JDW wrote:• I assume it did not come with the screws, nuts or mounting bracket shown in the PDF manual, so how did you mount it in your Mac?
JDW wrote:Some questions...
• What Mac did you put it in?
• What specific CF card did you use with it?
• What is performance like relative to a fast spinning platter hard drive? (Boot times, launching of apps, file duplicate, Benchmark utils, etc.)
JDW wrote:• Continuing thoughts about performance, so long as the CF card is 128GB or smaller, the manual says it should work (as long as you partition it properly for the OS you intend to use). But can this product take advantage of all the speed boosting features of newer CF cards?
Udo.Keller wrote:...PIO-6 means 25MB/s and UDMA-2 means 33.3MB/s. Both are far below the leading edge of e.g. SanDisk Extreme 60MB/s or SanDisk Extreme Pro 90MB/s... I will report some performance numbers as soon as possible.
JDW wrote:Udo.Keller wrote:...PIO-6 means 25MB/s and UDMA-2 means 33.3MB/s. Both are far below the leading edge of e.g. SanDisk Extreme 60MB/s or SanDisk Extreme Pro 90MB/s... I will report some performance numbers as soon as possible.
If possible, a performance number test with "the leading edge" Extreme Pro 90MB/s please!
JDW wrote:Thanks for posting the performance chart, but what is the frame of reference (i.e., the comparison with a normal, spinning-platter drive in the same computer)?
JDW wrote:And, regardless of what the benchmark charts say, how fast does it FEEL to you?
theos911 wrote:I just ordered a Kingston 266x card from newegg for my Wallstreet...
Users browsing this forum: gsteemso and 4 guests
