/s seems more common.[/Nitpick]
trag
Postby Unknown_K » 25 May 2010, 22:54
OK, you got me. But a Jackhammer is still much faster then the built in SCSI setup.
User avatar
Unknown_K
Return to Mac II, Quadra & Centris
Who is online
Users browsing this forum: No registered users and 1 guest
