it should work just fine with a Plus as well.
I'm not going to go through it again, but if you search up my explanation of why the Artmix SE/30 PDS passthrough/Daystar adapter is so expensive, that explanation applies to this device just as well.
We need some kind of kickstarter for these kind of projects.Trash80toHP_Mini wrote:The Artmix board appears to be two sided from the highres pics I have on file. The size of the thing cut down to just a PDS bus slot multiplier would still be a consideration for two sided protoboards.
trag, got linkage to your explanation?
billynomates wrote:It goes through the installation until 'Reading Apple Guide: Shortcuts', where it says 'closing files', and looks like it's finishing the installation - but mighty quickly. Then the above error pops up.
There's nothing on the CF when I checked it. The activity light does flash occasionally (can't tell if it's reads or writes), and I can copy stuff to and fro to my hearts desire, using the hfs that the Anubis software installs. If I leave a System Folder on the CF when I install, the installer recognises it (with appropriate version / upgrade messages), and won't allow me to use the disk.
Users browsing this forum: No registered users and 2 guests
