HD20 Schematics required
Macintosh, 512k, SE, etc.
Re: HD20 Schematics required
Postby ralphw » 23 Feb 2011, 08:24
These are just guesses, without looking at the drive.
The Rodime drives of my youth were either MFM or ST-506 devices. We used them because they only cost a few hundred dollars for a 40M drive, so we could risk
putting them in moving vehicles (a robot truck that could drive itself - as long as you didn't need it to go very fast...)
A company called "Adaptec" (might sound familiar), made an ACB-4000 card, which sat on top of the drive and converted SCSI commands to MFM/RLL ST-506 signals.
Check http://bitsavers.org/pdf/adaptec/400003-00A_ACB4000UM_Oct85.pdf for details.
Not sure if this will help with the reverse engineering project, but the background information will be helpful.
I'm interested in other project that can leverage the 'Disk II" controller technology. It would be fun to build a network interface with one.
wanted: Apple II, Apple //e, and Apple ][gs parts, connectors, chips, expansion cards
for sale: not yet
have: ][+, B&H ][+, //e, //c (to be tested), '05 Mac mini (server)
in storage: '93 660AV, '97 7300/180, '01 ibook, '04 G4 eMac
ralphw
Postby Mac128 » 23 Feb 2011, 17:28
ralphw, yes there were a number of SCSI conversion kits, even one by Personal Peripheral Comouter Corp. actually endorsed by Apple, that was quite popular, based on the MacBottom interface (which some say the HD20 was based on). But I'm not sure that helps us. I posted a similar article about John Bass' early SCSI interface, and the consensus seems to be that once you go SCSI, there are so many easier ways to go about it, unlike in 1985. Without documentation, would such an interface actually be of any more assitance than testing the original HD20 interface directly?
More can be found out about the drive and interface here: viewtopic.php?f=7&t=1036&start=50&hilit=HD20+scsi
User avatar
Mac128
Postby Dennis Nedry » 30 Mar 2012, 04:25
Sorry to drag up an old topic, but I have been poking a bit at the Z8 ROM dump from my HD 20. This is a 2k ROM and only a very small part of that appears to be instructions when you look at the LST file that I got when I disassembled it. They may very well have done something tricky that did not tip off the disassembler to some of the code, but I feel pretty optimistic about the job that IDA did. Some explanation for the vast amount of non-instruction code is the presence of the 1-bit icons when opened as a raw image in GraphicConverter. It is likely that chunks of Mac code and resources exist in the ROM that are sent over while booting.
This may not be TOO terribly hard to figure out, but I'm not used to this Z8 stuff. I'm stuck almost right away at address 0x0309. There is a return from subroutine here after the code appears to have jumped into the middle of that subroutine instead of calling it - and as far as I can tell, this would cause the stack size to go to -1 after the return, and who knows where it would try to return to. I also am having trouble understanding addressing and initial values when dealing with general purpose registers R0, R1, R2, etc. i.e. Almost immediately R0 and R1 are copied into RAM. I do not know the initial values of R0 or R1 (assumption is that they are pointers to P0 and P1, or both to P0), and also, when dealing with them, I am unsure if I am accessing the pointer itself or the data stored wherever the pointer points to.
Does anyone know of a simple Z8 simulator? I would like to load the ASM or machine code data into it and step through the instructions 1 by 1 and watch the effects on various ports and registers. This would be a great way for me to learn. I've seen these simulators for different processors, often times written in Java and they are quite nifty.
My goal in figuring this out is to develop and share an understanding for whatever protocols are being used by this drive so that it can eventually be reproduced. It honestly DOES NOT appear to be very complicated, and what could you expect from a 1980s Z8-based microcontroller? This is possible to figure out.
Dennis Nedry's 68kMLA Wiki Userpage, including my extensive Mac collection.
Dennis Nedry was an awesome Mac hacker, but I hack Macs in his name to preserve, not to destroy.
User avatar
Dennis Nedry
Postby Gorgonops » 30 Mar 2012, 15:51
It's interesting that you did indeed find those drive icons that were being discussed earlier in the thread, and they were apparently not already GCR encoded. Just a guess, but I'd be willing to bet that at least some of that "junk data" that you're having trouble interpreting is a GCR lookup table. This NetBSD source file:
http://nxr.netbsd.org/source/xref/src/s ... obio/iwm.s
Has GCR lookup tables apparently copied straight from the MacOS .Sony driver, perhaps you could see if they pattern match some of those mystery bytes?
No luck looking for a simple Z8 simulator myself; if you were using a Z80 or 6502 you'd have a million choices, of course. It looks like Zilog has some downloadable developer tools, and the ZDS II - Z8Encore! package says in the readme it includes an "instruction set simulator" along with the C compiler, assembler, disassembler, etc, etc. Is it the Zilog disassembler you're using? Granted I have no idea at all if the "Z8 Encore!" is different enough from an old-style Z8 to invalidate using the tools for it for investigation.
User avatar
Gorgonops
Postby Dennis Nedry » 30 Mar 2012, 16:44
I had access to IDA Pro for a short time, and that is where this disassembled LST file came from.
From what I understand, all CGR encoding/decoding in the Mac occurs in the IWM chip, and the respective decoding/encoding in the HD20 occurs in its very own IWM chip, so it seems like no CGR stuff is ever handled in software. That makes a lot of sense - why spend a load of overhead in software when it can be done in hardware with a crazy Steve Wozniac state machine chip that works in both directions.
For development purposes, we could use a real IWM chip from a busted Mac or HD20, and once the HD20 controller is running well, we could then move on to emulating the IWM chip too. Other than the IWM, it looks like there is only a flip-flop for managing the daisy chain port and some simple combinational logic between the Mac and the HD20 controller. This stuff can be reused directly for development and then emulated and integrated in at a later time.
Page 7 in UM001604-0108 wrote:General-Purpose Registers are undefined after the device is powered up. The registers keep their last value after any reset
Aha! Wait... :?:
edit
R0, R1, R2, etc apparently are "working registers", not "general purpose registers", so the above quote does not apply.
This is weird because it looks like there is a "register pointer" separate from the working registers that can change, and then any operations on the working registers themselves utilize that pointer to read or write to respective parts of memory.
edit
There is an instruction dedicated to setting the register pointer. This is beginning to make sense now. This spec sheet is definitely not written like a Z8 for dummies.
edit
Hard to find, but page 34 states that the reset value of the register pointer (0xFD) is 0x00. Yay!
All registers 0x04 - 0xEF are undefined after reset.
User avatar
Dennis Nedry
Postby Gorgonops » 30 Mar 2012, 16:59
Dennis Nedry wrote:From what I understand, all CGR encoding/decoding in the Mac occurs in the IWM chip, and the respective decoding/encoding in the HD20 occurs in its very own IWM chip, so it seems like no CGR stuff is ever handled in software. That makes a lot of sense - why spend a load of overhead in software when it can be done in hardware with a crazy Steve Wozniac state machine chip that works in both directions.
No. I think there are already links in this thread, but if not a quick Google will dissuade you from thinking that. The IWM is a *very simple* device, and it's almost entirely driven by software. GCR encoding/decoding is done by the CPU, completely, and is incredibly timing dependant which is why the driver code uses a lookup table instead of calculating bytes directly.
(Google) Here's Big Mess O' Wires brief commentary on how it works, and it includes useful links:
http://www.bigmessowires.com/2011/10/02 ... g-schemes/
Also, I probably threw this in already, but this page is probably useful too. It's about the Apple IIgs, not the Mac, but it's the same IWM chip.
http://www.mac.linux-m68k.org/devel/iwm.php
The page glosses over one thing, the "Unfortunately, the data must undergo considerable preparation before writing and after reading." part. That's where it references the deep-dive Apple DOS documentation, and in *that* you'll find the description of how a track read from disk "in its raw, encoded form" gets converted back to normal.
(Dang it, another edit.)
Now, the one thing that I suppose *might* be possible is that when being used for this application the driver code on both the Mac and HD-20 side aren't using the standard GCR encoding tables at all but something different. The state machine in the IWM is basically works as a crude data separator/"protocol enforcer", which according to its clocking counts bits and signals errors if it encounters invalid patterns of data, which for the most part would involve reading too many "zeros" in a row. The GCR encoding is a way to ensure that doesn't happen... if a given byte is all zeros, say, it's transformed in such a way that what's written to disk never has... I think it's more than two, zeros in a row. (I'd need to check the documentation.) It's probably possible you could write a simpler driver which would, say, instead of using 6 to 8 GCR patterns substitute an interspersed a timing bit every other bit, giving you essentially 4 to 8 GCR, which might be quicker to calculate on the fly instead of with a lookup table. (I wouldn't guarantee it, though.) Maybe the HD-20 does something like that. But at least according to my reading of the data sheet I *don't* think it can operate as just a straight UART. Trying to program that thing is probably above my pay grade, and I don't have the hardware to try to cross-connect two of them, so... the *simpler* thing to hope for is that it's using the documented protocol for data transfer.
User avatar
Gorgonops
Postby Dennis Nedry » 23 Apr 2012, 04:28
It has occurred to me that the apparent accessing of un-initialized SRAM registers at the beginning of the program in the HD-20's ROM may be a way of generating random numbers that may be necessary for floppy bus access arbitration among multiple HD20s. Or some other reason that they needed a random number. The SRAM is external to the Z8, and the datasheet does not indicate that there is any particular power-on value of the RAM bits, which is expected.
Earlier, I was attempting to watch the serial communication on the floppy port when a Mac Plus was talking to the HD20. It makes a LOT more sense to watch on the Z8 side of the IWM chip, for several good reasons:
  • Data is in decoded form (No GCR to deal with)
  • Data from other disk drives and stuff is likely filtered out
  • We don't have to know how the PAL works yet, which shouldn't be too hard to crack, but bugs could definitely arise from it
  • You can easily tell if data is going from the HD to the Mac or Mac to HD
  • You can find data from the Mac and pick around in the HD20's ROM for something that handles that command to help figure out what it is.
So, with these things in mind, we can bite off a smaller chunk and focus on figuring out the protocol for how this thing communicates. When/if that comes along, we can detach the PAL/flip flop/IWM from the rest of the controller board and connect a microcontroller that emulates the protocol in place of the removed part of the board.
Once that gets pretty solid, we could begin to emulate the rest of the hardware as well, which is much simpler. The flip-flop is figured out unless I made a mistake. The PAL will take a little testing, it is D-latched and has 2 feedback outputs, but it can certainly be done. And then the IWM - it seems that the IWM has some experience being emulated, so we can save that for the end.
I really want to make this thing work, not only for old times' sake and usefulness, but for the hacking experience. I haven't done a project quite like this before and I think there's a lot to be learned from it. I want to learn about mass storage in Flash memory to/from a microcontroller. I've never had a very good reason to do that.
User avatar
Dennis Nedry
Postby Gorgonops » 23 Apr 2012, 16:40
Dennis Nedry wrote:[*]Data is in decoded form (No GCR to deal with)
(BROKEN RECORD MODE)
Again, you're going to be very disappointed if you're expecting the bytes read off the IWM's data bus to be in "plain text". The IWM *reads and writes GCR encoded data*. Apple's "data sheet" for the IWM only alludes to this fact because it expects the user to be familiar with the Disk][ controller, but every place in that document where they use the phrase "8 bit nybble" they do *not* mean an unencoded 8-bit byte. They mean an 8 bit nybble, and they are not the same unless the IWM secretly supports a mode where it acts like a straight-up UART.
(/END BROKEN RECORD MODE)
Edits:
#1. For the record, in the book "Beneath Apple DOS", it's noted that the address marks on an Apple II disk are not GCR encoded; instead they use an "even-bits/odd-bits" 4-to-8 encoding, in which every other bit is a one. (Which would make it a valid read so far as the IWM is concerned.) It's certainly possible that communication with the HD-20 does something like that... although doing so would cut the effective data rate by about 40%, so unless it were vitally important that communication with the HD-20 trade performance for computational simplicity it seems like a poor deal. (And the bytes coming off the IWM *will still be encoded*.)
#2. Without scrolling back... did you figure out what that big unlabeled chip on the HD-20 board did? For all I know it's possible *that* is intelligent enough to do GCR encoding/decoding, although cooking an IC just for that would probably be overkill considering how bad Apple seemed to be at cooking custom ICs.
User avatar
Gorgonops
Postby Dennis Nedry » 23 Apr 2012, 23:32
I was under the strict belief that the very point of the IWM was to encode/decode GCR. What is your impression of the overall purpose of the IWM chip when it is on a Mac logic board? It seemed to me that the Mac could talk in 8-bit words to the IWM, and the IWM would translate to GCR for the floppy drive. It seems unlikely to me that they would have put that overhead onto the processor instead of a dedicated chip.
It's been a while since I read the digibarn IWM article, but if I have the entire concept of its function wrong, it must have gone WAY over my head.
The large square chip exists exclusively between the Z8 and the Rodime drive from what I can tell. I have found no connections in common with the floppy port side of the Z8.
Today I pulled the PAL chip from my HD20 and I'm trying to figure out how to dump it. It has D latches on 6 of the 8 outputs so that makes things interesting. Only 4 outputs are used elsewhere on the board, 3 of which are gated. I have built a microcontroller program that runs through each possible input, clocks, and records the outputs, but this probably isn't enough data to figure it out. I'm still working on it so we'll see.
User avatar
Dennis Nedry
Postby Dennis Nedry » 24 Apr 2012, 00:27
Page 1 of the IWM spec wrote:The IWM is a peripheral device that connects to a host data bus. The device generates and receives serial GCR encoded data.
Because you read and write to floppy disks, the IWM chip must be able to encode and decode data, so hooking it up in reverse like what is happening in the HD20 should be totally possible. The Z8 is on the data bus side of the IWM, so I am assuming that all data available to the Z8 is decoded.
Please point out where I'm wrong, I don't want to jump into something that I'm not capable of.
User avatar
Dennis Nedry
Postby Dennis Nedry » 24 Apr 2012, 05:26
The first 3 outputs are synchronous and register each via a D-Latch on positive clock edge. The 4th output is asynchronous. I tested with all 8 outputs, all 8 inputs, and all 8 outputs as additional feedback inputs. After a very small amount of experimenting, I didn't see any obvious indication that the extra I/O and feedback had any effect, and that leads me to believe that this thing is programmed in a more combinational manner, without any state machines programmed into the PAL. We don't know for sure without some extensive and pretty smart cracking, either that or attempting to dump the data from this chip, which may or may not be protected.
IF this chip is just combinational with output registers, then here is the I/O that I read from it:
Input: Pin 2, 3, 4, 5, 6, 7, 8
Output: Pin 18, 17, 13, 12 (12 being async)
Code: Select all
Input     Output
0000000   0011
0000001   0110
0000010   0110
0000011   0011
0000100   0111
0000101   0110
0000110   0110
0000111   0111
0001000   1001
0001001   1100
0001010   1100
0001011   1001
0001100   1101
0001101   1100
0001110   1100
0001111   1101
0010000   1001
0010001   1100
0010010   1100
0010011   1001
0010100   1101
0010101   1100
0010110   1100
0010111   1101
0011000   1001
0011001   1100
0011010   1100
0011011   1001
0011100   1101
0011101   1100
0011110   1100
0011111   1101
0100000   0001
0100001   0100
0100010   0100
0100011   0001
0100100   0101
0100101   0100
0100110   0100
0100111   0101
0101000   1001
0101001   1100
0101010   1100
0101011   1001
0101100   1101
0101101   1100
0101110   1100
0101111   1101
0110000   0001
0110001   0100
0110010   0100
0110011   0001
0110100   0101
0110101   0100
0110110   0100
0110111   0101
0111000   1001
0111001   1100
0111010   1100
0111011   1001
0111100   1101
0111101   1100
0111110   1100
0111111   1101
1000000   0011
1000001   0110
1000010   0110
1000011   0011
1000100   0111
1000101   0110
1000110   0110
1000111   0111
1001000   1001
1001001   1100
1001010   1100
1001011   1001
1001100   1101
1001101   1100
1001110   1100
1001111   1101
1010000   1001
1010001   1100
1010010   1100
1010011   1001
1010100   1101
1010101   1100
1010110   1100
1010111   1101
1011000   1001
1011001   1100
1011010   1100
1011011   1001
1011100   1101
1011101   1100
1011110   1100
1011111   1101
1100000   0001
1100001   0100
1100010   0100
1100011   0001
1100100   0101
1100101   0100
1100110   0100
1100111   0101
1101000   1001
1101001   1100
1101010   1100
1101011   1001
1101100   1101
1101101   1100
1101110   1100
1101111   1101
1110000   0001
1110001   0100
1110010   0100
1110011   0001
1110100   0101
1110101   0100
1110110   0100
1110111   0101
1111000   1001
1111001   1100
1111010   1100
1111011   1001
1111100   1101
1111101   1100
1111110   1100
1111111   1101
The last output is the last 2 inputs xnored in the data.
User avatar
Dennis Nedry
Postby Dennis Nedry » 24 Apr 2012, 06:33
So the results are in. They seem reasonable, though not proven.
Latched:
output bit 1 = input (NOT3 OR 2) NAND 4
output bit 2 = input 5 OR (6 XOR 7)
output bit 3 = NOR of inputs 2, 3, 4
Asynchronous:
output bit 4 = input 6 XNOR 7
So this means that input 1 doesn't matter?? That's not a good sign. Maybe the guys at Apple didn't reduce / optimize the circuit enough to realize that they didn't need that input at the PAL. It's possible.
User avatar
Dennis Nedry
Postby Gorgonops » 24 Apr 2012, 19:48
Dennis Nedry wrote:Please point out where I'm wrong, I don't want to jump into something that I'm not capable of.
I embedded a bunch of links along the way, but perhaps this one, by Big-Mess-O-Wires, which details the hoops that he went through emulating the IWM for his Mac-in-an-FPGA project is... the most straightforward. (I put it in before but perhaps you missed it.) I know "it encodes GCR from a straight data feed" seems like it should be a reasonable explanation of what the IWM does, since most other disk controller ICs *do* accept straight data bytes and completely transparently convert them to FM or MFM encoding on the other side, but... that's just not what it does, according to every in-depth manual on programming the thing I've read. It is *annoying* that basically all the references seem to delight in completely glossing over the "you need to encode the data" part, but it's there, really, I swear.
#1: Read Big-Mess-O-Wires page. He's not talking about encoding grabbed from the "outside" of the IWM, he's talking about puzzling how the encoding is done in software in the Mac ROM...
#2: I know it sucks, but Read this assembly source code for the NetBSD driver for the IWM chip. It's very well commented so you don't need to be able to program in 68000 assembly to read it. You can read the translation table, and you can follow the parts of the code that actually do the disk I/O to see how the bytes are transformed. (IE, three 8-bit bytes get stripped down to six bits, and are converted to 8 bit bytes with no more than two zeros in a row according to the "toDisk" translation table. Then the three 2-bit leftovers are combined into one 6-bit nybble and translated via the table. Three plaintext bytes get converted to four GCR bytes via a software routine. A reverse conversion table is also needed to convert data coming *from* the IWM back into regular bytes, and it doesn't match, on purpose.
(One helpful thing that's noted in this driver: the GCR translation table for MacOS is different than that used by Apple ][ ProDos. So while reading the Apple ][ DOS manuals will tell you the theory, you need to use translation tables lifted from the .Sony driver for the actual conversions.)
Again, I know, it's completely counter-intuitive. Given all the gushing love there is out there for the super-clever Woz disk controller you'd think it was a hardware miracle that was easy to use and did all sorts of magic for you, but it's actually little more than a bidirectional shift register and a very minimal window-based data separator. Everything that makes it work is software. It does *not* encode GCR.
That *all* said... reading the data sheet *again* (which isn't very good) and looking at a Q&A about how the Disk ][ controller works... I'm slightly less certain you *absolutely* couldn't shove data through the IWM that doesn't obey the "no more than two zeros in a row" rule, but I'm far from comfortable with saying that's *not* true. The input side of the IWM, as noted, is a window-based data separator, in which a "time window" for a valid read is opened by the trigger of the last valid bit read, and it's not completely clear to me what would happen if you went too many periods without a zero-one transition. I *swear* I read another document that claimed that the data in the output register would be invalid if that happened (it seemed implied that the IWM would stop reading until the register was cleared at the moment the rule was broken), but I can't find that document so I guess I can't absolutely *swear* that what I read there wasn't actually saying that the routine that grabs the byte off the IWM and checks it against the nybble translation table wouldn't be responsible for failing the byte for not matching the table. *IF* that's what it meant... then maybe you can just yoke two IWMs together and send plain-text through them. It's breaking the rules, but the documentation for the IWM is so bad I can't swear if those rules are hardware enforced in it. The floppy disk routines would have kittens over three zeros in a row, but... someone *really* needs to stare at a disassembly of the the Mac Plus version's of the .Sony driver and figure this out once and for all. The DV17 Sony Driver tech note says what part of the Mac Plus's version of the driver would be called if it were communicating with an HD-20, if there's *anyone* out there able to stare at that and see if that part of the driver uses or skips the GCR translation table calls then the mystery is solved.
But... the IWM does *not* encode GCR. *Please* note I'm not saying this in an attempt to discourage you, by any means. It's just important to understand that *if* GCR-style encoding is a necessity for the IWM to successfully read a data stream on the serial side (which I'm now... not certain about) you're going to get discouraged waiting for "plain text" bytes to appear on its data port. The software for doing the translations isn't that horrible, so if you need to do it shouldn't be a deal breaker for something of this magnitude.
User avatar
Gorgonops
Postby Dennis Nedry » 24 Apr 2012, 21:06
As is often the case, I did not research all of the details or even pay attention adequately to what people where trying to say right here at 68kmla.
It might be possible to figure out what the Z8 is doing on the IWM side and somehow separate that from what it is doing on the Rodime side. That would include the encoding/decoding that the board does for the Mac. It might also lead us to a Rodime spec somewhat by accident, but unlikely due to the custom square chip involved. (The square chip has access to the Z8 address and data busses, also a few control lines direct to the Z8 8-O )
So the key here looks like figuring out the Z8 code. Assuming that the Z8 is ROMless and runs exclusively from the external ROM chip that I dumped, it might be possible to figure this out with that approach. I'm grateful that you explained this for me because I would have done exactly what you said - I would have started looking for patterns in decoded data coming off of the IWM, which won't work with this strange auto-checksum / encoding stuff if that's in there.
It is also possible, as it seemed you alluded to, that the Mac skips it's encoding / decoding process specifically when talking to an HD20, thereby not needing anything to decode it in the HD20. In this case there might be unencoded data fresh off of the IWM, but I'm not really counting on it anymore.
User avatar
Dennis Nedry
Postby trag » 24 Apr 2012, 21:43
Is there an Apple II Disk Controller card which does the same thing as the IWM? I ask, because I have one in a box around here somewhere, and it's built out of discreet components. It should be possible to reverse engineer the IWM from that, if it has the equivalent of an IWM on board -- unless, of course, there are unreadable PALs involved.
I love the work you guys are doing.
trag
Postby Dennis Nedry » 24 Apr 2012, 22:51
I've never done anything with PALs before, nor have I ever really known much about them, but something that puzzles me about this PAL is that all of the unused outputs, latched or not, change states. This seems like potential evidence that those outputs are used internally as previous states for the next clock cycle, for state machines.
Seeing this in graphical form makes me think that input 1 (WR) may have something to do with the 3-state of the asynchronous I/O (RD). RD can also be used as an input when it's high-impedance, and I certainly didn't test for that.
If I had some resistors handy, I'd run it once with a pull-up and once with a pull-down on the RD pin. Any difference would indicate high-impedance. Any differences in other outputs when the RD output is different would indicate that it is being used as in input during its high-impedance state.
trag wrote:unless, of course, there are unreadable PALs involved.
All PALs are completely readable with enough persistence functionality-wise, they are finite state machines! }:) It's just tempting to see a pattern and assume that's it before every possible combination is exhausted. I bet this PAL is still directly dumpable, it's from 1985. I don't have anything that can do that for me though.
User avatar
Dennis Nedry
Postby Dennis Nedry » 25 Apr 2012, 01:10
I found a 10k resistor and ran the test. It turns out that high-impedance state depends on OE. Well, I guess that makes sense. It still doesn't make WR do anything. Within the scope of the original test, I have verified that this I/O does not function as a meaningful input during high impedance state.
To do this, I ran the test once with the I/O pin pulled up and once with it pulled down. I then compared the outputs of the 2 tests. Only the I/O pin was not the same between the 2 tests, it didn't affect any other outputs. The ones that were different show us high-impedance state.
It is possible that there was an extra input pin and they went ahead and ran a WR trace to it in case they might need it - then they could just replace the PAL if they need WR in the logic. That seems reasonable.
User avatar
Dennis Nedry
Postby Dennis Nedry » 25 Apr 2012, 04:23
As I go back over my work, I think I may have made some critical errors ...
I believe that I got confused 2 ways: flip inputs 0 - 7 to 7 - 0, and counting 0-based vs. 1-based. I'll go through it more much more carefully now and redraw the chip again.
User avatar
Dennis Nedry
Postby Dennis Nedry » 25 Apr 2012, 07:07
The diagrams I provided are almost completely wrong, I don't really know what happened. But this data is well-verified this time.
Here is the key:
Output:
F0 = Pin 12: RD
F1 = Pin 13: Z8 P22
F2 = Pin 14: nc
F3 = Pin 15: nc
F4 = Pin 16: nc
F5 = Pin 17: Z8 ?
F6 = Pin 18: Z8 P31
F7 = Pin 19: nc
Input:
A = Pin 9: nc (notably missing from minimized logic!)
B = Pin 8: PAL OE'
C = Pin 7: CA0
D = Pin 6: CA1
E = Pin 5: CA2
F = Pin 4: Z8 P37
G = Pin 3: WR Data
H = Pin 2: WR
Logic Friday Minimized:
F0 = C' E + D E + D F + D' E' F' H' + D' E' G H;
F1 = E + C' D ;
F2 = F + G' H + G H';
F3 = F + G' H';
F4 = G H + F' H';
F5 = C + D + E' ;
F6 = C' D' E' ;
F7 = G H + G' H';
3-state output is still based on OE' for F0 (Pin 12), and this was figured in to the source data by entering don't cares for this output when it is in 3-state mode. Unless there's hidden logic on previous states, for example, using the latched data stored in F2, F3, F4, I'm confident that this is the correct solution to the PAL chip now.
It honestly terrifies me that F2, F3, and F4 are not =1 or =0. And the complexity of F0. It could be that F0 is a function of F2, F3 and F4, which would indicate a state machine that I haven't found yet. I'm not worried about F7 because it's not latched.
User avatar
Dennis Nedry
Postby Gorgonops » 25 Apr 2012, 17:20
Dennis Nedry wrote:It might be possible to figure out what the Z8 is doing on the IWM side and somehow separate that from what it is doing on the Rodime side...
Separation is good, since of course for the purposes of replicating the functionality of the HD-20 with modern components any details of the Rodime drive itself are not very important... although you do need to understand enough to know what sort of commands get sent to it. The Rodime drive *probably* looks basically like an ST-412-style drive, in the sense that it takes/produces a serialized data stream and uses separate control lines to do things like track stepping/head selection/etc. An "intelligent" flash-based (CompactFlash, SD card, etc) replacement is probably going to support simple LBA addressing, where you can treat the drive as a block of sectors numbered from zero to XXXX. What you need to know regarding the Rodime is:
A: Does the Mac send track/platter selection commands, IE, does the Mac know the "geometry" of the HD-20, or is it treated linearly and the Z8 takes care of the the 3D translation? (Or, possibly, does the controller chip on the Rodime drive itself handle that, and it presents itself to the IWM board as linear?) I *thought* at some point we'd found some documentation saying the HD-20 presents itself to the Mac as a linear device, but the problem is that, given the style of Apple documentation, that may simply mean the *driver* presents it as linear.
B: Does the Z8+IWM do any transformation of the data stream received from the Mac before it's stuffed onto the drive? One theory which *may* be reasonable: If sector data from the Mac is GCR encoded by the normal floppy routine in the .Sony driver before it's sent to the HD-20 it *may* simply be written to drive in the "nybble-ized" form received from the IWM on the other end, rather than every sector being processed by the Z8 beyond the Z8 grabbing it off the IWM bus and stuffing it at a shift register leading to the Rodime's write circuitry. (Perhaps using the onboard SRAM as a buffer to compensate for differing data rates.) GCR produces bit patterns essentially similar to MFM encoding, it may be perfectly reasonable to use the data straight from the Mac.
If "B" is true that may have implications for looking for control bytes. See below:
I would try looking for the translation table bytes in the ROM dump. If the Z8 is decoding/encoding GCR there should be two tables which match the .Sony driver's tables, which you have in that NetBSD source code. Translation tables supposedly lifted straight from the Apple .Sony driver are near the start of that NetBSD source code.
A case like this may be possible: You *do* need to encode according to the rules (IE, no more than two zeros in a row) to use the "data pump" on the IWM. But...
1: Sector data from the Mac is GCR, but the Z8 doesn't decode it; it just shovels it to and from the hard disk. Likewise reads just shovel bytes from the hard drive to the IWM. (Again, probably through a RAM buffer.)
2: Control signals either use a simpler encoding like FM (similar to how address marks are written on floppy disks) and thus use a different table/are calculated directly, or the IWM's serial data pump isn't used at all for "housekeeping" and control signals/sector addresses are bit-banged over the control lines.
User avatar
Gorgonops
Postby Dennis Nedry » 25 Apr 2012, 17:35
Because some unencoded Mac code is stored in the HD20's ROM, one of 2 things is probably true:
-At least some encoding occurs in the Z8
-IWM supports some sort of mode where raw data goes in at the HD 20 and comes out raw in the Mac.
How could IWM require data to be encoded if it doesn't do any encoding/decoding itself? Is it calculating checksums or something? :?:
User avatar
Dennis Nedry
Postby Gorgonops » 25 Apr 2012, 19:00
Dennis Nedry wrote:How could IWM require data to be encoded if it doesn't do any encoding/decoding itself? Is it calculating checksums or something? :?:
Two reasons:
1: Requirements for "you need a bit ever X nanoseconds" stem from the mechanics of floppy drive reading and writing itself. I am *not* enough of a scientist to tell you exactly why they are what they are but collectively they amount to "If you don't keep changing the state of the floppy head from zero to one and back again often enough it's not going to write recoverable data". A long string of "1s" is okay, ideal even, because it gives lots of pulses for the data separator to lock onto when it's reading it back. A long string of zeros, IE, no pulses at all, will screw you because between magnetic flux migration and the not-completely-predictable rotational speed of a floppy drive there's a good chance that you will lose track of how many zeros were supposed to be between the last "1" and the next "1".
In order to comply with that requirement you somehow have to convert bytes which contain long strings of zeros to bytes that have no more than two zeros in a row. (Originally this was specified as "more than one zero" in a row, which in its simplest form is "single-density" or "FM" encoding consisting of a clock bit and a data bit. Apple's GCR pushes it to two, which is why the Disk ][ could store 140k on a floppy in 1979 while a machine using an early Western Digital Single Density controller, like the TRS-80 Model I, only got 90k on the same disk.) The IWM does not do this itself so the CPU has to do it. Literally all the IWM does is provide the hardware for turning those encoded bytes into pulses suitable for the disk drive and recovering said pulses from the drive. For actual reading and writing it does almost nothing more than that.* (asterisk sort of important. See later.)
2: The IWM was built to do number one, so even if it's *not* in this particular application dealing with a troublesome and unreliable data stream sucked off a floppy drive its data recovery hardware is still designed to do that job, so if you try sending it an unencoded data stream with a bunch of zeros... it may choke. The data sheet talks about how the data separator semi-derives its clocking from the last bit received, and it's unclear to me if it will start screwing up if it you send it too many zeros, or if it will work fine(ish) as a UART in this one case since the clocking is going to be more predictable than a disk read and it will just happily keep shoving zeros into the output shift register however many you send. And... the next paragraph is about that asterisk.
(*) There's a head-hurty part of the IWM's data sheet where it talks about the difference between "synchronous" and "asynchronous" modes (the basic difference between those two is "synchronous" is the "slavishly emulating the Disk ][ controller" mode" and "asynchronous" is "I'm slightly smarter about not needing constant CPU attention just to shift out bits, IE, I can at least handle watching a clock input on my own". Around that part of the data sheet, notice the parts that talk about the data format consisting of an "8 bit nibble with the MSB set". In Apple's GCR encoding scheme all valid encoded bytes have a "1" as their most significant bit. (Look at the translation table in the NetBSD driver; none of the "toDisk" bytes are less than 0x80.) Apparently testing for "1" in the MSB of the disk-read shift register is how the old Apple ][ disk routines used to tell if a full byte had been read in from the disk, and the because of that the IWM's hardware has been built to treat the shifting of a 1 into that position as a special event, latching or "stalling" the shift register depending on which mode (async or sync) the IWM is running in. The implications of this aren't totally clear to me, but... it seems to me that at the very least even if it *would* reliably read a string of zeros if you fed it 8 zeros in a row (or any byte starting with "0", for that matter.) you wouldn't know from the polling loop that you'd received a whole byte unless you were keeping track of the expected time to get a full byte independently. (Because you won't get the MSB bit telling you got 8 bits, and that's the only clue the IWM gives you.)
It's... not impossible, maybe, that the software on both sides gets around this by putting the IWMs in sync mode (to avoid the latching), counts the time 8 bits would take when reading, and then grabs 8 bits off the shift register and assumes it's good. But that sounds really sketchy to me, and... there's something else that fills me with dread. It's quite notable that the "diskTo" and "toDisk" tables are different in the NetBSD IWM driver... like, completely different. (Like, diskTo is filled with values that *are* lower than 0x80) Someone needs to sit down and stare at an Apple ][ disk driver. I'm wondering if the values recovered by the IWM's data separator are inverted or something compared to the bytes written, or if there's some shift/XOR going on in the driver that explains it.
Anyway, these are at least some reasons why I'm not at all warm to the idea the IWM is acting like a non-munging UART here. But there may be some completely undocumented mode where it does.
User avatar
Gorgonops
Postby Dennis Nedry » 25 Apr 2012, 19:20
I'm sorry Gorgonops, but I just don't have an attention span long enough to read through all of that and understand what you said right now.
Here is F0 from the PAL considering 1 previous state from all other outputs, Px being the previous state of Fx:
Code: Select all
Minimized:
F0 = B  + D F  + P2 C' F'  + D G' H' + P2 P7 D' E'  + P2 D' E' F' ;
This is from a very limited sample size so it is absolutely not conclusive in any way. Interesting that it seemed to find some connections though.
There are 32,768 possible input combinations considering 8 inputs and 7 feedback outputs (it can't really feedback itself as a previous state because it's not registered.) I tested 256 of them for this.
Come to think of it, because it's not registered, it would need the CURRENT state of the other outputs, DURRRRRR
So this test is rubbish.
edit
;D with current states
Code: Select all
Minimized:
F0 = B  + F4 D'  + F2 F3 D ;
User avatar
Dennis Nedry
Postby Dennis Nedry » 25 Apr 2012, 21:33
Because OE is active Low, the output only matters when B = OE = 0. So the equation can be reduced one step further:
Code: Select all
F0 = F4 D'  + F2 F3 D ;
Expanded to directly include F2, F3, F4 outputs:
Code: Select all
F0 = (G H + F' H') D'  + (F + G' H + G H') (F + G' H') D ;
User avatar
Dennis Nedry
Postby Gorgonops » 25 Apr 2012, 21:36
Dennis Nedry wrote:I'm sorry Gorgonops, but I just don't have an attention span long enough to read through all of that and understand what you said right now.
Short version: You're giving the IWM too much credit for being a smart, multi-purpose, easy to use chip that does many things and does them automatically. In actuality it's a very simple thing designed to do a very specific job, and the question is just how locked the hardware is to doing that job.
User avatar
Gorgonops
PreviousNext
Return to Compact Mac
Who is online
Users browsing this forum: No registered users and 2 guests
