80 pin -> 50 pin SCSI adapter in SE/30
Macintosh, 512k, SE, etc.
Postby Brooklyn » 29 Nov 2011, 05:41
So, I have a 1gb 80 pin SCSI hard drive I wanted to use in an SE/30. So I bought an 80 pin to 50 adapter for it. However when I boot up the system with disk tools floppy, Apple HD Setup does not detect any SCSI devices. The only thing I can think is I have to mess with jumper settings. The adapter came with 2 jumpers, and these are the pins on the adapter:
Any idea on what pins need jumpers? Thanks!
Currently Looking for: Apple II (not the plus or e) logic board in any condition.
Sonnet G4 1ghz ZIF upgrade CPU (for Beige G3)
User avatar
Brooklyn
Re: 80 pin -> 50 pin SCSI adapter in SE/30
Postby uniqueidentity » 29 Nov 2011, 08:57
Are you using the patched version of the tools? If not then it will only see Apple branded hard drives.
uniqueidentity
Postby Brooklyn » 29 Nov 2011, 14:55
Apple version. Where is the patched version? Or what tools should I use?
User avatar
Brooklyn
Postby ChristTrekker » 29 Nov 2011, 15:43
Quick googling finds this: http://lowendmac.com/sable/07/mac-drive ... patch.html
Or maybe Gamba's page has a link.
User avatar
ChristTrekker
Postby Trash80toHP_Mini » 29 Nov 2011, 15:56
Hard Disk Toolkit
The Mac's controller is SCSI ID 0, so you'll most likely need a jumper on ID 1 or ID2 as the Adapter/Drive's identifier on the chain.
If your HDD has an ID jumper installed, you've already got a bit of SCSI Voodoo going there.
Dunno about the rest, but that activity header definitely needs an LED lead! ;)
Got a clearer pic or docs to scan? :?:
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby Brooklyn » 29 Nov 2011, 16:17
Thanks guys for the software links.
The adapter came with no documentation. It came with a jumper on "ID 1" and "REM"
User avatar
Brooklyn
Postby Trash80toHP_Mini » 29 Nov 2011, 16:23
Apparently, that jumper config was your documentation. Gotta love it! ::)
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby ojfd » 29 Nov 2011, 17:35
Trash80toHP_Mini wrote:The Mac's controller is SCSI ID 0, so you'll most likely need a jumper on ID 1 or ID2 as the Adapter/Drive's identifier on the chain.
Wrong!
Mac itself (initiator) is always ID 7. Internal drive that consists System folder traditionally is set to ID 0.
So, Brooklyn, if this drive is your only drive, no jumpers on ID pins are needed.
BUT, unless your SCA adapter has onboard terminators, you have a problem.
SCA drives do not have any kind of onboard termination, but your SCSI chain in SE/30 needs to be terminated. Solutions to this problem would be:
1. Use different internal cable (with one extra connector) and use 50 pin terminator that attaches to that cable.
2. Use 'pass-thru' terminator (see below) on exsisting cable.
http://www.cs-electronics.com/sca-adapt.htm
http://www.cs-electronics.com/scsi-term.htm
Looking for: WGS-9150 m'boards, Apple TwinTurbo 128MA Rev.3.7 (short), Asus TX-97 (Socket 7) m'boards
ojfd
Postby Trash80toHP_Mini » 29 Nov 2011, 17:55
Thanks for the correction, o, I hadn't had coffee yet and must have got SCSI IDs mixed up with PseudoSlot IDs . . .
. . . if that's not right either, my next excuse will be that I'm home sick with a horrible cold, waiting it out to see if I'll need the antibiotics the doctor gave me a scrip for yesterday morning.
My inflamed sinuses are apparently blocking my brain from controlling my fingers . . . :I
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby Brooklyn » 29 Nov 2011, 18:47
It looks like the one I have has "passive" termination. So I'll have to find a way to terminate it...
User avatar
Brooklyn
Postby Trash80toHP_Mini » 29 Nov 2011, 19:09
This one I do know is correct! Even if this is a bit nit-picky and something you already know, it's well worth defining the terms. Termination is either on of off, commonly set by a jumper or switch position. Whereas Active Termination is the function of additional electronics, usually implemented on the pass thru Connector/Adapter PCB of an external peripheral's enclosure. "Passive" termination would be the simple on-off toggling setup, like the jumper block on you adapter's header connections.
Unless, of course, common usage has blurred the distinction since that time when SCSI Interfaced Consumer Products and Wooly Mammoths roamed the Earth.
< . . . figures it's well past time to post a pic of such a critter in the Peripherals Forum & hopes WiKiPedia linkages will save him the bother . . . >
edit: drat! no automagical linkage . . . does the presence of text modifier code prevent this? :?:
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby PowerPup » 29 Nov 2011, 20:12
I remember having one of those adapters on a Seagate drive in my 6100, though I don't have the drive or adapter on me anymore. :(
I would try placing jumpers on ID0 and TPR. TPR tells me it might stand for "Termination Powered" or something-a-ruther. :P It can't hurt* to try anyway. ;)
* I reserve the right to be not responsible for any damage and/or personal injury that may or may not happen by listening to my "words of wisdom." :o)
Macs I own: Classic II, LCIII, PowerMac 6100 w/ NewerTech G3 250Mhz CPU, PowerMacintosh G3, PowerMac G4 "Sawtooth", PowerBook 5300, PowerBook 3400, PowerBook G3 "Lombard", PowerBook G4 Titanium.
User avatar
PowerPup
Postby 24bit » 29 Nov 2011, 21:28
TPR is likely "Termination Power" the device will empower the bus in case voltage is weak.
This does NOT mean the bus is terminated. Termination has to be done seperately on the 50pin flat cable.
If you want to use ID0, no jumpers for SCSI ID have to be set.
If you need software for initializing your third party drive, you might try Lido:
http://macintoshgarden.org/apps/lido-756
Let us know how it goes, many of us will have to aquire old SCA server drives, as SCSI-1 50pin drives are becoming rare.
Edit: oops, just realized ojfd made things clear already.
Still running: 7100/80 and iMac Bondi blue with a few SCSI peripherals.
24bit
Postby ojfd » 29 Nov 2011, 22:24
Brooklyn wrote:It looks like the one I have has "passive" termination. So I'll have to find a way to terminate it...
How do you know that it has "passive" termination? Does it have several terminator resistor blocks like that black SIL package at position RN1 in the picture?
Yours look to me more like this one (no terminator resistors)
The more I think about it, the more it looks that your problem might be even bigger. What 80-pin SCA drive is it that you have? Wide or Narrow? What's the model number? If it's Wide, then you have to terminate remaining 9 signal lines on the drive as well to allow it to run on Narrow bus. In fact, that SCA-TERM adapter in top picture does just that. There's a chance that your drive still might work without terminating those extra 9 lines, but it also might not. It depends on a lot of circumstances. Correct way to do it would be to terminate them. Using SCA drives on Narrow bus is tricky, better to stay away from them, if you're not a SCSI expert.
Check the links I provided in my post above.
More info also at: http://tinyurl.com/bsklufj
ojfd
Postby Trash80toHP_Mini » 29 Nov 2011, 22:41
This is a great start on a SCSI Voodoo HowTo for a sticky post in the Peripherals forum. As has been mentioned, we're all going to wind up using obsolescent server drives until somebody here decides to compete with Acard for the IDE <-> SCSI Adapter market.
Keep the informed and expert information rolling in here folks . . . :approve:
. . . I'm crawling back into bed for a while . . . xx(
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby ojfd » 29 Nov 2011, 22:53
Follow up.
What I did, when I needed to put modern UW SCA drive on narrow bus was:
1. Installed this type of Narrow to Wide adapter directly on motherboard
2. Installed this type of SCA to UW adapter on the drive.
3. Replaced Narrow cabling with Ultra Wide one and used cable that had UW terminator at one end.
In that way, Ultra Wide drive had all signal lines properly terminated.
If the cable is too long / has too many connectors, it couldt be cut off near the last connector with very sharp knife
Flat, Ultra 2 cables (yellow) work best with older SCSI chips, I had problems with Ultra 160/320 twisted pair LWD terminated cables on some occasions. Don't ask me why, I don't know. (Impedance? Different termination circuitry?)
ojfd
Postby Trash80toHP_Mini » 29 Nov 2011, 23:06
How much length do the twists in a modern cable add to the actual length of wire that the older chipset's cable drivers are forced to handle in that scenario? :?:
Just though I'd ask . . . ISTR reading that too many adapters/connections could cause capacitance to rear its ugly head . . . but I've already been wrong once in this thread.
Apparently My Mileage Does Vary . . . |)
edit: does anybody have linkage to a well known, reputable, relatively affordable source for new, high quality internal SCSI cables and adapters?
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby PowerPup » 29 Nov 2011, 23:13
@ojfd: Huh, that's almost how I have my 4GB Compaq 68-pin SCSI drive set up in my 6100. :) I used one of those 68-pin to 50-pin adapters on the motherboard, a 68-pin cable, and another 68-pin to 50-pin adapter for the CD Rom Drive.
@24bit: Yeah, I realized that the Seagate I used was a 68-pin, not 80. So... I'll leave the SCSI advise to all you "experts." ;)
User avatar
PowerPup
Postby ojfd » 29 Nov 2011, 23:30
Trash80toHP_Mini wrote:edit: does anybody have linkage to a well known, reputable, relatively affordable source for new, high quality internal SCSI cables and adapters?
See links I provided in my posts :-)
Feel free to delete this post afterwards.
___________________________________________________________________________
edit by jt: Thanks for the face-save offer there, ojfd!
But, nah! Let this stand as an object lesson for other -lazy-- . . . erm . . . casual . . . readers of informative threads like this! :o)
http://tinyurl.com/bsklufj = source posted above :I
xx(
ojfd
Postby 24bit » 30 Nov 2011, 01:16
I only saw one more or less affordable 73GB new IBM drive here for EUR 63.- plus costs for an adapter.
Who would need 73 GB for a 68k Mac? Maybe the Amiga SCSI-1 to CF are the way to go rather.
powerpup, I hope I didnt hurt anybodies feelings, I´m by far no expert with SCSI HBA.
The few experts I knew, sadly moved to cemetary many years ago. The SCA would be trial and error for me.
24bit
Postby PowerPup » 30 Nov 2011, 04:49
@24bit: Oh no, you didn't hurt anyone's feelings. I was just being silly by using the word "expert." :o) Trial and error is my method for messing with SCSI too. ;)
User avatar
PowerPup
Postby Brooklyn » 03 Dec 2011, 02:43
Still no luck with the drive, I noticed it is causing my Mac SE/30 screen to have some wavy-ness that travels from the bottom of the screen up. I think it much have some interference with the power supply. Went to my 250mb Apple drive for now, going to have to revisit the scsi drive for another project. :-/
User avatar
Brooklyn
Postby mcdermd » 03 Dec 2011, 08:35
I am dealing with the same issue on a SCA drive connected to a 50-pin cable with a 50-pin to 80-pin drive adapter. I'm thinking one of these four ways should be successful but .. which one? The SCA drive I'm using (and most - all? - SCA drives) provides no termination so I'm going to have to have a terminator on the cable. Do I ...
1. get a 50-pin inline terminator to go between the 50-pin cable and the adapter (or logic board).
2. get an 80-pin inline terminator to go between the adapter and the SCA drive.
3. get a 50-pin to 80-pin adapter to go between the logic board and an 80-pin cable plus an inline 80-pin terminator to the drive.
4. get a 50-pin to 80-pin adapter to go between the logic board and a multi-connection 80-pin cable plus a terminator for the third cable connection (the one after the logic board and the drive).
5. Get a different 50-pin to 80-pin adapter that has termination onboard.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby ojfd » 03 Dec 2011, 14:01
mcdermd'
There are no such things as 80-pin inline terminator or 80-pin cable. :-D
Thihk again and reformulate your question(s).
ojfd
Postby mcdermd » 03 Dec 2011, 20:55
That should teach me to go to bed at 1:30am instead of posting here. :(
SCSI is still such a black art for me.
User avatar
mcdermd
Return to Compact Mac
Who is online
Users browsing this forum: jwse30 and 4 guests
