Macintosh IIci motherboard no video
Postby JRL » 31 Jul 2009, 19:41
So a while back, I received a bare Macintosh IIci motherboard. No RAM, and an old battery.
I replaced the old battery with a new one and put in x4 2 MB SIMMS.
When I turn the power supply on, I don't get any display from the built-in video at all. Note that I don't have an internal speaker hooked up so I can't hear anything.
What should I do? Thanks!
Plus (MicroMac Performer), SE x2, Classic, LC x3, LC II, LC III, P460, LC 475, LC 575, Color Classic, II, IIci (PowerCache), IIsi x2, 150, 160 x3, 170 x2, 180c, Duo 2300c, 520c x2, 5500, 6360, Duo Dock, 7100, iBook 366, MacBook
User avatar
JRL
Re: Macintosh IIci motherboard no video
Postby waynestewart » 31 Jul 2009, 20:29
When they stripped the IIci maybe they took the ROM jumper at W1. Without it you won't get any video.
Wayne
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
waynestewart
Postby JRL » 31 Jul 2009, 23:13
I'll check that location. Thanks!
BTW, no VRAM stick is necessary, right?
And also I'm using 100 ns RAM. Will that work?
User avatar
JRL
Postby JRL » 03 Aug 2009, 17:09
Well, I just read that 100 NS RAM (aka LC/LC II series RAM) won't work on the Macintosh IIci. :(
Will the IIci give video without RAM?
User avatar
JRL
Postby Charlieman » 03 Aug 2009, 20:44
There are lots of possible problems here.
System RAM needs to be fast (off the top of my head 80ns -- correctly guessed) and 2MB SIMMs don't work. You have to have functioning RAM for the Mac to boot enough to display anything on screen -- there's no VRAM.
The monitor has to sync nicely with the IIci built-in video card. Few monitors do.
For feedback on booting, you should get some indication just by putting your small fingers on top of the disk drive. Or try booting from a floppy disk -- anything with a system file should give audible feedback from the floppy drive.
Charlieman
Postby JRL » 04 Aug 2009, 03:45
The monitor I'm using is the Macintosh '12 RGB. I do have a Apple Color Plus '14 display which as for as I'm aware of works with the IIci (or am I mistaken?)
I also have x4 1 MB SIMMS but they were from a PC so I'm not too sure of compatibility.
User avatar
JRL
Postby GreenDoc » 04 Aug 2009, 15:00
Its a shame I let the RAM I had go along with the IIci board I sold a little while back.
Current:
IIgs, IIsi, Beige G3, B&W G3, Mac Plus, PB 5300cs, iMac G4, 2 Duo 210s, Bondi Blue iMac (RIP, reincarnated as CRT monitor), Imagewriter II, HD20SC, SCSI Apple Ext 1.5 GB HD.
Past:
IIci, LCIII, Mac II, Stylewriter 1200, Color Stylewriter 2400
User avatar
GreenDoc
Postby equill » 04 Aug 2009, 15:08
Apple Memory Guide 2001 wrote:… The IIci uses DRAM for video and maps it to Bank A. Contrary to other Macintosh models, always install the lowest density SIMMs in Bank A for best performance.
As Charlieman suggested, 80ns RAM is needed. If you have no video card in place, onboard video needs Bank A (two right-hand pairs) DRAM to work (so-called 'Vampire Video'). Your total DRAM, depending on your installed System, may then be perilously low. (The IIci can support up to OS 7.6.1 on a 68030 if it has enough RAM, which can be up to 128MB.)
Developer Notes 1989 wrote:… On-board video support for 12” B&W, 13” RGB, and 15” B&W Portrait monitors …
Various third-party and Apple NuBus video cards can give a wider choice of displays, and also obviate the use of DRAM for video with their on-card VRAM.
waynestewart wrote:When they stripped the IIci maybe they took the ROM jumper at W1. Without it you won't get any video.
Nor anything else, for that matter. That jumper selects between on-board ROM and the ROM slot. There never was a ROM card for the IIci, so the on-board ROM must be selected. Otherwise the IIci behaves all-same hearthstone. No ROM = no startee. Nix. Nada.
Developer Notes 1989 wrote:… Parity is generated by the optional Parity Generator Chip (PGC). If you want parity checking you must order the Macintosh IIci configured with the PGC and nine-bit DRAM SIMMs.
The (scarce) parity-checking version of the MLB obliges you to use (9-chip) parity SIMMs (but still 80ns or faster). If there is no Parity Generator Chip to the left of the DRAM slots of Bank B, but only the naked solder-pads, this is not a concern. You can use parity SIMMs in a IIci without a PGC, however, because the ninth chip will be ignored by the System. If you do not have a video card, you could probably use the 4 x 1MB in Bank A and the 4 x 2MB in Bank B (you are fortunate that the IIci is one of the few Macs that will use 512kB and 2MB SIMMs, but not 8MB) to get around Vampire Video effects.
de
Apple IIe; 68K: 20DT/T + 5PB; PPC: 9DT/MT + 3PB + PTPro; G3: 7DT/MT; G4: 3T
User avatar
equill
Postby JRL » 04 Aug 2009, 16:35
I tried equill's configuration (x4 1 MB in the first bank, x4 2 MB in the second) but with no change.
I will try the Apple Color Plus '14 next since I think Macintosh IIcis will work with that monitor.
User avatar
JRL
Postby trag » 07 Aug 2009, 17:50
JRL wrote:I tried equill's configuration (x4 1 MB in the first bank, x4 2 MB in the second) but with no change.
The Apple Color Plus worked for me back in the early 90s. I used to use it on my IIci's built-in video until I got a video card for it.
However, the ACP is subject to a fuse blowing problem. A lot of them had it. And mine eventually died by blooming the screen to either super bright or super contrasted. There was probably one bad component in there that needed fixing, but by that time we were ready to switch to LCDs. I still have a 14" viewsonic around here that will work with it though.
trag
Postby JRL » 07 Aug 2009, 19:05
Alright, thanks!
Good thing mine works fine.
Also trag, do you know if the Macintosh '12 RGB display (the one that came with the LC/LC II) will work with my Macintosh IIci motherboard? Thanks!
User avatar
JRL
Return to Mac II, Quadra & Centris
Who is online
Users browsing this forum: beachycove and 2 guests
