Bunsen wrote:BTW moving the CPU over from the bad board to the Centris will make it a Quadra
So long as it works, I don't care what it's called.
Yes?
Quadraman wrote:It seems to me that replacing all the capacitors is going to be a long and difficult process. I don't know how much the replacements caps would be, but the labor alone doesn't seem worth it. You'd probably be better getting a replacement board or a complete machine. Even if you only valued your time at $25 an hour, and it only took an hour, you could buy an early G3 iMac or Powermac for that.
tomlee59 wrote:Quadraman wrote:It seems to me that replacing all the capacitors is going to be a long and difficult process. I don't know how much the replacements caps would be, but the labor alone doesn't seem worth it. You'd probably be better getting a replacement board or a complete machine. Even if you only valued your time at $25 an hour, and it only took an hour, you could buy an early G3 iMac or Powermac for that.
Well, "worth" often involves more than a purely monetary calculation. One could argue that most hobbies are not worth the time, especially if one factors in opportunity cost. But they're FUN. So, the value of a hobby is very much a personal affair.
For me, I rarely do a full capacitor replacement. If the dishwasher trick brings it back to life, I leave it as is because I'm lazy, and replacing all the caps is not as fun for me (I feel no guilt; I've done enough soldering for several lifetimes). However, others with more dedication to the craft feel differently and diligently replace all caps, properly taking pride in a job well done.
Return to Mac II, Quadra & Centris
Users browsing this forum: No registered users and 4 guests
