Solid state hard drive (CompactFlash Card) on Quadra 630?
Postby AG Wolf » 12 Aug 2009, 17:37
...or on any machine really...
I have a couple of IDE <-> CompactFlash card adapters, but I only have one chintsy 32mb compactflash card from like 1999/2000; when I tried using the card on the machine, it didn't do jack...
I'm just curious if anyone had gotten this working yet. I have an LC475 modded at 33mhz hosting a basic website from home, I wanted to use a Q630 as the server and use a CF card as a sort of SSD if possible. Has anyone else gotten some similar sort of combination to work?
AG Wolf
Re: Solid state hard drive (CompactFlash Card) on Quadra 630?
Postby joshc » 12 Aug 2009, 20:15
What software were you using to recognise the card and format/mount it? If nothing else works its usually best to try FWB Hard Disk Toolkit. Also its worth trying different brands of CF cards - cards with small capacities are really cheap so you can't lose much.
MacBook Pro 15.4" Non-Retina (Mid 2012) with Antiglare Display, Intel Core i7 2.3 GHz, 16GB RAM, WD Scorpio Black 750GB 7200RPM, OS X 10.8/Windows 7 dual boot.
User avatar
joshc
Postby Trash80toHP_Mini » 13 Aug 2009, 18:42
IRC, and as I understood it back in the day . . . :-/
Apple's botched (read as intentionally crippled, IMHO) implementation of IDE on the Q630 will ONLY address IDE HDDs. I could well be wrong, and I hope you can prove me so, but you won't be able to get such Solid State Memory to work on a "stock" Q630, AFAIK.
It'd take a PCI equipped MoBo transplant and a USB card to do much of anything really useful with my favorite form factored Desktop Mac from the transitional NuBus->PCI architecture era.
It was my fovorite because it perfectly fit into the rounded desktop overhang I built to top off the dresser/desk/captains bed & custom adjustable shelving unit I built for the rug-rat's small bedroom up in the Big Apple.
Good luck hacking Solid State Memory onto the Q630's NuBus Architecture, comrade.
jt =8-\
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby Bunsen » 14 Aug 2009, 08:04
From other things I have read, it may be worth trying a card that states it is UDMA or ATA mode compatible
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby AG Wolf » 16 Aug 2009, 15:44
I unfortunately don't have other cards to try, and am at limited funds to really "experiment." is there a list anywhere that might say what brands/sizes/models of CF cards are UDMA/ATA compatible?
I don't plan to dwell on this too long (nor hold onto the machine) if it doesn't really look possible. It was just an idea I had a while back and left on the back burner; I only remembered it again recently because I'm going through all my old mac stuff again to try and get rid of stuff before I leave for college in less than two weeks. On that note, I'll have some stuff for sale very soon if I can get my butt in gear. a 512k, Plus, SE, Classic, G3AIO (maybe two), 9600 w/g3 (or g4, dont recall) upgrade, G4 400mhz, maybe some hardware and other accessories. But that's another thread for another day :P
I'd like to hold onto this 630 a bit longer, so any other input is definitely appreciated.
AG Wolf
Postby Bunsen » 16 Aug 2009, 23:19
AG Wolf wrote:is there a list anywhere that might say what brands/sizes/models of CF cards are UDMA/ATA compatible?
All I have to go on are advertisements on ebay and manufacturer's spec pages, where available.
You could try a Microdrive, which is a real ATA hard drive in CF format. The Seagate ST1 goes up to 8GB from memory, and each has a 2MB onboard cache RAM. I picked one up for $20 shipped with a USB converter. OK, so it's not solid state and has moving parts, but it'll still be a lot lower in power use and noise than your average 3.5" hard drive. Otherwise I'd suggest a small (ie cheap) used Seagate HD. They're usually pretty quiet. Or a laptop HD on a 3.5" converter.
What are your reasons for wanting CF in there?
User avatar
Bunsen
Witchfinder-General
Postby register » 18 Aug 2009, 19:57
The new Sandisk Extreme III CF card (specified transfer rate 30 Mb/s) should do well, as it supports UDMA. This thing is pretty fast, better than any old harddisk drive. The 2 GB version might be affordable and the storage capacity is appropriate for a 68k machine.
register
Postby register » 20 Aug 2009, 20:43
P.S.: please be so kind to share your results for the Q630 here.
register
Postby johnklos » 19 Sep 2009, 22:22
The problem is finding CF cards which support the ATA standard. The most common place to find information about which cards are suitable is the iPod world, because lots of people replace failed microdrives with CF cards. Any CF card which will work in an iPod will work in an IDE-CF adapter, with the only exception being that certain adapters don't support CF cards larger than 2 gigabytes.
I use various IDE-CF adapters as boot drives for installing MacOS and NetBSD on m68k Macs (actually, SCSI-IDE-CF), and I have booted a Q630 via an IDE-CF, so it's certainly doable.
johnklos
Return to Mac II, Quadra & Centris
Who is online
Users browsing this forum: No registered users and 3 guests
