SE/30 with Checkerboard Pattern but Boots normally
Macintosh, 512k, SE, etc.
Postby nvdeynde » 03 Feb 2012, 14:33
Hi,
My SE/30 suddenly has the checkerboard pattern. However the machine boots normally and has startup bong too.
The pattern does not go away after boot and makes the machine unuseable.
I have reseated and cleaned the contacts of the Rom sim and all Memory modules without result. Pulled and reseated the Video Rom too, no result.
I'm sure the problem is on the Logic Board as the SE/30 works perfect with my spare board.
So the Analog board, PSU and Video board can all be excluded too.
Same for the Rom Simm, Memory modules, Video Rom as I have tried these from my spare working board to no avail.
All capacitors on the logic board have already been replaced about 1 year ago: ESR values are good so they aren't the problem either.
The machine is used several times weekly for years without problem until this one. I have never seen it before with a board that still boots into Mac OS.
It's the kind of thing you see when the board has SimasiMac and needs capacitor replacement but then you don't have the startup bong and no boot into Mac OS anymore while my board still has both.
Below photos of the screen and the logic board.
What can be the problem and is this board still repairable ?
Nico
Mac 128K, 512K, ED, Plus, Plus ED, SE, SE FDHD, SE/30, Classic, Classic II, Color Classic, Mac II series, Mac Portable M5120 and M5126, Powerbook 100, Duo and 500 series.
nvdeynde
Re: SE/30 with Checkerboard Pattern but Boots normally
Postby tt » 04 Feb 2012, 05:23
Bad VRAM or video controller? The desktop and menubar are definitely there. Cool pattern by the way.
User avatar
tt
Postby mcdermd » 04 Feb 2012, 05:43
I have something similar with a different patter on one of my SE/30s. I haven't figured it out either.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby TheoryBoy » 04 Feb 2012, 14:25
I had a problem very like yours, Display problem with complete booting. My problem was related to a faulty memory chip keeping certain lines low. I replaced them by taking them from an old mac II card.
Dont mind the crash, it was just a bad System install. Important thing is I got video.
68K: Portable, Powerbook 100, SE,SE/30,IIfx 16MB,LCII,LC630
PPC: Pismo, Kanga, Wallstreet, Powerbook 3400, 9600 G3 Upgraded, 9600 350Mhz,8100, Beige G3, Performa 6320, 6500
Intel: Macbook, Mac Pro
User avatar
TheoryBoy
Postby nvdeynde » 04 Feb 2012, 14:58
There are so many different IC's in the video circuit...
Here are the schematics of the video circuit for an SE/30 logic board. I'm surprised that it is this complicated for B&W machine.
I'm going to replace the 2 video memory chips. I doubt it will solve the problem since the checkerboard pattern is static and identical every time. I would expect a random pattern with a bad video chip.
However it's worth a try: I'm going to dig in my old Mac II video cards >:(<
Thanks,
Nico
nvdeynde
Postby nvdeynde » 21 Feb 2012, 07:36
I've replaced the 2x Vrams yesterday and checked all the traces in the video circuit to no avail: still the checkerboard pattern.
I guess the board is beyond repair xx(
nvdeynde
Postby techknight » 22 Feb 2012, 03:17
one of the 74 series chips is bad, or one of the PALs is bad.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby nvdeynde » 22 Feb 2012, 07:35
Probably but I don't have a hot air or SMD rework station to remove these from the PCB.
nvdeynde
Postby techknight » 23 Feb 2012, 03:33
What you need is an oscilloscope and a working board to compare it to. You'll find the culprit real quick, as the waveforms compared against one to another will be wrong on the bad chip. If you were closer, i would volunteer to take a look at the board for you, as I have a working SE/30 here i can go off of.
techknight
Return to Compact Mac
Who is online
Users browsing this forum: No registered users and 2 guests
