128k Sad Mac Error Code 040200
Macintosh, 512k, SE, etc.
Postby JDW » 28 Jan 2012, 09:21
I tested out one of the 128k boards in my collection for the first time today:
http://www.flickr.com/photos/66071596@N00/2391525329/
Unfortunately, I get a Sad Mac Error Code 040200 at cold boot:
http://www.flickr.com/photos/66071596@N00/6774982287/
http://youtu.be/dx47sgAoMZY
I never tested this board because it came with a 512k board when I purchased it, and the 512k board always worked and gave me more RAM to boot. Not sure if the previous owned upgraded to the 512k for the RAM only or because his previous 128k board had problems. In any case, I do see that at least 2 of the 3 axial electrolytic capacitors on the board have leaked. What are your thoughts?
Thanks.
User avatar
JDW
Re: 128k Sad Mac Error Code 040200
Postby techknight » 29 Jan 2012, 01:11
could be anything. But because of the picture artifacts that come and go, I am betting on RAM, as those artifacts are landing within the address locations of the framebuffer, be it RAM itself or the A/D lines between RAM and display.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby JDW » 29 Jan 2012, 10:30
So you would not rule out bad influences from leaked capacitor fluid then?
User avatar
JDW
Postby techknight » 29 Jan 2012, 17:46
only if there is evidence of it. Meaning, you can physically see corroded traces, and if you follow a schematic and test point to point between RAM and its logic.
if thats ok, then no its not the electrolyte. Be honest, i dont think I have found any cases in my personal experience that capacitors have "killed" a board. Sure, they have done lots of damage, but unless its VERY severe, the electrical connections still remained intact. Now batteries on the other hand, yea.......
Besides If I am not mistaken, the axial capacitors are only in the power plane.
But all in all, since the capacitors have leaked and me not physically being able to see the board, no i cannot entirely rule that out, but judging by your picture, the capacitor hasnt leaked enough to do any damage at all. Axials typically do not.
techknight
Postby JDW » 30 Jan 2012, 03:35
I see a bit of green gunk at the point where the leads exist the body of the axials -- always a sign of leakage. Furthermore, I was brushing dust on the board away with a small paintbrush when I noticed that I was starting to paint with a clear liquid. But I did not spot any eaten traces.
Assuming the 040200 Sad Mac Code is RAM related, does that code point us to a specific chip on the board?
User avatar
JDW
Postby gubbish » 31 Jan 2012, 16:08
Here's the table of Sad Mac codes:
http://support.apple.com/kb/TA46376
Looks like 040200 translates to bad RAM at location G6.
gubbish
Return to Compact Mac
Who is online
Users browsing this forum: MinerAl and 1 guest
